 Old 11-15-2010, 10:21 AM   #1
fermentj's Avatar
Posts: 35   (View Stats)
fermentj is a name known to allfermentj is a name known to allfermentj is a name known to allfermentj is a name known to allfermentj is a name known to allfermentj is a name known to all
Default Climate Control - AC Always on
I searched the forums as best I could, mayhe this was already discussed buts its buried somewhere.
So I bought a 2011 MS3 about a month ago, it has automatic climate control. The day I bought the car it was in the mid 70s and when I pushed the Auto button and set the temperature it turned the AC on and I thought nothing of it.
Well last week in the mornings it was in the upper 30s and still every time i put on the Auto the AC button turned on.
Now I know that's usually the case for the defrosters, but its under any normal condition it does the same thing.
AC steals power from the car so I always find myself manually turning it off.
Does anyone have the same problem? Or know why its happening?
Thanks
fermentj is offline   Reply With Quote
 Old 11-15-2010, 10:25 AM   #2
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Yeah that's the safety feature, what it does is prevent the motor from blowing.
What a lovable bunch we are!!
The Following 4 Users Say Thank You to predapio For This Useful Post:
jracer (11-20-2010), lyonsroar (11-15-2010), Nataphen (11-19-2010), NJSPEED3 (11-19-2010)
 Old 11-15-2010, 10:26 AM   #3
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
super_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the world
what problem? ... yeah, u turn the fans and compressor on... that will "steal" power... thats normal. whats the problem?
super_pablo_ is offline   Reply With Quote
 Old 11-15-2010, 10:29 AM   #4
Speedaway's Avatar
Posts: 1,477   (View Stats)
Speedaway is the leader of the worldSpeedaway is the leader of the worldSpeedaway is the leader of the worldSpeedaway is the leader of the worldSpeedaway is the leader of the worldSpeedaway is the leader of the worldSpeedaway is the leader of the worldSpeedaway is the leader of the worldSpeedaway is the leader of the worldSpeedaway is the leader of the worldSpeedaway is the leader of the world
Groans: 58
You will lose power from a honda v-takkk engine but we got something better then v-takk.
We have Torque and ton's of it.
By the way it's normal, mine is alway's ON but doesn't mean it's running.
Mazdaspeed3 2008.5 black mica.
SRI
- COBB / TIP - COBB / Accessport - COBB / RMM - TRZ / HF cat DP to come
Speedaway is offline   Reply With Quote
 Old 11-15-2010, 10:40 AM   #5
ms3brendan's Avatar
Posts: 1,017   (View Stats)
ms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the world
The AC is on when it's cold to act as a de-humidifier. If you turn the AC off manually, your auto climate control turns off. I don't like having the AC on because it makes my compressor run more which throws my LTFTs off some which bothers me (not that it makes a difference) but, if you prefer to have the auto climate control on, the AC has to be on.. No way around it. It's like this in many other cars as well, in my buddy's 2012 WRX.. it's the same way.
Also, don't know if you've noticed.. but when it's warmer out and you have your AC.. when we go WOT, our cars actually shut off the AC so it doesn't rob you of power. You can notice this when you go WOT with the AC on it'll all of a sudden be blowing not cold air anymore.
2012 BMW 135i //M-Sport
ms3brendan is offline   Reply With Quote
The Following User Says Thank You to ms3brendan For This Useful Post:
jracer (11-20-2010)
 Old 11-15-2010, 10:44 AM   #6
bro2's Avatar
Posts: 384   (View Stats)
bro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the world
When I have the Auto Climate on I can manually shut the AC off and the climate control stays on.
2010 Mica black ms3 ~ cobb AP ~ cp-e nano/ AEM dryflow ~ TRZ rmm ~ 35% tint all around with 15% strip on top ~ 6k hid ~ nokya hyper yellow fogs ~ cp-e towplate
bro2 is offline   Reply With Quote
 Old 11-15-2010, 10:47 AM   #7
predapio's Avatar
Groans: 309
Just take the bus. Problem solved.
The Following 2 Users Say Thank You to predapio For This Useful Post:
 Old 11-15-2010, 11:11 AM   #8
ms3brendan's Avatar
So your auto light stays on and it'll auto-adjust how much it blows? ..mine will maintain the air coming in at whatever temperature I have it set at at all times but when I turn the AC off it won't adjust the level of blowing.
 Old 11-15-2010, 12:12 PM   #9
fermentj's Avatar
Thanks for the replies, I just wanted to make sure I wasn't the only one
I usually turn off the AC manually and then adjust the fan as needed so I guess I'm shutting it off anyway. I can handle the 3 seconds every so often to adjust it.
 Old 11-15-2010, 12:36 PM   #10
RacerX78's Avatar
Posts: 818   (View Stats)
RacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the world
Groaned at 6 Times in 4 Posts
Yea this bugs the crap out of me too. I rarely like to use the AC, but even if its freezing out the compressor comes on.
RacerX78 is offline   Reply With Quote
 Old 11-15-2010, 02:40 PM   #11
HLR Element's Avatar
Posts: 2,477   (View Stats)
HLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the world
Groans: 109
all auto climate controls do that in every car. Just cause the AC light is on doesn't mean it's running.
