-   Mazdaspeed3/6 General Discussion (http://www.mazdaspeedforums.org/forum/f505/)
-   -   Help me Shop (http://www.mazdaspeedforums.org/forum/f505/help-me-shop-111573/)
Mizzle 04-22-2012 05:15 PM
Spend My Money For Me
Soooo I'm indecisive, lazy, fearful & ocd. These things cause problems when it comes to spending money. I'm making a list here with links to help myself, but I also want your suggestions if necessary. I'm set on the wheels, tho, since I want to try and keep the negative scrub radius.
If you know of a better price, part, have another suggestion or are a vendor looking to deal, hit me up and/or post in here.
As far as parts I'm not decided on yet, I'm fine with DIY so if another OCC will work but doesn't have a check valve, I'll get a check valve ya know?
Wheels:
_Enkei PF01 17x8 ET50 (silver) with centers
_~ $1,100
_TireRack
Tires:
_Continental ExtremeContact DW 245/45ZR17 Purchased @ $620
_Tire Details - Discount Tire Direct
Lugs:
_McGard 65557BK SplineDrive Wheel Installation Kit Purchased @ $81.35
_Amazon
STS:
_Ralco RZ 914950 Purchased @ $116.61
_Ralco RZ Short Shifter MAZDA 3 2007 - 2009 914950
Programmer:
_AP AP-MAZ-002
_$535.00
_07-11 Mazdaspeed3 Cobb Tuning Accessport
Side Mounts:
_JBR obv.
_$350.00
Springs:
_Swift
_$319.00
_Swift Spec R Springs Mazdaspeed 3 MS3 2010+
Fuel Pump Internals:
_$349.96
_Autotech Hi Volume Fuel Pump Upgrade HPFP Internals Mazdaspeed 3 6 MS3 MS6
Help:
Spark Plugs:
_?
Strut Mounts:
_What adjustable mounts are out there?
Rear camber arms:
_Brand loyalty aside, which ones are a.) awesome & b.) adjustable on the car?
BSD Kit:
_Which would you recommend?
OCC:
_Which would you recommend? Easiest to drain?
EGR Blockoff:
_I'm thinking JBR?
FSB:
_Stiffest?
RSB:
_Stiffest?
Is the Whiteline bumpsteer thing worth it?
Is the Whiteline caster kit worth it?
Should I get rear toe adjuster thingies?
What else am I missing? I don't (yet,) want a FMIC/TMIC, dp, etc.
I don't have the money for internals or the AP yet, hence why it's mostly the stuff at the beginning of the list.
How are we so far/what do you think?
:edit:
Please include links.
mazdafreak 04-22-2012 05:18 PM
Md occ.....(Matt Damond oil catch can)
Rsb-jbr.
Mizzle 04-22-2012 05:24 PM
Rsb-jbr.
Links?
I heard TriPoint's race bar was the stiffest. No?
Vansquish 04-22-2012 05:27 PM
I seem to recall having heard some not-so-great things about the Ralco RZ short shifters. I think if you look around a little bit, you'll find some mentions of it being "weak" or "rattly" or something along those lines.
I think I'd go with the TWM kit instead, though it is significantly pricier.
TWOptSL0W 04-22-2012 05:32 PM
i got my rpf1's for 1k shipped, pm me
predapio 04-22-2012 05:32 PM
From what I've read, the Conti's are okay at everything, great at nothing.
I still say a summer setup and a winter setup.
mazdafreak 04-22-2012 05:33 PM
Originally Posted by Mizzle (Post 1374993)
Links?
I hear front sway bar isn't worth it since u will get way too much oversteer or understeer, one of those.
Umm but for rear sway bar......I'd just go jbr
Mazdaspeed 3 (07' - 2012) : James Barone Racing, Custom Fabrication
And the oil catch can you can get from Matt damond.
http://www.mazdaspeedforums.org/foru...-thread-36097/
Mizzle 04-22-2012 05:47 PM
DW, not DWS. They're second only to 2x expensive Michelins.
Vansquish 04-22-2012 05:53 PM
If you want to know about the Ralco RZ for sure, I suggest you chat with Daddy Chinkus. I think he's got one in his car.
Mizzle 04-22-2012 06:16 PM
I want more of a "If it were my car and I could do it again, I'd buy ____ because ____."
Mizzle 04-22-2012 07:28 PM
OP updated. Easiest to drain OCC that'll work with a CAI.
MS3-a(sore)ASS-rex 04-22-2012 07:53 PM
OCC=matt damond or JBR
EGR delete=JBR
RSB=no clue
Plugs=Denso ITV22's
BSD=I personally like the SURE BSD
Rear Camber Arms=Megan or SPC. Both adjust on the car
Mizzle 04-22-2012 09:38 PM
Is there a bsd walk-through?
Any less expensive occ's or would making a cheaper one work negate the savings?
Link to Megan camber arms?
@jbarone - does yours adjust when installed?
What is the consensus on rear toe adjusters?
mazdafreak 04-22-2012 09:58 PM
No, his arent adjustable once on the car.
