Notices
Like Tree2Likes
 Old 10-11-2012, 09:52 AM   #1
Unicorn Farts
Deldran's Avatar
Posts: 2,188   (View Stats)
Groans: 96
Groaned at 35 Times in 28 Posts
Default Gas smell with heater on
So i am getting this wierd issue. If the car sits and idles for a period of time with the heat on it gets a really gassy smell.
A bit of background about a month ago dealship fixed VVT, no issues with that at all. but used crappy dealer oil that i havent changed out yet not sure if this could have an effect or not.
Now if i just turn it on auto letting the heat run with the A/C on i dont get that smell.
if i turn the A/C off it does. I do not smell gas outside of the car.
For example this morning had heat on like 85, car wasnt completly up to temp yet but i left it on while i went into the store. No gas smell when i got out. got back in bad gas smell inside but did not smell it before i got in.
It also seems if i am driving down the highway i dont get a gas smell.
This weekend going to switch back to T6 but i wouldnt think oil would cause this.
Any thoughts.
Cobb AP - HTP 3.5" Intake -Cobb DP - Cobb CBE - Sure Track RMM - Mazdaspeed Coilovers - CorkSport Endlinks -CorkSport RSB -SPC Camber arms
Deldran is online now   Reply With Quote
 Old 10-11-2012, 09:56 AM   #2
theurgy's Avatar
Posts: 1,458   (View Stats)
I doubt oil will make a difference, I would maybe have the dealership take a look at your fuel pump (in-tank) and tank seals.
Maybe change your cabin air filter?
ETS TMIC, Cobb SRI, Cobb TIP, TWM SS w/Bushings and TypeR knob, Cobb Shift Weight, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb RSB, Autotech HPFP Internals, Denso Iridium ITV-22, Cobb AccessPort, Port and Polished IM, VTCS & EGR Delete, CP-e Safe Seals, SURE TIG IM and TB, JBR Trilogy Mounts 70a Duro, GS EBCS, CP-e Catted Downpipe.
Coming Soon:
Stratified Tuning Guardian Angel and Lex Tuning.
theurgy is online now   Reply With Quote
 Old 10-11-2012, 10:05 AM   #3
Unicorn Farts
Deldran's Avatar
Groans: 96
Do gen 1's have a cabin filter?
I also just had a thought, when the heat is on its not recircing the air in the cabin its pulling air in from the outside. Anyone know where this air gets pulled in at, maybe when they took the top of the motor apart they got some gas from the HPFP connections close to this inlet
 Old 10-11-2012, 10:11 AM   #4
helmetface's Avatar
Posts: 4,584   (View Stats)
Groans: 142
^ yes we haz air filter...doesn't every [modern] car?
ms6forthewin likes this.
 Old 10-11-2012, 10:21 AM   #5
Unicorn Farts
Deldran's Avatar
Groans: 96
Lol i will check that out, not sure why i only thought the gen2 did
 Old 10-11-2012, 10:26 AM   #6
fooqr's Avatar
Posts: 557   (View Stats)
fooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the world
Not every car, but ours does. PITA to replace. Check ebay for cheap knock-off replacement filters. Should be about $10.
Might also want to check injector seals. Failing seals can lead to gas smell under the hood.
08 MS3 GT (SSM). JBR WP intake, CS boost tubes, Forge v2 BPV, JBR TB/IM TIG, JBR TB coolant bypass, JBR EGR block-off, 3-bar MAP, PTP pill, bnoon bolt, SM OCC (MD kit) w/ Kat's heater, UR DP (ceramic cat), UR resonated TP/CBE, JBR SSP, SU shift bushings, JBR trilogy mounts (CRMO 88 RMM, 70 PMM/TMM), Koni yellows, JBR RSB, 2nd Fiamm, Stoptech SS lines, Hawk HPS, spin-on CX-9 oil filter, Fumoto valve, PP 5W-30, XT-M5-QS, tints, clear bra, Continental DWS, ITV22, DashHawk, AP, AT internals
There are no stupid questions, but there are stupid people and some of them ask questions.
