 Old 01-09-2017, 11:28 PM   #1
furinax's Avatar
Posts: 218   (View Stats)
furinax is just really nicefurinax is just really nicefurinax is just really nicefurinax is just really nicefurinax is just really nice
Groaned at 7 Times in 3 Posts
Default Fuel door switch stuck
I pulled into a gas station today and tried to open the fuel door but the switch wouldn't go up. It was just stuck. I pulled hard but didn't want to break it. Eventually we got it open by going through the trunk and pulling on the release to unlock the fuel door.... however the switch is still stuck. Any ideas?
I'm running without a skid plate. Could that possibly cause any issues with the fuel door switch?
2007 Mazdaspeed 3
furinax is offline   Reply With Quote
 Old 01-10-2017, 03:45 AM   #2
frothy's Avatar
Posts: 1,067   (View Stats)
The cable's run through the interior of the car, so the lack of a skidplate would have no impact.
 Old 01-10-2017, 04:19 AM   #3
SoyBean's Avatar
Posts: 176   (View Stats)
SoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond repute
I recently decided to ditch the switch and cable. I just pull the trigger in the trunk. However, I unintentionally unhooked the spring that hold the pin in place. That diagram doesn't show the spring attached to item 2. #BecaseRacecar
2008.5 Black MS3 "Wednesday"
PWR: HTP 3.5, CPe Catless DP, CX FMIC, HKS (VTA), PTP HPFP Internals, TRZ MM, AWR PMM
SUSP: Drag DR31 18x8 +35, MonoSS Coilovers/Endlinks, Racing Beat Sway Bars, Drilled Rotors, Green Brake Pads
MISC: AP v3 Self-Tuned, 6LB Battery, Braided Brake Lines, NRG Steering Wheel, Partial Gutted Interior
SoyBean is offline   Reply With Quote
 Old 01-10-2017, 05:17 PM   #4
sheston's Avatar
Posts: 1,844   (View Stats)
Must be a racecar thing. Mine stuck years ago, so I just have a little cable dangling in the trunk to open the fuel door. Not bad, since I have to get in the back to get my Meth to put in the tank anyways.
Like it was said, because racecar :-)
 Old 01-10-2017, 05:21 PM   #5
GH07MS3's Avatar
Posts: 170   (View Stats)
GH07MS3 has a reputation beyond reputeGH07MS3 has a reputation beyond reputeGH07MS3 has a reputation beyond reputeGH07MS3 has a reputation beyond reputeGH07MS3 has a reputation beyond reputeGH07MS3 has a reputation beyond reputeGH07MS3 has a reputation beyond reputeGH07MS3 has a reputation beyond reputeGH07MS3 has a reputation beyond reputeGH07MS3 has a reputation beyond reputeGH07MS3 has a reputation beyond repute
Groaned at 8 Times in 5 Posts
i just lubed up the pin with wd 40 and pushed on it a bunch and its worked fine since
Cobb AP/TIP/SRI/Rear Sway bar- ATP 3 inch catted DP -Mazdaspeed CBE -Greddy type r bov -TWM SS -TRZ pass and rear MM -AWR driver side MM -Centric Rotors -Hawk HPS pads -DG Motorsports fiberglass hood -Mazdaspeed sport springs and camber arms, -Mazdaspeed coilovers, -Rally Armour poly. flaps -Autotech internals -FREEK TUNED
290 WHP
311 WTQ
GH07MS3 is offline   Reply With Quote
 Old 01-11-2017, 10:00 PM   #6
furinax's Avatar
Magically worked again today. Maybe it was a temp related issue?
I will try lubing up the pin. I would not want to lose the spring that holds it down.
2007 Mazdaspeed 3
HTML code is On
Mazdaspeed 6 power door lock switch bross2009 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 01-22-2017 04:56 PM
keyless door request switch shadow6 MazdaSpeed 3/6 - Car Audio & Electronics 1 06-04-2013 05:56 AM
Passenger front door stuck closed Autox Mazdaspeed3/6 General Discussion 4 03-27-2013 06:55 PM
MS6 Drivers Door Switch Cluster Removal MazdaSpeedster Mazdaspeed3/6 General Discussion 2 10-27-2012 06:46 PM
Page generated in 0.37741 seconds with 24 queries
