 Old 09-18-2008, 02:39 PM   #1
bombdotcom's Avatar
Posts: 816   (View Stats)
bombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the world
Groaned at 40 Times in 20 Posts
Default engine compression?
whats the deal with it? i wanna build my engine soon and i have no idea what all the numbers mean and so on?....
(RIP) 08' MS3---MODS:COBB AP- COBB SRI AND TIP- COBB RSB- COBB KNOB- CP-E TMIC- LIMITED EDITION HKS BOV- CORKSPORT DP AND TP- TRZ REARMOUNT- MD OCC- PTP IM COOLER KIT- COSWORTH BSD- EIBACH PROKIT- TWM SHIFTER BUSHINGS- JBR SHORT SHIFT KIT-
13' CWP MS3
bombdotcom is offline   Reply With Quote
 Old 09-18-2008, 02:52 PM   #2
Jackal
Breakdown81's Avatar
Posts: 869   (View Stats)
Breakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the world
Groans: 56
general rule of thumb for compression ratios:
for turbo cars lower compression is better, it allows you to feed more boost.
high compression is bad.
suggest you get a copy of corky bells books, specifically maximum boost. also start searching around this forum on the turbo induction section and the engine sections, get knowledgeable then build with confidence.
Breakdown81 is offline   Reply With Quote
 Old 09-18-2008, 04:18 PM   #3
bombdotcom's Avatar
ya i needa pick up a book. can i get it at barnes and nobles?
13' CWP MS3
 Old 09-18-2008, 05:10 PM   #4
MTuning's Avatar
Posts: 362   (View Stats)
MTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond repute
Groaned at 16 Times in 8 Posts
lower compression allow more of a safety factor to prevent detonation, in relation to timing.
MTuning is offline   Reply With Quote
 Old 09-18-2008, 08:59 PM   #5
MSF Punished Member
FWD=WWD's Avatar
Posts: 200   (View Stats)
FWD=WWD is a name known to allFWD=WWD is a name known to allFWD=WWD is a name known to allFWD=WWD is a name known to allFWD=WWD is a name known to allFWD=WWD is a name known to all
high compression isnt always bad. its good in N/A cars because it alows more power due to the higher compression in the cylinders pushing back on the pistions and rids harder...
But in turbo setups, thats the turbo's job... to ram the air into the cylinder to do the same thing... if they both did it, it would be too much and every thing just goes kaboom. lol.
Turbo = Low compression ... usually around 8.5:1 is a general lowest.. besides the extremists.
N/A = tough call... ive seen as high as 14:1 in big block v8's... maybe 12:1 in hondas.. and my bimmer was 11.5:1...
FWD=WWD is offline   Reply With Quote
The Following User Says Thank You to FWD=WWD For This Useful Post:
Breakdown81 (09-23-2008)
 Old 09-19-2008, 06:56 AM   #6
Ziggo's Avatar
Posts: 3,843   (View Stats)
14:1 is generally the limit. 600cc Sportbike engines will tend to 15:1, but they are very oversquare and run such high rpms that knock really dosn't have time to develop.
 Old 09-19-2008, 07:02 AM   #7
Awddsm97's Avatar
Posts: 37   (View Stats)
Awddsm97 is a glorious beacon of lightAwddsm97 is a glorious beacon of lightAwddsm97 is a glorious beacon of lightAwddsm97 is a glorious beacon of lightAwddsm97 is a glorious beacon of light
In turbo applications I've run everything from 8:1 to 10:1 compression. Lower compression will allow for more boost on pump gas. Higher compression will put you closer to the limit at a lower boost level. However in a race motor application high compression and big boost make big power. For street cars I usually stay under 9:1.
Awddsm97 is offline   Reply With Quote
 Old 09-19-2008, 08:41 AM   #8
mexicant's Avatar
Posts: 867   (View Stats)
mexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the world
Groans: 147
Groaned at 34 Times in 29 Posts
If you go with a lower compression, your bottom end power and spoolup time will suffer. My DSM has a 7.8:1 compression ratio, the big upgrade is to use the 8.5:1 compression ratio pistons, it makes a world of a difference in spooltime and initial "hit" of boost.
