Notices
Like Tree26Likes
 Old 05-09-2012, 10:17 PM   #161
Eth Fiend
phate's Avatar
Posts: 4,254   (View Stats)
phate has disabled reputation
Do you need a single log, or will multiples work for you? I have some data from folks that I'm going to do a manual cal on (no previous work done). Should be a good comparison, I can usually get them within 2% on the first try
-06 MS6 - Tuning the high compression forged mill
-Corn fed 07 MS3 - Sold
phate is online now
Enki (05-09-2012)
 Old 05-09-2012, 10:21 PM   #162
Enki's Avatar
Posts: 2,985   (View Stats)
Enki has disabled reputation
Groans: 103
Groaned at 21 Times in 19 Posts
I'd prefer a log in the meg plus range; ~15 minutes with multiple WOT pulls. If you can provide that, I'll take it.
Enki is online now
 Old 05-09-2012, 10:32 PM   #163
GLORIFIEDBOZO's Avatar
Posts: 1,930   (View Stats)
Subbed to look at this in the morning
Sent from my DROIDX using Tapatalk 2
GLORIFIEDBOZO is offline
 Old 05-09-2012, 10:52 PM   #164
Eth Fiend
phate's Avatar
Lemme see if I remember tomorrow.
phate is online now
Enki (05-10-2012)
 Old 05-09-2012, 11:24 PM   #165
Bosox's Avatar
Posts: 328   (View Stats)
Bosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the world
Groaned at 33 Times in 13 Posts
Subbed
2010 Liquid Silver MS3 - COBB SRI/TIH, AP, JBR 88 Duro RMM, JBR Bushings, JBR SSP, AT Internals, CP-e Catted DP/RP, Michelin Pilot Super Sports 235/40 18, Motorcraft MT Fluid, Step Colder NGK's
Wife's Car: 2013 CX5 AWD Grand Touring (It's slow but handles nice)
OBAMA SUCKS
Stratified Tune by Lex
Bosox is offline
 Old 05-14-2012, 08:09 PM   #166
Enki's Avatar
Groans: 103
I still need at least one person (preferably on pump gas, uncalibrated) to step forward before I release to the tuning groups for beta testing.
Requirements are in OP.
Enki is online now
 Old 05-15-2012, 02:18 PM   #167
nindoja's Avatar
Posts: 964   (View Stats)
Enki: I'd rather not go WOT 3-4 times with an OTS MAF cal, would it be fine if I manually modified the MAF cal to be overly rich? This would result in a MAF cal that isn't right, but is still safe enough that I don't hit 13.X AFR at WOT.
I realize this might only test some parts of your code, but I'd rather not go super lean with an OTS cal.
True Red 2009 MS3
JBR: 3.5" WP w/recirc // RSB // Rear Camber Arms // Chrome Molly RMM
Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops
Other: Synapse Engineering FMIC + BOV // Autotech internals // SURE Flow M3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
// 13.761 @ 105.5 - Mason Dixon Dragway - 4/17/12
nindoja is offline
 Old 05-15-2012, 02:43 PM   #168
Enki's Avatar
Groans: 103
If you're worried about going lean, target rich in the OTS WOT AFR targets (modify it). The app will compensate appropriately.
Enki is online now
 Old 05-15-2012, 02:43 PM   #169
nindoja's Avatar
Enki that was my plan, I'll get a map updated and go do a log tomorrow.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
nindoja is offline
 Old 05-15-2012, 02:56 PM   #170
Enki's Avatar
Groans: 103
I modified my post, you may want to re-read it.
Enki is online now
 Old 05-15-2012, 03:26 PM   #171
drummermike58's Avatar
Posts: 358   (View Stats)
drummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the world
Enki,
I just started doing a new CAL on a freshly built motor. I got halfway through the PT mafcal but couldnt finish before having to go to Texas for work. Mt WOT is completely un cal'ed and PT is not quite there yet. I will be back home on Friday night and can take logs saturday for you.
