![]() | | #1 | ![]() |
![]() Join Date: Nov 2008 Location: Tucson, AZ
Rep Power: 4205 ![]() Thanks: 4,085
Groans: 103
Groaned at 21 Times in 19 Posts
(Thread Starter) | Not Ranked : 0 score This is where you (the reader) come into play; continued harassment will result in me eventually finishing this thing, which subsequently will mean no more manual MAF calibrations will be required on your part. Here's a screenshot of the pretty near finished UI; I will likely replace the "enki" picture with more options down the road, but a simple setup will suffice for now. ![]() For those that give a shit, I had gotten pretty far with the script only version, but found it to be infeasible to collate and average all the data from even a small log file using only scripting. Thus, the switch to C#, which I am pretty positive will ultimately prove successful. Feel free to use this thread to suggest features, report bugs (when I start doing betas), ask questions, or post power ballads about well hung llamas. REQUESTED FEATURES: Easier initial scaling for big MAF housings Allow for all closed or open loop operation without app shitting itself in endless loops NOW RUNNING TRIALS! I will be taking a COUPLE of samples from people (that can/will do a manual MAFCAL themselves) whom post in this thread the following information (within CODE tags; keep the tabs in there or my lazy ass will skip you): 1. Current MAF calibration 2. Current WOT AFR targets 3. Accelerator pedal open loop transition 4. Load open loop transition 5. Rev limit 6. The log file 7. Your manually created MAF calibration (for me to compare) Note that the log file needs at least the following columns within it or it will not work at all (extra data doesn't matter, but fewer extra columns results in better data resolution and thus, higher accuracy): Accel. Pedal Pos. (%) Actual AFR (AFR) Boost (PSI) Calculated Load (Load) Long Term FT (%) MAF Voltage (V) RPM (RPM) Short Term FT (%) Wastegate Duty (%) Order of these columns within the log file does not matter. Also, please have everything in one post so I can go back to it later for further testing.
__________________ ![]() Last edited by Enki; 05-08-2012 at 07:31 PM. |
| The Following 106 Users Say Thank You to Enki For This Useful Post: | 06Speed6 (04-19-2012), 2k4_8 (04-19-2012), 86azms3 (04-18-2012), Adam is so pro (05-09-2012), alphasaur (04-19-2012), Angr-E1 (04-20-2012), Awesomesauce (05-04-2012), AZSPEED3 (04-20-2012), backward_0 (06-09-2012), BigRedSpecial (04-19-2012), BlckMS3 (04-18-2012), BlueStreak (04-19-2012), Boosten Ya(josh) (05-04-2012), Boost_creep (04-20-2012), breakfasteatre (05-08-2012), breakfstincluded (06-17-2012), BrianB6 (04-19-2012), Broxer (04-20-2012), burn813 (08-01-2012), captain slow (04-19-2012), charlesfist (04-19-2012), Coaststarlight (04-27-2012), CosmicArkie (04-20-2012), cshunter (08-01-2012), Dano (06-17-2012), Death-From-A-Mile (04-18-2012), dereeek (04-18-2012), djuosnteisn (04-20-2012), dpolseno41 (04-18-2012), drknyte (05-05-2012), DuBz (08-01-2012), E.Tinker (04-19-2012), Easter Bunny (04-19-2012), EdgeAutosport.com (04-19-2012), Eric28243 (04-23-2012), Fobio (04-20-2012), forcedinduktion (04-18-2012), franz (04-19-2012), fywdyl (04-20-2012), G26 (04-20-2012), Harvey PU (04-21-2012), helmetface (04-19-2012), i8urgti (05-08-2012), IshiKage (04-19-2012), JacksonMS30 (04-27-2012), jack_hammer (04-23-2012), Jake_MS3 (04-19-2012), JmkC (06-17-2012), josurr (04-18-2012), jtt (04-18-2012), kgb (04-19-2012), kngeducate (04-19-2012), kunfu (04-22-2012), leon78 (04-18-2012), Lex (04-18-2012), magicka (04-20-2012), Magic_AoD (04-21-2012), MattJackson86 (04-18-2012), Meder (04-19-2012), meicalnissyen (04-26-2012), melly mel (04-19-2012), Micha (06-26-2012), Mizzle (04-20-2012), Monotonous ONE (04-19-2012), mrdouble99 (04-19-2012), mrmonk7663 (04-19-2012), MS3-a(sore)ASS-rex (04-19-2012), MS3inDC (04-26-2012), Ms3_Miami (04-20-2012), mzr0818 (04-19-2012), NCZ13 (05-07-2012), nighthawk358 (04-23-2012), nindoja (04-20-2012), Oliverms3 (04-19-2012), phate (04-19-2012), Pointless (04-19-2012), Pseud0logik (04-18-2012), Pu Manchu (04-20-2012), radioflyer (04-23-2012), RayRay (04-27-2012), Realgib3 (04-18-2012), rfinkle2 (04-19-2012), rigor (04-23-2012), ryno077 (04-22-2012), ScarMS3 (04-27-2012), shawn. (05-04-2012), SilverDemon (04-19-2012), SLOWHATCH (04-30-2012), smoogs12 (04-26-2012), SoAgg159 (04-19-2012), socks (04-20-2012), SpeedSixxx (04-19-2012), Spirry (04-21-2012), superskaterxes (04-23-2012), Takinato (06-11-2012), TexasSpeed3 (04-19-2012), themytb (04-18-2012), Todd98SE (08-28-2012), Tokay444 (04-20-2012), TWOptSL0W (04-19-2012), uncorked11 (04-21-2012), urbansurfer (07-15-2012), vdgmcool (05-14-2012), warlord (04-19-2012), xb2ms3 (04-22-2012), Zbrit00x (05-05-2012) |
| Engineered Tuning ![]() ![]() ![]() Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 8351 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,236
Excellent! This will be a nice little app.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following User Says Thank You to Lex For This Useful Post: | Enki (04-18-2012) |
![]() Join Date: Nov 2010 Location: rockledge fl
Rep Power: 625 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,688
Groaned at 8 Times in 5 Posts
ive been comtemplating trying to code something like this since i started visual basic class, we just havent learned how to process large amounts of data like that yet lol
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() |
![]() | | #4 | ![]() |
Groans: 103
Well in order to do it accurately (which is kind of a given) you need to go by .01 volts on the MAF scale; this means interpolating a FUCKLOAD of data if your dataset is small, or estimating (which is what generally is done on manual MAFCals). What I was about to do in script is create a 500 row by 4 column table for the end result data...This didn't include the datasets where I take each individual .01 volt increment worth of data from the log and average it, remove outliers, classify as OL/CL, etc before dumping it into the table proper. Basically, I gave up on the scripted portion after running through a simulated processing path in my head and figuring out that my computer would shit ram all over the place and bring a single thread to its knees trying to get through even a smallish log. At least this way, I can use linq or at worst load the log into an (embedded) SQL backend for query rather than having to pre-sort before manipulation. TLDR: Old code would result in this: ![]() Also, I am a huge nerd.
__________________ ![]() |
| The Following 8 Users Say Thank You to Enki For This Useful Post: | Easter Bunny (04-19-2012), IshiKage (04-19-2012), Micha (06-26-2012), phate (04-19-2012), rfinkle2 (04-19-2012), SpeedSixxx (04-19-2012), TexasSpeed3 (04-19-2012), uncorked11 (04-21-2012) |
![]() | | #5 | ![]() |
![]() Join Date: Feb 2009 Location: gilbert, az
Rep Power: 1864 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,852
Groans: 237
Groaned at 70 Times in 36 Posts
Sounds homo James
__________________ 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, hallman pro rx bc, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Turbosmart Hybrid bpv, SURE TIG's + coolant bypass, ITV24's, CP-E 75d RMM, Medefail Tranny mount, DDM 35W 6000K HID's, SURE Counterweight, 18x8 245/40 NT-05's up front, R: 225/45 Sport Maxx TT's 390whp/400wtq |
| The Following User Says Thank You to 86azms3 For This Useful Post: | Tomas (04-26-2012) |
![]() | | #6 | ![]() |
![]() Join Date: Dec 2008 Location: Los Angeles, CA
Rep Power: 403 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
Let me know if you need any help on this. Probably don't have the time to code it, but questions or if you need a 2nd set of eyes to look it over. I was looking to work on something like this (and other auto tune stuff) with me standback software I wrote.
