 Old 12-13-2011, 06:58 AM   #1
ufboostedgator's Avatar
Posts: 36   (View Stats)
ufboostedgator has a brilliant futureufboostedgator has a brilliant futureufboostedgator has a brilliant futureufboostedgator has a brilliant futureufboostedgator has a brilliant futureufboostedgator has a brilliant futureufboostedgator has a brilliant futureufboostedgator has a brilliant futureufboostedgator has a brilliant futureufboostedgator has a brilliant futureufboostedgator has a brilliant future
Default Click Click in reverse
Before I get flamed, I did search around and have come up with some answers but I am still curious. Every time I am backing out of a parking spot, I get a 2 clicks from the front. Now, it won't do it if you back straight up only if backing up while turning. It also won't click going forward from reverse. Say I back into my spot and then leave, it is smooth. It reminds me of my 4wd truck with auto hubs. When you put it back into 2wd from 4wd, I have to back up about 15 feet until it unlocks the hubs with a distinctive click click then it's good to go. Could it be my LSD that is clicking or does it sound like the CV axles. I read that tightening your axle nut could potentially solve the issue as can greasing everything but before I break down and do it, I want to make sure I am not wasting my time. How often do you have to rebuild the LSD/do you have to on these cars? I am sitting just over 96K miles and I figure it is about that time for an overhaul/go over everything just seeing where I should start. Thanks for the input.
~Matt
CP-E Cold Air Intake
CP-E TIP
Street Unit TP
Turbosmart BPV
HKS Hi-Flo exhaust
Greddy Ti-C Muffler
Autotech FP Internals
BNR Stg. 2 Turbo
Grimmspeed EBCS (3 Port Mode)
Cobb AP
Spec Stg. 3+ Clutch
Street Unit RMM
Custom Tune by boost_creep
Eibach Pro-Kit Springs
Tenzo-R DC 6's
ufboostedgator is offline   Reply With Quote
 Old 12-13-2011, 07:03 AM   #2
Rokusek's Avatar
Posts: 5,551   (View Stats)
Can you make a video with the sound that your hearing? might help us out in determining what the issue might be
 Old 12-13-2011, 07:06 AM   #3
Yes, I definitely can after I get off of work. I rode my motorcycle today so I will have to wait until I get home and go from there. I only question the CV axles because it does not seem to come from any particular side, just clicks in general.
CP-E TIP
Street Unit TP
Turbosmart BPV
HKS Hi-Flo exhaust
Greddy Ti-C Muffler
BNR Stg. 2 Turbo
Cobb AP
Spec Stg. 3+ Clutch
Street Unit RMM
Tenzo-R DC 6's
 Old 12-13-2011, 07:09 AM   #4
Rokusek's Avatar
hmm... yea post a video inside and outside the car if you can
 Old 12-13-2011, 07:13 AM   #5
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
its normal. look through Rodrigos posts, he made a thread on this
2015 Mazda 6
HTML code is On
click on start up.. wut it iz? tddvrrn MazdaSpeed 3/6 - Car Audio & Electronics 3 01-06-2012 06:20 AM
Does your axle click yet??? rodrigo MazdaSpeed 3/6 - Troubleshoot/Diagnostics 32 12-08-2010 06:35 PM
How to make my tranny "click-click" perfect? BolvangaR MazdaSpeed 3 - Engine, Transmission & Driveline 55 04-13-2010 07:48 PM
click, click, click laocas01 MazdaSpeed 6 - Engine, Transmission & Driveline 21 04-20-2009 12:32 AM
Page generated in 0.25359 seconds with 22 queries