--2010 BM MS3--
Treadstone tr8 fmic core, custom piping, self made 3.5" MAF, gtx3076 .82 a/r ts/vband hotside, RaceRoots EWG exh mani/3" vband DP, TIAL MVR EWG, UR Catback, Sure shortcut, Sure R3 rmm, Eagle Rods, Custom 10.5:1 .020 over pistons, balanced rotating assy., ARP head and main studs, Autotech internals, Accessport, 3bar map sensor, vtcs delete, EGR delete, Balance shaft delete, Hallman MBC, HKS SSQV 4 BOV, NGK iridium spark plugs, D2 coilovers, Nextmod lip kit, painted Enkei Aegis 19x8.5 et +35, 245/40/19 potenza tires, chinese HIDs, JB shift knob, 35% tinted, still tuning...
drummermike58 is offline
The Following 2 Users Say Thank You to drummermike58 For This Useful Post:
Enki (05-15-2012), nindoja (05-15-2012)
 Old 05-15-2012, 03:55 PM   #172
ms34m3's Avatar
Posts: 76   (View Stats)
ms34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond repute
Groaned at 13 Times in 3 Posts
would you open source this? put on Github? I have lots of experience in this area, perhaps I can help getting some code done... I
ms34m3 is offline
 Old 06-05-2012, 06:06 PM   #173
andrewpiro's Avatar
Posts: 283   (View Stats)
andrewpiro is the leader of the worldandrewpiro is the leader of the worldandrewpiro is the leader of the worldandrewpiro is the leader of the worldandrewpiro is the leader of the worldandrewpiro is the leader of the worldandrewpiro is the leader of the worldandrewpiro is the leader of the worldandrewpiro is the leader of the worldandrewpiro is the leader of the worldandrewpiro is the leader of the world
Groaned at 7 Times in 6 Posts
Any updates on this?
andrewpiro is offline
 Old 06-05-2012, 10:41 PM   #174
Enki's Avatar
Groans: 103
Not until I can get the test data I need.
Enki is online now
 Old 06-17-2012, 12:26 PM   #175
insomniacucr's Avatar
Posts: 65   (View Stats)
insomniacucr has disabled reputation
Are you still waiting on test data?
insomniacucr is offline
The Following User Says Thank You to insomniacucr For This Useful Post:
Enki (06-17-2012)
 Old 06-17-2012, 01:04 PM   #176
Posts: 8,005   (View Stats)
Groans: 34
Awesome man! so I assume this will be similar to Scoobie RomRaider's auto maf cal but would include both CL and OL calibration?
RR just basically plots + or - fuel trims over time from a long PT log so its not for WOT calibration AFAIK. Then you apply its plotted correction to your PT maf region.
PERM
07 Red MS3 GT - E40 - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - SS Exmani - Cobb DP - CNT CBE - AP w PERMTune - Grim EBC - Dano OCC - CPE CDFP - Labonte S2 WMI/w failsafe - ACT Street Kit - SUv2 RMM -"Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-05
The hardest part of modding is knowing when you've met your goal
I dunno though; it sounds good in my head but I'm mostly talking out of my ass.
Dano is offline
Enki (06-17-2012)
 Old 06-17-2012, 04:14 PM   #177
Enki's Avatar
Groans: 103
I have a good portion of test data at the moment, just working through some problems I've found with the logic as a result; the issue I found would have properly fucked the mafcal so it's a damn good thing I got the data I did when I did.
The app does both open and closed loop calibration, and will use short term trims to a point; you can set it to use any percentage of the short term trim values from 0 to 100%; default is 50 (so as to not fuck with the trims too much).
The current implementation of trimming also uses the x number of most common trims per .01 voltage; for example: You have 3 instances of +7 LTFT, 2 instances of +5 and 1 instance of 0 at 2.2 volts. With the LTFT trim setting at 1, your calculated LTFT modifier for that voltage will be 7; with a trim setting of 2, it would be ((7*3)+(5*2))/5 or 6.2. The same trim settings are available for LTFT, STFT, and WOT AFR. Obviously, since STFT and WOT AFR are going to vary more highly, the default values for these trims are higher.