__________________ Cobb AP - CP-E Xcel Nano - CP-E Turbo Inlet - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Grimmspeed EBCS - ITV22 at .025 - 3 Bar MAP ![]() Torque for Mazdaspeed on Android Market! Gen2 now supported! Mazdaspeed MAP Harness - Bitwise Motorsports http://www.bitwise-motorsports.com |
| The Following User Says Thank You to MattJackson86 For This Useful Post: | Enki (04-18-2012) |
![]() | | #7 | ![]() |
Groans: 103
(Thread Starter) | Not Ranked : 0 score Eat a bowl of dicks Corey
MAF Values ([0-9]+\.[0-9][0-9][\t]){128,}?[0-9]+[\.][0-9][0-9] WOT AFR Values ([0-9][0-9]\.[0-9][0-9][0-9][\t]){13,}?[0-9][0-9][\.][0-9][0-9][0-9]
__________________ ![]() Last edited by Enki; 04-18-2012 at 11:01 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 4 Users Say Thank You to Enki For This Useful Post: |
![]() | | #8 | ![]() |
This helps me with RegEx: Regex Tester Online
![]() | | #9 | ![]() |
Groans: 103
Already checked my regex; tis good.
| The Following User Says Thank You to Enki For This Useful Post: | phate (04-19-2012) |
![]() | | #10 | ![]() |
| indiscretion ![]() Join Date: Feb 2012 Location: Quantico, VA
Rep Power: 1169 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,489
Groaned at 22 Times in 15 Posts
__________________ ![]() 2013 Scion FR-S (Whiteout) White 17x9 Rota Grids w/ 245's_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP. |
| The Following User Says Thank You to leon78 For This Useful Post: | Enki (04-18-2012) |
![]() | | #11 | ![]() |
Rep Power: 6707 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,342
This is going to be so nice, the one thing that I am starting to really hate is doing maf cals, its never perfect and it takes hours to even get it close.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant |
![]() | | #12 | ![]() |
| DoucheMongerTool ![]() Join Date: Sep 2011 Location: St. Johns, Canada
Rep Power: 388 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 879
Groans: 43
I had no idea something like this was even possible... Now what excuse will I have to randomly go out and burn half a tank of gas?
__________________ 2008.5 CWP: Corksport SRI/TIP//AP//ETS TMIC//Autotechs//NGK LTR7s//TIGs//EGR delete//JBR stg2 OCC//JBR 88a RMM/70a TMM/PMM//JBR SSP/SSB/knob//Eibach Pro Kit//Koni Yellows//JBR RSB//Mazdaspeed Camber Links//RX8's/NT05s//MZ3 GT 17s/Blizzak WS60s//Dashdaq Awaiting Install: ATP GTX 3071//Rapebuilt Manifold//JBR WP//TurboXS DP/RP//DO Stage 2 Needed: Driver mod |
![]() | | #13 | ![]() |
![]() Join Date: Aug 2009 Location: Trevose, PA
Rep Power: 6716 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,264
Groans: 193
Groaned at 75 Times in 63 Posts
I think you should change the picture with "ENKI" in it to o e of T-Pain...he is the king of autotune after all. In all seriousness though, this will be fucking amazing if you can get it to work.
__________________ MS3 has officially been retired to daily duty Project 1G is officially under way; 1991 Eagle Talon TSi. Stock Turbo & Stock Motor Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA |
![]() | | #14 | ![]() |
Groans: 103
![]() As for it working, it will; at some point anyways. My biggest hurdle right now is knowledge, but I'm already up to 200 lines of UI validation and content conformance (making sure people are passing the right data to the app). I probably need to make the regex a bit more strict, and plan ahead for larger MAF housings though. As a side note, I already plan on adding wastegate integration in the future (making hitting those boost targets super easy); that will probably only be for WOT though, as running the entire table will be a pain in the ass.
__________________ ![]() | |||
![]() | | #15 | ![]() |
Groans: 43
__________________ 2008.5 CWP: Corksport SRI/TIP//AP//ETS TMIC//Autotechs//NGK LTR7s//TIGs//EGR delete//JBR stg2 OCC//JBR 88a RMM/70a TMM/PMM//JBR SSP/SSB/knob//Eibach Pro Kit//Koni Yellows//JBR RSB//Mazdaspeed Camber Links//RX8's/NT05s//MZ3 GT 17s/Blizzak WS60s//Dashdaq Awaiting Install: ATP GTX 3071//Rapebuilt Manifold//JBR WP//TurboXS DP/RP//DO Stage 2 Needed: Driver mod | |
| The Following User Says Thank You to BigRedSpecial For This Useful Post: | Enki (04-19-2012) |
![]() | | #16 | ![]() |
Groans: 103
You could still tell her you're going out to get logs for tuning/calibrating. That part still hasn't changed.
