 Old 06-06-2019, 10:18 AM   #1
Thor Hammer's Avatar
Posts: 1,845   (View Stats)
Groans: 211
Default Front Axle Nut Coming Loose
For the first time in my life I have a weird problem. Front passenger axle nut keeps coming loose. I replaced the wheel bearings on both sides in December of 2017 with Timken units. And just about every other suspension component at that time.
A couple months ago noticed a noise from front wheel. Upon inspection I noticed the axle nut was loose. Properly torqued to 202 ft/lbs. and staked the nut. Well, I went a little tighter to 220.
Two days ago noise reappeared. This morning I had to tighten the nut again and noise is gone. WTF?
Can a bad hub cause this to occur? They should last the life of the car. How would I know the hub is compromised and not just the bearing?
Drivers side is fine. No issues.
Even though its tight again now, I have play from left to right but not up and down when grabbing the tire. Drivers side has zero play.
I belive the lower ball joint on the front lower control arm in the knuckle is shot. I have all new bearings/hub, and control arm due Saturday to install.
Thoughts anyone?
 Old 06-12-2019, 11:00 AM   #2
MSMS3's Avatar
Posts: 2,500   (View Stats)
Groans: 140
@Thor Hammer; Forgive the late reply. But those nuts are "one time use" items. They should be replaced and not reused. They lose tensile strength once torqued and do not hold torque properly if reused.
Get a new OEM nut. They are cheap. Torque and stake the new nut and you should be golden.
2017 Audi Q5 3.0 T (supercharged) Stage 2, EPL tune, JHM overdrive crank pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 430 hp.
 Old 06-12-2019, 11:06 AM   #3
Db09ms3's Avatar
Posts: 375   (View Stats)
Groans: 81
Yeesh I reused mine. Looks like I'll buying OEM soon enough.
Stockish
HTML code is On
Front CV Axle Installation Help GohanX MazdaSpeed 6 - Engine, Transmission & Driveline 10 01-24-2019 10:26 AM
Loose change sound from front suspension alden MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 08-28-2018 03:05 AM
New Front CV Axle-Pulls To Right Thor Hammer MazdaSpeed 6 - Engine, Transmission & Driveline 5 03-22-2017 03:04 AM
Loose rattle Front Driver's side mikelevi MazdaSpeed 3/6 - Suspension & Brakes 10 03-10-2012 04:52 PM
klunking in driver front stealership told me front axle carrier never heard of such a part gotgrip MazdaSpeed 3/6 - Suspension & Brakes 6 02-25-2011 10:34 AM
Page generated in 0.22758 seconds with 22 queries
