Notices
 Old 08-11-2012, 06:39 PM   #1
csrt/ms3 owner's Avatar
Posts: 16   (View Stats)
csrt/ms3 owner will become famous soon enough
Default crazy problems need advice...
Today on the way to work my air conditioner stopped working and makes a really loud roar then on my way home from work my 3 windows passenger and 2 rear windows went down fine and now will not go.back up.. wtf is going on???
csrt/ms3 owner is offline   Reply With Quote
 Old 08-11-2012, 06:52 PM   #2
skeeter149's Avatar
Posts: 3,601   (View Stats)
Groans: 85
Groaned at 22 Times in 17 Posts
bump for some help, sorry i have no ideas
"Go find your own enterprise, and get the fuck off my bridge!"
2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP, TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals. "Garaged Indefinately", (Got My Perm On)
1996 200sx SE-R- Injen CAI, GReddy SP2 CBE, Progress FSB, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "The Daily"
skeeter149 is offline   Reply With Quote
 Old 08-11-2012, 06:54 PM   #3
greenespeed's Avatar
Posts: 1,313   (View Stats)
greenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the world
Groaned at 6 Times in 3 Posts
No idea, but it sounds electrical to me, the windows anyway. The AC doesn't sound related. Have you checked all your fuses in both panels and checked the relays under the hood?
2006 Mazdaspeed6 BCM GT
MODS : Cobb AP // Cobb SF // Sure TIP // JBR RMM // JBR SSB // JBR SSP // Magnaflow CBE // MSR 045 18 X 8 +35 // ACT ZX5-HDG6 // M2 3" catless DP // AT HPFP Internals // NGK's -- FREEKTUNE in progress
Having a 12 second Honda is just like coming out of the closet; You're going to surprise a bunch of people, but in the end you're still gay.
greenespeed is offline   Reply With Quote
 Old 08-11-2012, 07:30 PM   #4
No. They went up a lil while ago like nothing was wrong. I will though.
 Old 08-11-2012, 07:35 PM   #5
Leads me to believe that the AC is seperate issue from the windows. When the window wouldn't go up did you try each window from it's own switch or just from the driver's? If just from the driver's side I would check to be sure the switches are all connected good at the driver's door.
Have you done any work to the car recently?
The Following User Says Thank You to greenespeed For This Useful Post:
Tokay444 (08-11-2012)
 Old 08-12-2012, 06:37 AM   #6
meicalnissyen's Avatar
Posts: 247   (View Stats)
meicalnissyen has a reputation beyond reputemeicalnissyen has a reputation beyond reputemeicalnissyen has a reputation beyond reputemeicalnissyen has a reputation beyond reputemeicalnissyen has a reputation beyond reputemeicalnissyen has a reputation beyond reputemeicalnissyen has a reputation beyond reputemeicalnissyen has a reputation beyond reputemeicalnissyen has a reputation beyond reputemeicalnissyen has a reputation beyond reputemeicalnissyen has a reputation beyond repute
the AC, i have no idea
the windows? haha
I just did the same weetawd move
push the window button on the drivers armrest, they will magically start working again
A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch
meicalnissyen is offline   Reply With Quote
 Old 08-12-2012, 10:11 AM   #7
Only from drivers side switch. Only work done was reaplacing stock low beams with oem hid bulbs.
HTML code is On
ECU gone crazy dalmau03 MazdaSpeed 3/6 - ECU Computer Tuning 4 07-22-2012 02:53 PM
Think I am going crazy rawazchico Gen2 MS3 General Discussion 45 06-04-2012 04:31 PM
speed 3 problems need advice and help reconbygod12 MazdaSpeed 3 - Engine, Transmission & Driveline 26 09-16-2011 02:52 AM
Not Crazy chrismia MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 11-12-2010 07:14 PM
Page generated in 0.88652 seconds with 23 queries