| The Following User Says Thank You to Enki For This Useful Post: | BigRedSpecial (04-19-2012) |
![]() | | #17 | ![]() |
Be careful with delays if you're using STFTs or even AFRs since during throttle transitions these can really vary. I would look for steady state throttle, then look at LTFTs, and then STFTs as well. I would average STFTs (just like the car does) in broken up regions of the MAF curve that is more granular than what the current LTFTs do.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Lex; 04-19-2012 at 10:24 AM. |
| The Following 6 Users Say Thank You to Lex For This Useful Post: | 06Speed6 (04-19-2012), Bucker (04-19-2012), charlesfist (04-19-2012), Enki (04-19-2012), phate (04-19-2012), TexasSpeed3 (04-19-2012) |
![]() | | #18 | ![]() |
Groans: 103
Well the plan is to average all but outlier data (stuff that exceeds a certain threshold of difference from the meat of the data) and use 100% of the LTFT but only 50% of STFT data (for now; thanks phate for this idea!). I figure, if you want it more accurate, you can simply pull another log and run it back through again. The whole averaging thing means the larger and more diverse the raw log file is, the more accurate this will become; doing the short little logs isn't going to cut it as there won't be enough intelligence in the code to discern situational changes like throttle lift or roll on, etc. BTW, still making progress; currently loading logs into datatables for parsing!
| The Following 15 Users Say Thank You to Enki For This Useful Post: | 06Speed6 (04-19-2012), Awesomesauce (05-04-2012), AZSPEED3 (04-20-2012), BigRedSpecial (04-19-2012), CosmicArkie (04-20-2012), dereeek (04-21-2012), Easter Bunny (04-19-2012), jack_hammer (04-26-2012), MS3-a(sore)ASS-rex (04-19-2012), phate (04-19-2012), Realgib3 (04-19-2012), rfinkle2 (04-19-2012), rigor (04-23-2012), Spirry (04-21-2012), TexasSpeed3 (04-19-2012) |
![]() | | #19 | ![]() |
Rep Power: 11895 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42,819
Groans: 235
Wow Enki. To learn C++ just to bring this out is a feat all in itself. Thanks very much for this. Arguably the most important part of the tune is being addressed with much less chance of error. This is something that I will definitely use. Thanks very much. Lots of effort.
| The Following 3 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() | | #20 | ![]() |
| Eth Fiend ![]() Join Date: May 2010 Location: Murhpysboro, Illinois
Rep Power: 6792 ![]() Thanks: 10,658
Subbed. The CL/OL transition range is always the trickiest part. You might want to incorporate some limit as to how much change between adjacent cells can occur. [I believe the derivative of the maf curve is almost linear, so you might just be able to assume this and limit it with a single value.] IF someone has a leak, you get very bumpy maf curves if you tune around it. That should NOT be done, and the curve should always stay pretty dang smooth. If the calculated correction in one area falls outside of the norm, red flags and whistles should go off, because their setup needs inspected. I foresee this tool being used (unknowingly) by folks to tune around things that should not be tuned around. Edit: start praying to the gods of internal combustion for automatically calibrating a maf curve while spraying meth.
__________________ -06 MS6 - Tuning the high compression forged mill -Corn fed 07 MS3 - Sold |
| The Following 10 Users Say Thank You to phate For This Useful Post: | 06Speed6 (04-19-2012), Broxer (04-20-2012), Bucker (04-19-2012), CosmicArkie (04-20-2012), Enki (04-19-2012), MS3-a(sore)ASS-rex (04-19-2012), rfinkle2 (04-19-2012), SLOWHATCH (04-30-2012), TexasSpeed3 (04-19-2012), uncorked11 (04-21-2012) |
![]() | | #21 | ![]() |
![]() Join Date: Dec 2009 Location: Flagler Beach, Florida
Rep Power: 1141 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,655
Subbed for future reference. Thanks for all the hard work and time we all know you're spending!
__________________ 2009 Mazdaspeed 3 /// COBB AccessPORT Stage2 /// COBB Tuning SF Intake /// Ultimate Racing Test Pipe /// Autotech HPFP Internals /// Turbosmart Dual-Port BPV /// Denso ITV22's /// Corksport Boost Tubes /// Corksport BPV Return Hose /// CP-e RMM 75D /// Redline 75w90 /// DDM Tuning 6K Lows, 3K Fogs /// Prosport Boost Gauge /// RPM Vent Pod /// |
| The Following 2 Users Say Thank You to Jake_MS3 For This Useful Post: | Don06speed6 (04-20-2012), Enki (04-19-2012) |
![]() | | #22 | ![]() |
![]() Join Date: Mar 2011 Location: Idaho Falls, ID
Rep Power: 206 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 500
Groans: 53
Groaned at 18 Times in 6 Posts
Wow,bthis will sure be nice! Another humble thanks!