"08, I hate to break it to you, but if it gives kevin a boner, its porn"
NATOR PERFORMANCE
Nylon washer sponsered
mexicant is offline   Reply With Quote
 Old 09-19-2008, 09:53 AM   #9
phailerider's Avatar
Posts: 4,639   (View Stats)
phailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the world
Groans: 49
Groaned at 179 Times in 125 Posts
all the big vag turbo builds kept stock compression with their setups... that was enough for me to keep the stock 9.5:1 compression in place on my build. If our motors werent DI, i may have dropped it, but for a di motor, we felt that we would have lost too much of the advantage of the motor to go lower.
maybe were wrong... but im excited to see 24 psi, with a gt30 on 9.5:1. Quick spool big power, and meth to cool it.
phailerider is offline   Reply With Quote
The Following User Says Thank You to phailerider For This Useful Post:
 Old 09-20-2008, 02:58 AM   #10
Demi's Avatar
Posts: 1,107   (View Stats)
Demi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the world
Groans: 61
Groaned at 16 Times in 11 Posts
Ken and I were talking about this. My thinking is that were are gonna see higher numbers with lower compression on this car, Randy had his reasons for his compression choices and is having great success with it. Once we get the fuel figured out a little better I think we are gonna hit another wall that only lower compression or higher octane fuel will take care of.
Beginners guide to turbos<- New to this? Give it a look!
-And for the rest of you, if it comes from Autozone and doesnt replace something that broke off your car or make your cabin smell like Coco Butter, its fucking rice.
Demi is offline   Reply With Quote
 Old 09-22-2008, 02:54 PM   #11
bombdotcom's Avatar
so what exactly do the numbers mean? air to fuel?
13' CWP MS3
 Old 09-22-2008, 07:32 PM   #12
Demi's Avatar
Groans: 61
Air to fuel ratios represent the mixture of air and fuel in the combustion chamber. I believe 14.7 is quote unquote "perfect" or stoichiometric mix. This is in reference to the amount of air to fuel. So 14.7 is 14.7 parts air to 1 part fuel. The lower the number the richer (more fuel) the mix is. The higher the number the leaner it is (more air). Most of the danger lies in too lean a mixture, but it should be noted that extremely rich can be dangerous to an engine as well.
But thats not what these guys are talking about. The compression ratio represents the amount the piston stroke and bore will compress the air fuel mixture. The higher number (in this case 9.5) is when the pistion is bottom dead center. When the piston drives to top dead center it compresses the 9.5 to 1. As in 9.5:1. So some thing like 10:1 would be more compression and 8.5:1 would be lower. Higher compression can lead to higher horse power numbers in properly outfitted engines (naturally aspirated cars do well with it). But lower compression setups lend themselves to larger amounts of forced induction. Typically lower compression produces less heat and there for less chance for detonation.
This is the simple explanation. Here are some good links that explain it better than i can.
HowStuffWorks "Producing More Engine Power"
HowStuffWorks "Diesel Engines vs. Gasoline Engines"
HowStuffWorks "How Gasoline Works"
HowStuffWorks "Other Horsepower Increasing Methods"
The Following User Says Thank You to Demi For This Useful Post:
 Old 09-23-2008, 03:06 AM   #13
bombdotcom's Avatar
thanks alot
13' CWP MS3
HTML code is On
Pulsar Spark Plug Replacement, Pinging Engine, Jeep Liberty Engine Stalls, Windows Are Stuck, Blower Motor Runs On Low O Haltech Automotive News 1 04-13-2012 08:13 PM
Pulsar Spark Plug Replacement, Pinging Engine, Jeep Liberty Engine Stalls, Windows Are Stuck, Blower Motor Runs On Low O Haltech Automotive News 0 07-10-2008 10:10 AM
So, anything out there you'd like to strap a jet engine to? Haltech Automotive News 0 05-19-2008 07:40 AM
So, anything out there you'd like to strap a jet engine to? Haltech Automotive News 0 05-17-2008 09:17 AM
Page generated in 0.32396 seconds with 28 queries