TLDR:
Progress is slow but existent.
Enki is online now
CosmicArkie (06-17-2012), cshunter (08-01-2012), Dano (06-17-2012), mrmonk7663 (06-17-2012), redbathtub (06-18-2012)
 Old 06-17-2012, 07:25 PM   #178
Groans: 34
nice....so using the STFT value modifier, can you eliminate STFT from the calculation? I generally ignore STFT due to its volatility and instead put more time into the car at various voltage ranges so STFT gets transferred to LTFT. This can be done very successfully in very few miles if you do it right.
awesome app either way.
PERM
Dano is offline
 Old 06-17-2012, 10:43 PM   #179
Enki's Avatar
Groans: 103
Yes, you can set it so that you use a percentage of the most common x values or completely disregard it altogether.
Enki is online now
Dano (06-18-2012)
 Old 06-17-2012, 10:56 PM   #180
m4tic's Avatar
Posts: 4,508   (View Stats)
Groaned at 22 Times in 20 Posts
I'm rooting for you to see this through.. I'm planning on getting a 3" intake/tip and I don't want to cal the old way.
2007 w/ Cheez
// COBB AP // COBB SRI // COBB TIP // CXRacing FMIC // HKS SSQV v1 // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // BC Racing BR Coilovers // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Prosport Elec Boost Gauge // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob
m4tic is offline
The Following User Says Thank You to m4tic For This Useful Post:
Enki (06-17-2012)
 Old 06-17-2012, 11:05 PM   #181
scorpiorc10's Avatar
Posts: 171   (View Stats)
scorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the world
Groans: 77
Groaned at 103 Times in 42 Posts
sub
scorpiorc10 is offline
 Old 06-17-2012, 11:29 PM   #182
DiGi Faggot's Avatar
Posts: 1,082   (View Stats)
DiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the world
Groaned at 86 Times in 49 Posts
Enki; Not sure if anyones offered; But if you need help with C#. I'm a technical architect and good with C# if you need any help.
DiGi Faggot is offline
 Old 06-17-2012, 11:54 PM   #183
Enki's Avatar
Groans: 103
I'll make sure to have auto-scaling for aftermarket/big MAF housings sometime in the near future.
Originally Posted by scorpiorc10 View Post
sub
To you and everyone else who does this: thread tools -> subscribe to thread. It's up at the top.
Numerous people have offered to help, but I'm primarily doing this as a learning exercise. Don't learn much by having people do the work for you/give you the answers.
Enki is online now
m4tic (06-18-2012)
 Old 06-25-2012, 08:42 PM   #184
m4tic's Avatar
hows it going?
2007 w/ Cheez
m4tic is offline
 Old 06-25-2012, 09:02 PM   #185
Enki's Avatar
Groans: 103
Slowly. Between work and other real life stuff, I've not had much time to either work on this or tinker with the 'Speed (the latter being significantly more important to the community than this app).
Tomorrow afternoon sometime, I get to go in and see a doctor about my foot; either have a stress fracture (less likely) or tendon/ligament damage (fallen arch?).
I'll get it done eventually guys.
Enki is online now
 Old 06-25-2012, 09:10 PM   #186
Eatin' Your Tuna
Haltech's Avatar
Groans: 211
I happen to have a lot of good resources for programming loaded onto the site if you want them Enki. It may help you speed this up. Shoot me a PM and ill parse the links.
Haltech is offline
The Following 2 Users Say Thank You to Haltech For This Useful Post:
Enki (06-25-2012), phate (06-25-2012)
 Old 06-25-2012, 10:11 PM   #187
Enki's Avatar
Groans: 103
Thanks Hal, but it isn't a simple matter of knowledge (I soak up knowledge like a dry sponge soaks up water); time is the thing I lack.