__________________ COBB AP, JBR RMM, CS SRI/TIP, AT HPFP INTERNALS, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS |
| The Following User Says Thank You to 2k4_8 For This Useful Post: | Enki (04-19-2012) |
![]() | | #23 | ![]() |
Groans: 103
For now, final determination of acceptability will be on the end user; run at your own risk sort of thing. Ultimately, it shouldn't be too hard to leave calibration A as default and drop the apps output into B, and flip back and forth to determine if you want to use it or not. Your input has been taken into advisement and will be considered (if I can figure out a nice, safe way to implement it) for inclusion in a later version. Thanks for the input Phate!
| The Following 2 Users Say Thank You to Enki For This Useful Post: | phate (04-19-2012), TexasSpeed3 (04-19-2012) |
![]() | | #24 | ![]() |
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 3813 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,073
Groans: 711
Groaned at 76 Times in 57 Posts
i want to suck your cock
![]() | | #25 | ![]() |
![]() Join Date: May 2009 Location: Kankakee, IL
Rep Power: 7897 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,583
Groans: 121
I tried out a mathematically ideal MAF curve once. Didn't work too well. Tapadatass
__________________ ATP GTX3071 IWG . 10.5:1 pistons . K1 Rods . Balance Shaft Delete . COBB AP . eBay Special Catless DP . Mazdaspeed Accessory CBE . OCC . Autolite XP5364 Spark Plugs . TRZ TMM . TRZ RMM . MDM SSP . JBR Shifter Bushings . JBR EGR Delete . KW V1 Coilovers . SPC Rear Camber Arms . EBC Yellowstuff Pads . Autotech HPFP internals . 3-Bar MAP Sensor . N2MB WOT Box . ACT 6-Puck Sprung Clutch w/ Streetlite Flywheel . Konig Milligrams 18x8.5 et45 with 245/40's . GrimmSpeed EBCS . Self-PnP IM with VTCS removed . TWM full replacement shifter with 3" extension . TS BPV SU Edition . CX Racing FMIC . HTP 3.5" Intake . Lots of ricer mods . Beans Above the Frank Build http://www.mazdaspeedforums.org/forum/f541/beans-above-frank-build-115919/ | |
| The Following 6 Users Say Thank You to silvapain For This Useful Post: | Enki (04-19-2012), MS3-a(sore)ASS-rex (04-19-2012), phate (04-19-2012), rfinkle2 (04-19-2012), Spirry (04-21-2012), TexasSpeed3 (04-19-2012) |
![]() | | #26 | ![]() |
Groans: 103
(Thread Starter) | Not Ranked : 0 score Well shit, I guess I HAVE to finish it now (preferably while you finish me! )
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
![]() | | #27 | ![]() |
![]() Join Date: May 2011 Location: Montréal
Rep Power: 80 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 65
Groaned at 4 Times in 2 Posts
Totally awesome
__________________ Mazdaspeed3 - Cobb AccesPort - Cobb SRI - 259whp@280wtq - 12.737@108.51mph - H&R spring - SPC camber kit - Team Dynamic Pro Race 1.2 18X8 et50 |
| The Following User Says Thank You to mrdouble99 For This Useful Post: | Enki (04-19-2012) |
![]() | | #28 | ![]() |
Groans: 103
(Thread Starter) | Not Ranked : 0 score Care to elaborate? Last math class I had in high school the final project was to balance a checkbook.
![]() | | #29 | ![]() |
| Not Ranked : 0 score Ah, yeah. We talked about that at one point.
| The Following User Says Thank You to phate For This Useful Post: | Enki (04-19-2012) |
![]() | | #30 | ![]() |
Groans: 121
| The Following 7 Users Say Thank You to silvapain For This Useful Post: | 06Speed6 (04-19-2012), 86azms3 (04-19-2012), Enki (04-19-2012), MS3-a(sore)ASS-rex (04-19-2012), phate (04-19-2012), rfinkle2 (04-19-2012), TexasSpeed3 (04-19-2012) |
![]() | | #31 | ![]() |
It will probably be easiest if the user does a MAF cal log that has very gentle throttle inputs and that extends into WOT to cover the whole range. Have them log desired AFR as well as actual AFR along with the LTFT, STFT information.
