 Old 02-16-2012, 02:43 PM   #1
Caldwell's Avatar
Posts: 112   (View Stats)
Caldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant futureCaldwell has a brilliant future
Default CEL - P0441 ( EVAP )
Like the title says, my car is reading code P0441...
EVAP control sytem incorrect purge flow.
possible causes -
Canister faulty
Purge Valve Solenoid faulty
Leaking EVAP Hose
Faulty EVAP leak detection pump
Anyone pull this code before ?, if so how difficult is it to correct these problems ???
I dont have good luck with working on my own cars, as i tend to cause more of a problem...
thanks alot for your time !!
South Philly 08' Cosmic Blue
Caldwell is offline   Reply With Quote
 Old 02-16-2012, 02:45 PM   #2
ms6forthewin's Avatar
Posts: 525   (View Stats)
ms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the world
I bet its ur purge valve
-2014 Evo X GSR
-2007 MAZDASPEED 6 (SOLD)
BNR S3// ALL-SUPPORTING MODS
ms6forthewin is offline   Reply With Quote
 Old 02-16-2012, 02:49 PM   #3
Caldwell's Avatar
is that different then my BPV ?
 Old 02-16-2012, 02:54 PM   #4
EdgeAutosport.com's Avatar
Posts: 6,206   (View Stats)
Check your gas cap.
 Old 02-16-2012, 02:59 PM   #5
Caldwell's Avatar
nah already tried that one... cant tighten the cap any harder lol
 Old 02-16-2012, 03:02 PM   #6
reset the ecu and see if it comes back. I threw the same code tightened cap/cleared and it never came back
 Old 02-16-2012, 03:03 PM   #7
Caldwell's Avatar
^^^ interesting... how can i do that ?
the car feels great, no noticed difference in performance of any kind...
 Old 02-16-2012, 03:25 PM   #8
Disconnect the battery and then pump the brakes to drain the battery completely.
 Old 02-16-2012, 04:22 PM   #9
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Does the car stumble or idle roughly after filling gas?
NATOR PA
 Old 04-18-2012, 03:57 PM   #10
chintastic's Avatar
Posts: 299   (View Stats)
chintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the world
Im throwing a p0446 code ...car runs normal...I tightened gas cap, rest ecu,, filled up tank and still get a code....afr is normal...idle is normal as well as everything else...idk what to do..I don't wanna go to the dealer.
2013 CWP Mazdaspeed 3 : COBB TIH, COBB Intake, COBB AP, GFB BPV, SURE Shortcut, counterweight, and shifter bushings, Rally Armour mud flaps,
chintastic is offline   Reply With Quote
 Old 04-14-2014, 12:39 PM   #11
homeryansta's Avatar
Posts: 31   (View Stats)
homeryansta is a glorious beacon of lighthomeryansta is a glorious beacon of lighthomeryansta is a glorious beacon of lighthomeryansta is a glorious beacon of lighthomeryansta is a glorious beacon of lighthomeryansta is a glorious beacon of light
Groaned at 10 Times in 3 Posts
I'm getting the same thing too.
homeryansta is offline   Reply With Quote
HTML code is On
P0455, P02187... Evap leak ItalianSA MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 04-04-2012 02:05 PM
evap system delete mrkdspd MazdaSpeed 6 - Engine, Transmission & Driveline 1 02-17-2011 09:22 PM
Very Small Leak (evap code) CEL Mizzle MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 06-16-2010 12:09 AM
DTC P0441??? spnkr21 MazdaSpeed 3 - Engine, Transmission & Driveline 2 03-28-2009 05:05 AM
Page generated in 0.30715 seconds with 25 queries
