-   Mazdaspeed3/6 General Discussion (http://www.mazdaspeedforums.org/forum/f505/)
-   -   Engine light came on and went off a couple of hrs later. What gives? (http://www.mazdaspeedforums.org/forum/f505/engine-light-came-went-off-couple-hrs-196760/)
Roman-dude 12-20-2015 07:30 PM
Thx
Sent from my SAMSUNG-SM-G900A using Tapatalk
MS3
MS3Shadow 12-20-2015 08:21 PM
Whoa, that's a whole of information you've provided us....
sent from my Nexus 6P
sheston 12-20-2015 08:25 PM
^^ You can't figure it out from that?
You probably have some issue that is borderline, and posts then clears a code
Code Monkey 12-20-2015 08:27 PM
Cool story bro.
Roman-dude 12-20-2015 08:32 PM
Yeah, I know. There isn't more to it at this point lol. I'll drop by the shop at some point to have this looked at.
frothy 12-20-2015 08:37 PM
Have you scanned the car for fault codes? Do that. Not much anyone can help you with until that's done.
If there are no fault codes stored, there's no point in taking the car to a shop either. No fault code, no problem to troubleshoot/solve.
Roman-dude 12-20-2015 08:40 PM
Yeah, that's pretty much the plan. Don't have a scanner, so I'll have the shop do that.
frothy 12-20-2015 08:46 PM
Go to Autozone, they'll scan for free.
Or buy a OBD2/bluetooth adapter (if you have an Android based phone) and download the Torque app and scan the car yourself.
A shop will likely charge you.
Roman-dude 12-20-2015 08:48 PM
Thanks. They charge very little for that, but I might just follow your advice.
Balthazar 12-20-2015 08:49 PM
Like frothy said,
You need an elm327 Bluetooth adapter from eBay
Then you'll be ready next time.
Jkspeed 12-21-2015 08:44 AM
Could be anything, but my best guess would be it's for a blocked EGR.
Get a code reader so you can be sure this is the case. Mine used to go on for a blocked EGR, so I would delete the trouble code. Usually a month later it would go back on, and turn itself off before I could get home and check. Then I just removed all that nonsense and have been trouble free since :).
mituc 12-21-2015 08:49 AM
Read the error code with some ELM, dashdaq, dashawk, or a tuner device (versatuner, cobb ap) and post it. Once you do that we may start guessing, but otherwise our telepathic abilities resume to knowing only sex related happenings about various persons.
Say Chi Sin Lo 12-21-2015 10:09 AM
Had a code for EGR something, asked the dealer how much it'll be to fix it, they said an arm and a leg. But on that route of honestly, they also said it wouldn't affect the car (right?).
Anyways, I cleared the code and it hasn't come back since.
Roman-dude 12-30-2015 09:33 AM
P2271 running too lean.
Roman-dude 12-30-2015 09:44 AM
Although when I Google the code it comes up with "o2 sensor signal biased / stuck rich bank 1 sensor 2"
sheston 12-30-2015 06:38 PM
Still hard to help you much. Can't see what if anything has been done to your car.
I would go with a leak. Something has come loose, or a gasket is leaking.... Check all your tube connections
Roman-dude 12-30-2015 08:09 PM
Thanks. The only thing the car had is a cai.
Has
Jkspeed 03-02-2016 10:15 AM
Well first off, I would just do it yourself...
and yea, shouldn't be an issue other than a nuisance.
Page generated in 0.18230 seconds with 11 queries
