 Old 03-13-2019, 10:56 PM   #1
th3_heis3nberg's Avatar
Posts: 7   (View Stats)
th3_heis3nberg is an unknown quantity at this point
Default codes p2188 and p0234 please help
so today while driving my car it was running a bit sluggish and when i went into boost it would just die off. after awhile the check engine light came on saying i had overboost issues and fuel was running too rich at idle. the car is pretty much stock besides a tmm and a cobb cai. the car sits at 105k can anyone please tell me whats going on? i can provide more info if someones willing to help.
th3_heis3nberg is offline   Reply With Quote
 Old 03-14-2019, 06:27 AM   #2
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,942   (View Stats)
Groans: 541
could be a ton of things... losing air after its metered, bad maf, bad injector. the cheapest thing to do is clean your maf and check all hoses.
94 M
06 MS6
 Old 03-16-2019, 11:22 AM   #3
I figured out what the problem was when i put in my auto tech HPFP internals. The HPFP itself somehow cleared the rich idle code. Could have been some unsecure fittings or hoses but whatever it was it did the job! I also found that my TIH was very loose and after the install I had no codes about overbooost!
 Old 03-16-2019, 11:33 AM   #4
Police - Grammarhead
Vansquish's Avatar
Groans: 1,854
You have an aftermarket intake and exhaust on the car. The car breathes better than it would have when it was stock.
The tune you are currently using is hitting a boost and/or load limit and cutting power because of the lowered restriction in your intake and exhaust systems. You need a tune that accounts for the increased air and exhaust flow volumes.
HTML code is On
p0300 and p0234 after exhaust? cocoleveo7686 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 11-24-2014 12:28 PM
my friends car caught two codes code p2006&p2188 impact-blue MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 11-04-2013 06:22 PM
P0234 advice? Swinger13 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 10-21-2012 08:25 PM
P0234 Overboost nybe0010 2010 MS3 - Troubleshoot/Diagnostics 5 10-10-2012 08:00 AM
Page generated in 0.25572 seconds with 22 queries
