 Old 07-06-2019, 10:48 AM   #1
shawnmos's Avatar
Posts: 47   (View Stats)
shawnmos is on a distinguished road
Unhappy Excessive engine breaking/jerking when letting off throttle.
So this may just be a coincidence but I recently had the VVT replaced by the dealer and now I am noticing excessive engine braking when I let off the gas, to the point that the car feels like it's jerking.
Now, manual cars normally do this a bit, especially in the lower gears but it's now noticeable it in 3rd and 4th gear as well.
Does anyone have any ideas as to what would cause this? I'm thinking vacuum leak that may or may not have been caused by them disassembling a bunch of stuff, but I'm not sure. I'm hoping it doesn't have anything to do with them not adjusting the timing correctly when they replaced the chain.
Another possibility is that it's excessive drag caused by the AC compressor. I added some more R134a and overfilled it a bit. I let some back out, but it's possible it could still be overfilled. However, the problem should go away when I turn off the compressor but it does not.
Thoughts?
2008 Mazdaspeed 3
2010 Mazda 5
shawnmos is offline   Reply With Quote
 Old 07-12-2019, 06:09 AM   #2
Reds3's Avatar
Posts: 31   (View Stats)
Reds3 is a jewel in the roughReds3 is a jewel in the roughReds3 is a jewel in the roughReds3 is a jewel in the rough
How are your engine mounts?
Also if you had a vacuum leak you should be able to see a difference in your fuel trims on your AP, assuming you have an AP or some kind of data logging device hooked up.
2007 Mazdaspeed 3 / Cobb SRI / 219K and Counting
1995 EG6 B16A3 78K *sold*
Reds3 is offline   Reply With Quote
 Old 07-12-2019, 08:37 AM   #3
Jeff23spl's Avatar
Posts: 2,020   (View Stats)
just ac compressor turning on and off could make some drag but you can easily turn it off just to compare if it is that...
When i drove my skyactive 3, i switch AC off to pass a car and for a low power engine, it makes a difference....
btw have you added petrolum equivalent r134 or real r134 ? I'm curious because in here, we need a special licence to manipulate freon but not the small petrolum products replacement in can....And some specify to use just half or 40% of the freon weight needed....
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 07-12-2019, 10:52 AM   #4
Fstrnyou's Avatar
Posts: 2,474   (View Stats)
Engine breaking is called ZZB.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 07-16-2019, 11:57 AM   #5
MSMS3's Avatar
Posts: 2,634   (View Stats)
Groans: 146
Ha ha. OP probably does not even know why this is funny. Spelling must not be a high priority. I'm not the grammar and spelling police. We all make mistakes, but that was funny.
As to why his engine braking may be excessive, there are lots of possible explanations. I'd lean toward exploring engine and transmission mounts first. These cars are getting a lot of age and miles on them. Fixing one thing, especially if it increases or restores lost power, can reveal other problems that were latent. An abrupt movement of the engine and transmission when letting up on the gas may be causing this sensation. That points to one or more bad engine or transmission mounts.
Also, if the ac solenoid clutch is sticking so that the ac compressor is turning all the time, even when it is turned "off" this could, indeed, put a heavy load on the belts, pulleys and introduce a lot of drag to the engine. That would stress weak engine/transmission mounts. It will also burn out the compressor. OP should look and see if the compressor is turning when the ac is switched off. It should stop when off, and resume when turned on. That is visible.
 Old 08-01-2019, 07:21 AM   #6
shawnmos's Avatar
Doh
I assumed it was real r134 but it came in a can so maybe not?
Thanks, I'll check over the mounts, though the PMM was replaced not too long ago. I'll check the compressor too.
I don't have an AP but I have Forscan on my laptop. I honestly don't know enough about what they should look like to know whether they are off.
2008 Mazdaspeed 3
2010 Mazda 5
Last edited by shawnmos; 08-01-2019 at 07:21 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-01-2019, 08:04 AM   #7
Jeff23spl's Avatar
STFT and LTFT combinned should remain inside a +/-10% with a proper maf tune (Cobb say 8%)
have you checked if it is different if you switch to neutral just to isolate motor/trans from the equation when you decelerate ? The car should almost ''fly'' in neutral or you may have a stikky brake or a bearing...
Wife drive 2010 CX7
 Old 08-02-2019, 09:24 PM   #8
shawnmos's Avatar
This was just a 5min drive around the block.
2008 Mazdaspeed 3
2010 Mazda 5
 Old 09-10-2019, 04:32 PM   #9
shawnmos's Avatar
It does not do it in neutral. Only when the car is in gear.
I just replaced the RMM hoping that would fix the problem but it did not make much difference.
2008 Mazdaspeed 3
2010 Mazda 5
 Old 09-11-2019, 08:25 AM   #10
shawnmos's Avatar
Attaching a few different drives/days. The more I've been reading the more it sounds like a fuel cutoff when I let go of the gas.
2008 Mazdaspeed 3
2010 Mazda 5
 Old 09-11-2019, 07:55 PM   #11
Quazz236's Avatar
Posts: 15   (View Stats)
Quazz236 will become famous soon enough
What RPM does it happen at? I've noticed that when I let the gas go and coast in gear the engine feels somewhat rough around 3K. Like lets say I'll go up to 5k RPM and let the gas go and roll (any gear btw) when the RPM's start dropping the engine feels smooth till about 3K then it gets rough between 3k-2.5ish.k and then under 2.5k RPM it feels ok again. IDK if it's something similar or not.
Quazz236 is offline   Reply With Quote
 Old 09-12-2019, 06:24 AM   #12
shawnmos's Avatar
It seems to happen at any RPM. I've actually noticed since replacing the RMM it no longer jerks when I let off the throttle. So maybe that was part of the problem.
However, it still jerks violently when I first start to accelerate. It doesn't seem to matter the RPM, though it's worse the lower the gear. It's still somewhat noticeable in 5th or 6th gear though. Just feathering the pedal a bit and it jerks a lot.
2008 Mazdaspeed 3
2010 Mazda 5
 Old 09-12-2019, 07:42 AM   #13
Fstrnyou's Avatar
I think I have noticed a similar phenomenon with very little throttle input. Off throttle, the fuel is cut off. But at very light throttle where I'm still slowing down but not as much as off throttle, it feels a little jerky. I just assumed it was the nature of having a 3.5" intake and maybe the MAFcal was slightly off in that area. Or maybe the throttle tables needed to be refined in that area. It didn't bother me enough dig into it.
Other rides:
History:
HTML code is On
excessive oil consumption, engine running meh paxtonschwendner MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 10-21-2014 02:26 PM
KR when letting off throttle radioflyer MazdaSpeed 3/6 - ECU Computer Tuning 5 03-06-2012 09:39 AM
excessive popping from engine MX3ze@7psi MazdaSpeed 3/6 - Troubleshoot/Diagnostics 50 01-15-2012 06:51 PM
car jerking light throttle 3rd gear Kydizzle MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 12-15-2011 12:32 AM
BREAKING: Lexus recalls HS250h over risk of excessive fuel leakage Haltech Automotive News 0 06-25-2010 02:10 PM
Page generated in 0.32820 seconds with 26 queries