Mk7 GTI
HLR Element is offline   Reply With Quote
 Old 11-15-2010, 02:44 PM   #12
triplejumper18's Avatar
Posts: 2,569   (View Stats)
triplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the world
Groans: 196
Groaned at 57 Times in 47 Posts
Every time I see a woman in a swimsuit I get a boner. Is this normal?
triplejumper18 is offline   Reply With Quote
The Following 2 Users Say Thank You to triplejumper18 For This Useful Post:
FreeFlyFreak (11-15-2010), jracer (11-20-2010)
 Old 11-15-2010, 05:49 PM   #13
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,155   (View Stats)
Groans: 754
Yes it is normal (your experience may vary depending on age, physical condition and sexual preference) but.................
Just cos you get a boner it doesn't mean you get to fuck the woman in the swimsuit. Capisce (cah-PEESH)
Suspension:
 Old 11-15-2010, 07:02 PM   #14
blacksin's Avatar
Posts: 18   (View Stats)
blacksin is an unknown quantity at this point
Dunno if the MS6 is the same, but I hit the AC button, the "Auto" light goes off, but it still changes the fan speed and direction to try to mantain the set temperature. It still turns the AC on when the defroster is on, however.
blacksin is offline   Reply With Quote
 Old 11-15-2010, 07:07 PM   #15
Speedaway's Avatar
Groans: 58
On my MS3 it turn everything off if i turn the AC off.
SRI
 Old 11-15-2010, 07:22 PM   #16
Team Überfrazn
labikesrcool's Avatar
Posts: 782   (View Stats)
labikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the world
take out the fuse for the winter. when you turn on the defrost your ac is running even though the light isn't on. sneaky.
"My car won't start!"
"Well, maybe there's a killer after you."-Mitch Hedberg
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming.
- Mitch Hedberg
labikesrcool is offline   Reply With Quote
 Old 11-17-2010, 09:17 AM   #17
TegRacer324's Avatar
Posts: 145   (View Stats)
TegRacer324 is just really niceTegRacer324 is just really niceTegRacer324 is just really niceTegRacer324 is just really niceTegRacer324 is just really nice
If you shut the ac off, the auto light goes off but the climate control is still on. Every time you touch a feature it turns that feature off of auto, but does not shut the entire thing down.
TegRacer324 is offline   Reply With Quote
 Old 11-19-2010, 03:49 PM   #18
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
I'm not sure why the hell this is a thread, but on the 2010+ at least, you can turn the AC off and still set the temp to whatever. It will do everything that it can to maintain that temp without the AC.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
 Old 11-19-2010, 09:12 PM   #19
ms3brendan's Avatar
It's true but when the AC is on full auto is on and it'll adjust different modes such as it'll go to defrost at a certain temp opposed to blowing in your face.
 Old 11-19-2010, 09:16 PM   #20
bro2's Avatar
The genpu does this no matter if the AC is on or off...like blowing loads on ur face till u get all hot and sticky, then it dumps on ur feet
 Old 11-19-2010, 10:44 PM   #21
oh10speed3's Avatar
Posts: 1,119   (View Stats)
oh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the world
Groaned at 74 Times in 30 Posts
I never use the air conditioning. If its cold outside, I just bundle up. And if its hot outside, I roll down the windows and drive at blistering speeds.
Sent from my Droid using Tapatalk
//Stage 1 & Done\\
oh10speed3 is offline   Reply With Quote
 Old 11-20-2010, 03:33 AM   #22
SW160's Avatar
Posts: 423   (View Stats)
SW160 is the leader of the worldSW160 is the leader of the worldSW160 is the leader of the worldSW160 is the leader of the worldSW160 is the leader of the worldSW160 is the leader of the worldSW160 is the leader of the worldSW160 is the leader of the worldSW160 is the leader of the worldSW160 is the leader of the worldSW160 is the leader of the world
Just wire this to your fuze box and mount on your dash, problem fixed.
SW160 is offline   Reply With Quote
 Old 11-21-2010, 07:15 AM   #23
Dizzel's Avatar
Posts: 168   (View Stats)
Dizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond repute
According to an article I read in Motor Trend about a year ago the A/C comes on to keep the seals lubricated in the compressor. This stops them from going bad during parts of the year when the A/C is not used. If they dry out and crack you bleed out all your freon. It also helps dehumidify the air as previously stated. Nothing is broken.
Dizzel is offline   Reply With Quote
 Old 11-25-2010, 10:53 AM   #24
smakdown61's Avatar
Posts: 1,069   (View Stats)
smakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the world
Groaned at 37 Times in 23 Posts
Some of you guys need to read the manual for your cars. It clearly states that when you have the auto climate activated, and manually adjust something (whether it be fan speed, temp, etc...) everything else STILL stays in auto except what you just adjusted manually.
smakdown61 is offline   Reply With Quote
 Old 11-25-2010, 11:21 AM   #25
GoBackToSleep's Avatar
Posts: 870   (View Stats)
GoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the world
Groaned at 16 Times in 3 Posts
This is normal. I wondered about it myself when I first got this car (my first car with automatic climate control) but I learned it happens on all these systems anyway.
- Matt
2012 Mazda 3i Touring hatch 6MT in graphite mica (current)
2008 Mazdaspeed 3 Sport CBM (traded)
GoBackToSleep is offline   Reply With Quote
HTML code is On
Visteon expands climate control operations in China Haltech Automotive News 0 06-22-2010 09:10 PM
Wastegate control, Boost spikes, PID control FreeFlyFreak
Cobb ATR Support
83 11-05-2009 11:40 AM
Automatic Climate Control Question needforspeed6 MazdaSpeed 6 - Engine, Transmission & Driveline 8 10-18-2009 01:23 PM
GOP: climate bills to make $4 gas look cheap Haltech Automotive News 0 06-19-2008 09:00 AM
Page generated in 0.44140 seconds with 39 queries
