 Old 08-09-2019, 03:24 PM   #1
Ktmms6's Avatar
Posts: 1   (View Stats)
Ktmms6 is an unknown quantity at this point
Default Clutch not right
I was taking off from a hill the other day and when I was getting going my clutch took a change in the feeling of the pedal. I noticed but it still shifted so I drove it for about 3 minutes until I hit a stop sign and put it in neutral and I could not get it back into gear. I killed it and started it in first and limped it home. I instantly thought slave cylinder and put it in and bled the hell out of it just to find it is still the same. I did research and I have somewhat narrowed it down to a finger in the pressure plate jammed or a throw out bearing. I have checked the travel of the fork and it is right, and it does not bleed off when you hold it (at least not in a minute). Was wanting to know anyone else’s opinion or if it has happened to them before I tear it apart.
Ktmms6 is offline   Reply With Quote
 Old 08-09-2019, 03:51 PM   #2
Db09ms3's Avatar
Posts: 427   (View Stats)
Db09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the world
Groans: 88
Pull the red rubber boot back on the slave cylinder, have someone press clutch, does it leak?
Stockish
HTML code is On
Oem clutch/Fidanza Flywheel, Causing sticky clutch pedal? Douggievee MazdaSpeed 6 - Engine, Transmission & Driveline 14 05-14-2015 09:44 AM
Clutch Masters Twin Disc Clutch Kit now Available at EdgeAutosport! EdgeAutosport.com EdgeAutosport.com 67 03-17-2015 02:39 PM
New OEM Clutch with Fidanza Flywheel Soft Clutch Feel zer010gic MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-15-2014 10:12 PM
Clutch disc snapped - new CM clutch experience Absolut1l MazdaSpeed 6 - Engine, Transmission & Driveline 4 05-08-2013 04:07 AM
Will a DIY clutch adjustment help a slipping clutch? Greekfreak MazdaSpeed 6 - Engine, Transmission & Driveline 1 09-20-2012 04:53 PM
Page generated in 0.40131 seconds with 21 queries