- A. Funicello
fooqr is offline   Reply With Quote
 Old 10-11-2012, 10:29 AM   #7
Unicorn Farts
Deldran's Avatar
Groans: 96
Yea next time i have it sitting for a bit i will pop the hood before i get into the car see if i smell i there.
 Old 10-11-2012, 11:02 AM   #8
theurgy's Avatar
Replacing the Cabin Air Filters
Coming Soon:
 Old 10-11-2012, 11:16 AM   #9
Unicorn Farts
Deldran's Avatar
Groans: 96
Originally Posted by theurgy View Post
yep looks like a giant PITA but i would be willing to bet mine have never been replaced so i better
 Old 10-11-2012, 11:18 AM   #10
helmetface's Avatar
Groans: 142
Its really not that bad
 Old 10-11-2012, 11:25 AM   #11
Unicorn Farts
Deldran's Avatar
Groans: 96
I am sure its not to bad, but it just why would they make a consumable item like a filter so hard to get to. Most normal people are just gona get raped by the dealer to get it done because they wont want to do it.
 Old 10-11-2012, 12:09 PM   #12
theurgy's Avatar
They made the Gen 2 filter ridiculously easy to change.
Anyhow, might not actually sole your problem though, I would look into the source of your problem.
Coming Soon:
 Old 10-11-2012, 12:38 PM   #13
Unicorn Farts
Deldran's Avatar
Groans: 96
Agreed just not sure what the source is yet. I really doubt its seals.
What is a good way to check this doesn't random kr show up in logs the car drives perfectly fine haven't taken a log lately though
Sent from galaxy Nexus vis CM10
 Old 10-11-2012, 01:00 PM   #14
theurgy's Avatar
If it's random KR, then do some datalogs for some daily driving and set your monitor to look at KR.
Coming Soon:
 Old 10-11-2012, 01:17 PM   #15
Unicorn Farts
Deldran's Avatar
Groans: 96
No I was asking is that what shows up when injector seals start to go bad
 Old 10-11-2012, 01:56 PM   #16
theurgy's Avatar
That's a good question, I just upgraded mine to remove any possibility of knock.
Figure I was already in there for a valve cleaning.
Maybe some of the tuner guys can pipe in and give some insight as to what the datalog symptoms are for bad injector seals.
Coming Soon:
 Old 10-11-2012, 07:13 PM   #17
Frequentflyer's Avatar
Posts: 1,878   (View Stats)
I've been getting the same thing lately. Drive for a while and stop at a light and I get a gas smell unless I got recirc on the fan. I thought maybe I had an exhaust leak from my Corksport DP, but it's tight. I'm thinking it is the injector seals. I've got near 107k miles running 18-19psi now for most of the car's lifetime. I've got a set of PTP seals waiting to go in.
08.5 CWP MS3 - Cobb AP *Stage 2* ATR tweaked - Cobb SRI w/AEM dry flow filter - RPMC Inlet - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - Rota 18x8.5 48+ SVN Black/w Red Lip - Bridgestone Potenza RE760 - Cobb RSB - Prosport Boost Gauge/Mearcat pod - Motorcraft XT-M5-QS in the tranny!
Frequentflyer is online now   Reply With Quote
 Old 10-12-2012, 05:02 AM   #18
Unicorn Farts
Deldran's Avatar
Groans: 96
So it seems I have a very gassy smell under the hood as well. Guess I am going to have to get new seals.
What to use sure halos or the Toyota seals
 Old 10-12-2012, 10:33 AM   #19
theurgy's Avatar
Meh.. I got Halos cause I like SURE, but I hear those Toyota seals are a good cheaper option.
I just figure if you're going to go through the trouble of taking off your manifold, and fuel rail, injectors, etc...
Why not install a product that is meant and designed for our cars.
Coming Soon:
 Old 10-12-2012, 03:05 PM   #20
Unicorn Farts
Deldran's Avatar
Groans: 96
Ok here is a 3rd gear log i took on the way home.
Fuel pressure look good, when i got done driving around, the last 8-10 minutes of driving was normal in town driving. i popped the hood with the motor running to see if i could smell any gassy smell. Not really, if i practically put my nose on the IM i would get a very faint gas smell but nothing like i do in the morning.