Hell, I still need to rebuild my pump as the car...well, shouldn't be driven to be honest.
Enki is online now
phate (06-25-2012)
 Old 07-15-2012, 12:58 AM   #188
m4tic's Avatar
give to me nao!!
2007 w/ Cheez
m4tic is offline
 Old 07-15-2012, 05:27 PM   #189
give to me nao!!
Still drunk from nator?
m4tic (07-16-2012)
 Old 07-16-2012, 02:08 PM   #190
m4tic's Avatar
i was down... still a little goofy haha
2007 w/ Cheez
m4tic is offline
 Old 07-16-2012, 02:30 PM   #191
Eatin' Your Tuna
Haltech's Avatar
Groans: 211
how do i subscribe to this thread?
Bump
Haltech is offline
 Old 07-16-2012, 03:58 PM   #192
Posts: 5,613   (View Stats)
Groans: 121
Bump
Fucking noob. Use search.
silvapain is offline
burn813 (08-05-2012), JasonMzdSpd3 (07-18-2012), mrmonk7663 (07-17-2012)
 Old 07-16-2012, 04:25 PM   #193
Enki's Avatar
Groans: 103
All of a sudden, thread smells of burning rubber and cum.
It is a mystery.
Enki is online now
 Old 08-01-2012, 06:00 PM   #194
Enki's Avatar
Groans: 103
Good news and bad news.
Starting with the bad:
Apparently, I've lost all the source at some point during the computer move; it's nowhere to be found and I've just discovered this.
The good:
I'll be redoing the app in WPF as I need to learn it for work anyways, so the UI will be better, and since I already had it working once, I'll be able to redo the code in a more concise manner making development cycles on it much, much shorter and more option rich, easier.
I should also be able to refine the database structure and add in the ability to integrate multiple logs into one dataset for re-processing (in case you have multiple logs, it will now be possible to combine them all). If requested, I can implement filtering/highlighting in exportable datasets, with statistics.
Please to be commenting.
Enki is online now
cshunter (08-01-2012), magicka (08-01-2012)
 Old 08-01-2012, 06:08 PM   #195
nindoja's Avatar
Dang, that sucks Enki.
I would suggest https://bitbucket.org/ for all your source control needs. They have both public and private repos for free. I've been using it for a few private projects lately and love it.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
nindoja is offline
 Old 08-01-2012, 06:29 PM   #196
Enki's Avatar
Groans: 103
Well the only reason I lost it is due to the computer move. I'll have multiple backups (including cloud) in the near future (as in when I start writing code).
Edit:
In case there was any doubt, the next step on my list for the old project was to completely overhaul it as it was bloated and ran like ass towards the end. This way I can kill two birds with one stone.
Enki is online now
 Old 08-01-2012, 06:44 PM   #197
Eatin' Your Tuna
Haltech's Avatar
Groans: 211
Whatever fag, just get to work already.
Haltech is offline
The Following 3 Users Say Thank You to Haltech For This Useful Post:
Dano (08-01-2012), Enki (08-01-2012), magicka (08-01-2012)
 Old 08-01-2012, 07:46 PM   #198
Groans: 34
like my dad used to always say
" son, a poor excuse is better than no excuse at all"
a code monkey without a backup is like a hooker without KY.
insomniacucr likes this.
PERM
Dano is offline
Enki (08-01-2012), Haltech (08-01-2012)
 Old 08-01-2012, 08:04 PM   #199
Enki's Avatar
Groans: 103
I burned the drives without making sure I had everything. Fucking stupid. More work for me, more wait for you.
I'm going to add more functionality to it in the short term, so it will be better right out of the gate, so it will be an overall better tool.
Enki is online now
 Old 08-01-2012, 08:06 PM   #200
Eatin' Your Tuna
Haltech's Avatar
Groans: 211
Better have MSF branding on it too...
Haltech is offline
HTML code is On
Page generated in 0.58322 seconds with 34 queries