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #32 | ![]() |
![]() Join Date: Mar 2011 Location: Bastrop, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,150
Groans: 273
damn this is making me want to get back into programming. but shit so many variables in this one. your a brave soul taking on learning a new language as well as this program by itself. cant wait to see how this works
__________________ 2011 Black Mica - Daily JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp |
| The Following User Says Thank You to TexasSpeed3 For This Useful Post: | Enki (04-19-2012) |
![]() | | #33 | ![]() |
![]() Join Date: Nov 2010 Location: AZ
Rep Power: 260 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 373
Gonna be badass, shit, az will have something to be proud of. Can you please change the ENKI on the front to a unicorn shooting jizz outta his dick with a rainbow behind him?
__________________ 07 MS3 Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's Perm |
| The Following User Says Thank You to SoAgg159 For This Useful Post: | Enki (04-19-2012) |
![]() | | #34 | ![]() |
Groans: 103
So far the required logged values are accel pedal position, afr, boost, calc load, both trims, maf voltage, rpm and wastegate. I thought about doing mass airflow, but it didn't seem to line up with the voltage sometimes. As a side note, hit my first big hurdle and am currently working through it.
![]() | | #35 | ![]() |
I wonder if someone could write a script that would check for improper curves that are out of a certain range. There has gotta be a way because that script would throw a flag for meth systems, aux fueling, intake leaks, and maybe some other stuff im not thinking of. The math is way over my head but I know we have some math gurus around here that can make graph formula that fits.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | rfinkle2 (04-20-2012) |
![]() | | #36 | ![]() |
Groans: 103
| The Following User Says Thank You to Enki For This Useful Post: | 06Speed6 (04-19-2012) |
![]() | | #37 | ![]() |
| Monk Tuning ![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 868 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,032
Hellz yah. I've been waiting 2 months for an update on this...I'm glad you are making progress on it and will continue to wait for the beta release. The incorporation of larger maf housings...3", 3.25, 3.5, and 4" would be great!!! Good Job Enki.
__________________ 2011 Speed3-CP-E Stage 2 RMM, JBR TMM, JBR SSP, JBR SSB, 3.5" JBR WP, DDM 55w 6000k, Hoen Fog Lights, Autotech Internals, Enkei 17x8.5 RPF1, TIGs, EGR Delete, OCC, Treadstone TR8, FoMoCo Trans Fluid, Swift Springs, BSD and Baffle Kit, Ported Intake Manifold ala Driver311, CPE Injector Seals,PTP injector stud kit, RB Fabrication Ex Manifold, PTP 1950 Rail valve, ITV22s, Cordova Throttle Body, E85 blend Tuned by ME!!! Waiting to install- JTMS3 SUB BOX!!! TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
![]() | | #38 | ![]() |
![]() Join Date: Oct 2011 Location: Diamond Bar CA
Rep Power: 93 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
wow! this would be great!!
__________________ 2007 MAZDASPEED 6 BNR S3// ALL-SUPPORTING MODS |
| The Following User Says Thank You to ms6forthewin For This Useful Post: | Enki (04-20-2012) |
![]() | | #39 | ![]() |
![]() Join Date: Feb 2012 Location: Coloroado Springs
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,003
Sick! This should be one kick ass app when complete. Sent from Epic 4G via tap & touch 2.
__________________ 2012 Speed3 Tech~ Liquid Silver~ Mods - AP, COBB SRI, CP-E RMM, SURE TIP, CP-E Catted DP, AT Internals, CS TMIC, NGK 1 step colder plugs, TurboSmart BPV, GTX 2867r, ATP 3" inlet kit. Ordered Mods - Planned mods - JBR MM kit full, JBR SSP. Mods here but not installed- Tinted 15% all the way around, 5% hatch. ------------------------------------------------------------------------------------------- I think the internet needs more Cowbell! |
| The Following User Says Thank You to JasonMzdSpd3 For This Useful Post: | Enki (04-20-2012) |
![]() | | #40 | ![]() |
![]() Join Date: Jul 2009 Location: Keene, NH
Rep Power: 997 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
If you need any help with your methodology or have any questions in general, let me know. I'm just finishing up a class in C++, and although C# takes a departure from C++ in certain areas, they are relatively similar.
__________________ 08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's 253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune 97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup 89 Kawasaki 650SX Stand-Up Jetski |