Could the car not being completely warmed up when i notice this be a factor.
phate
 Old 10-12-2012, 03:26 PM   #21
Eth Fiend
phate's Avatar
Posts: 4,337   (View Stats)
phate has disabled reputation
You need some boost control massaging, lol.
Other than that, it looks fine. I'd say it's not the injector seals.
Are you sure you just weren't catching a whiff of the exhaust?
-06 MS6 - Tuning the high compression forged mill
-Corn fed 07 MS3 - Sold
phate is online now   Reply With Quote
 Old 10-12-2012, 03:39 PM   #22
Unicorn Farts
Deldran's Avatar
Groans: 96
Yea I know my wgdc tables need a bit of work. I don't think so pretty sure I don't have an exhaust leak but I could just be being a bit paranoid due to the dealer just doing some work to it
 Old 10-12-2012, 04:03 PM   #23
dantes5823's Avatar
Posts: 6,674   (View Stats)
I've been getting a gas smell for a while. Now that I think about it, it's been since I did my ptp Injector seals.....
 Old 10-12-2012, 04:24 PM   #24
Unicorn Farts
Deldran's Avatar
Groans: 96
PTP is the issue there
 Old 10-12-2012, 04:46 PM   #25
dantes5823's Avatar
Guess I'll buy the sure halos. I've been itching to buy them anyways.
 Old 10-12-2012, 04:52 PM   #26
theurgy's Avatar
LOL.. did you make sure to snap them into place?
Coming Soon:
 Old 10-15-2012, 11:56 AM   #27
fooqr's Avatar
phate
If you park in a garage, smell first thing in the morning after it's been sitting all night in an enclosed space.
- A. Funicello
 Old 10-16-2012, 05:59 AM   #28
Unicorn Farts
Deldran's Avatar
Groans: 96
This is different than that, it doesnt smell like a gassy exhaust it smells like straight up gas like if you stuck your nose next to a open gas can.
It seems to only happen in the morning when i am driving and the car isnt completly up to temp. once it is the problem seems to go away.
But my logs seem fine havent lost any power and car is not driving funny or making any strange noises, so i still think its some fluke
 Old 12-19-2012, 01:17 PM   #29
mswierse's Avatar
Posts: 289   (View Stats)
mswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the world
I get the same thing... Just started to notice it, but it also just started to get cold enough to require heat.
My smell reminds me of the smell from draining the occ.
Sent from my DROID BIONIC using Tapatalk 2
2012 VRM MS3: JBR 3.5" WP Intake, JBR 80 Duro RMM, MD OCC, Cobb AP, MeTune (with Phate's help!), Autotech internals, Denso ITV22 Spark Plugs, Second Cat removed...
13.5@106
mswierse is offline   Reply With Quote
 Old 03-07-2013, 10:50 PM   #30
kobberr's Avatar
Posts: 63   (View Stats)
kobberr has disabled reputation
Groaned at 25 Times in 16 Posts
I have the same problem. It started after I installed hpfp internals. I just recirc the air and it doesn't happen anymore, but I would like to solve the problem indefinitely. Sounds like no one ever found any real solution.
ATP GT2871R, COBB SRI, CS TIP, Grimmspeed EBCS, FullRace EM, SU TMIC, TurboSmart BPV, Autotech HPFP internals, DW65c Intank FP, M2 DP, Custom CBE, Denso Iridium ITV22 plugs, SURE RMM, ACT 6 puck clutch...
PSI Proformance Tuned:
2/28/2012: 267awhp/334tq on 93 octane (Stage 2: K04)
11/6/2012: 309awhp/312tq on 93 octane (Stage 3: GT2871r)
kobberr is offline   Reply With Quote
 Old 03-07-2013, 11:15 PM   #31
sidekick's Avatar
Posts: 1,565   (View Stats)
Groans: 30
Groaned at 47 Times in 29 Posts
So how do you feel about this now?
2006 Mazdaspeed6
Cobb AP | E30 | HTP 3" | JBR 80A | Autotechs
250AWHP | 280AWTQ
sidekick is online now   Reply With Quote
The Following User Says Thank You to sidekick For This Useful Post:
ms3blackmica (03-12-2013)
 Old 03-08-2013, 09:29 AM   #32
dantes5823's Avatar
I dont wanna talk about it.
sidekick likes this.
 Old 03-08-2013, 10:20 AM   #33
theurgy's Avatar
LOL
Coming Soon:
 Old 03-08-2013, 11:18 AM   #34
JosephM's Avatar
Posts: 65   (View Stats)
JosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud of
Groaned at 61 Times in 15 Posts
gas in the oil causing the smell? read a post yesterday about certain oil being diluted with gas and being able to smell the gas off dipstick.
cold weather + dilution = smell?
JosephM is offline   Reply With Quote
 Old 03-08-2013, 11:33 AM   #35
twincitySPEED6's Avatar
Posts: 54   (View Stats)
twincitySPEED6 is just really nicetwincitySPEED6 is just really nicetwincitySPEED6 is just really nicetwincitySPEED6 is just really nice
I too have this issue once in a while
I drive a 2007 MS3
[eibach prokit + bilstein struts, k&n sri, jbr tip, forge v1, md occ, egr delete, resonator delete, jbr rmm, grimmspeed ebcs]
Ill be looking for an ap soon...
twincitySPEED6 is online now   Reply With Quote
 Old 03-12-2013, 01:27 AM   #36
ms6forthewin's Avatar
Posts: 505   (View Stats)
ms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the world
becuzz race car...
are you running catless?
Any thoughts.
2007 MAZDASPEED 6
BNR S3// ALL-SUPPORTING MODS
ms6forthewin is offline   Reply With Quote
 Old 03-12-2013, 03:09 AM   #37
Vegasspeeed's Avatar
Posts: 178   (View Stats)
Vegasspeeed has disabled reputation
Groaned at 7 Times in 6 Posts
Originally Posted by ms6forthewin View Post
becuzz race car...
I was about to ask the same question cuz it sounds similar to what I experienced after installing a catless dp..it only happened the first few days after but I think it stopped doing it for whatever reason
K&N intake, Cobb TIP, sure test pipe, both resonators deleted, Autotech HPFP internals, Cobb AP, Forge BOV V2, JBR 88A RMM, JBR 80A PMM, TRZ TMM, Prosport Boost gauge, CXracing FMIC, RL coilovers,
NEXT: XXR 521's (gold or hyper silver) or 527's (gold) & JBR RSB
Vegasspeeed is online now   Reply With Quote
 Old 03-12-2013, 06:16 AM   #38
Unicorn Farts
Deldran's Avatar
Groans: 96
No not catless. Full Cobb TBE. the issue seems to have resolved itself now. i no longer get the smell. I think when the dealer fixed my VVT they might have got a bit of gas in the ac system inlet, which might have been the cause. But i think my cat might be failing cause i get weird intermittent downstream O2 cel
 Old 03-12-2013, 01:55 PM   #39
or maybe there is a leaking issue? like the sensor isnt in all the way...just a guess
 Old 03-12-2013, 02:31 PM   #40
Unicorn Farts
Deldran's Avatar
Groans: 96
Possibly I haven't really looked into it my open and closed loop afrs are always spot on so NCE
Sent from my Nexus 4 using Tapatalk 2
HTML code is On
How To: Wolverine Oil Pan Heater labikesrcool MazdaSpeed 3 - How-To's 22 10-24-2012 10:03 AM
Edmonton - Block Heater stillmatic Canada 9 01-19-2012 04:48 PM
Wtf? Heater Control Circuit CEL? wakeboarddude MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 03-10-2010 04:59 PM
Radio/Heater speed/Temp not working maritime ms6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 03-06-2010 01:26 PM
Does your A/C compressor kick on with the heater? Wishbone MazdaSpeed 3 - Engine, Transmission & Driveline 13 12-15-2009 06:16 PM
Page generated in 0.56816 seconds with 34 queries