Mizzle 04-22-2012 10:00 PM
Thanks. Do Megan arms have stiffer bushings?
MS3-a(sore)ASS-rex 04-23-2012 05:15 AM
Edgeautosport.com has them and @eric@edgeautosport can get you some good prices on mist of these parts
Constantin 04-24-2012 05:49 PM
Really? I didn't do a detailed search yet. Can you post the link to the thread? I in the market for sway bars. Original plan was to go get front and rear...
Constantin 04-24-2012 05:58 PM
Originally Posted by Mizzle (Post 1374977)
STS:
_Ralco RZ 914950
_$118.99
_Ralco RZ Short Shifter MAZDA 3 2007 - 2009 914950 (unless I can bid one down on Ebay.)
I heard that with aggressive shifting with short shifters you are highly increasing the chance to ruin your tranny. To be more specific you are putting a lot of pressure on synchronizers.
I have heard it from reputable source, but I am NO EXPERT! May somebody who know about the possible problems that short shifter can bring can comment here...it will be nice to know for sure.
Mizzle 04-24-2012 09:27 PM
Whoever said a STS ruins your synchros is retarded.
That said, I'm just buying that to replace my stock unit. I'm going to add a 2" extension to bring it back to stock height anyways.
Constantin 04-27-2012 04:56 PM
FSB = no oversteer
Hey, found this thread by @Tomas:
Hotchkis FSB Install
@Tomas sais (post #5) that he does not experience oversteer. In fact he highly recommends Hotchkis FSB.
Mizzle 05-05-2012 02:31 AM
Ralco STS ordered from THMotorsports: $116.61 shipped. :)
Hubcentric rings ordered from EBay - $9.
McGard lug kit ordered - $38 after using AMEX points (from ~$85)
Question:
Why are the spark plug part numbers for 2010 MS3's and 2008 MS3's different?
@Daddy Chinkus - is the shifter a STS because they cut the shaft down or because the linkage connection is longer?
NGK 2008: ILTR6A-8G .032"
NGK 2010: SILTR6A-7G .027"
Obviously the gap, but what else?
mczimer 05-05-2012 09:32 AM
If you are getting an AP, you might as well invest in one step colder plugs. For the OCC....yes, MC's is a great setup, but it isn't anything you can't do yourself. You can install the OCC by the horn bracket, which lets you drain the easiest, or by the CAI (should still fit). When you do install the OCC, you should also clean your valves and do the EGR blockoff at the same time, since it is a seriously big PITA without the I off.
dooderek 05-06-2012 01:28 AM
linkage is but the shifter itself is also shorter
Mizzle 05-06-2012 05:50 PM
Any knowledge on the plug part numbers?
grantmm 05-06-2012 06:25 PM
+1 for TriPoint Rear Swaybar. Their customer service is better than amazing. I'd rather support them then someone who's an ass to anyone who questions their products (JBR).
Mizzle 05-06-2012 06:51 PM
A.) @jbarone is one of the best vendors we've ever had.
B.) My thread is not for bickering.
C.) Anyone that says shit like the following doesn't get to speak unless spoken to:
Originally Posted by grantmm (Post 1391095)
I upshift and downshift without the clutch all the time...
Soo any input on the plugs?
grantmm 05-06-2012 06:57 PM
JBR is also one of the cockiest people ever on the forum.
Shifting a car without using the clutch says nothing about someone's knowledge oor experience with car setup. :smashfreakB:
I'm also not the one who can't use the search function for one of the most commonly discussed maintenance upgrades.
burn813 05-06-2012 07:04 PM
I have the ralco and I have had it on ye car for about a year...... I am pretty happy with it..... Only thing I don't like is I think it is about 1/2 an inch shorter than the twm and when you put the car in reverse it rubs on the shifter boot.... I am on my second shifter boot
Mizzle 05-06-2012 07:39 PM
First off, no one mentions the SILTRA6A-7G.
Second, get off your soap box and fuck off / gtfo.
Do you have a shortened boot? I assume it's where the washer is that retains the boot?
burn813 05-06-2012 08:01 PM
Attachment 59948
Right there
burn813 05-06-2012 08:04 PM
And yes that is the short boot
Mizzle 05-06-2012 09:08 PM
Weird.
Is it something on the inside? I ask because I have a grinder... and mine is already purchased :P
burn813 05-06-2012 10:02 PM
Yeah there is a plastic piece that you could prolly trim down..... I am just to fucking lazy
Mizzle 05-06-2012 11:30 PM
So lazy, in fact, that you can't type two "o's," in "too."
<3
Bosox 05-07-2012 12:22 AM
All these mentions of Matt Damond.. I don't think the guy exists. I think he is made up. Either that or he has been on location with Ben for the last 6 months. The guy reminds me of the R.O.U.S.es or Keyser Söze.
burn813 05-07-2012 06:27 AM
<3
Shit, fuck ..... You are right
He is there, he just hides well @Bosox
Mizzle 05-07-2012 08:00 AM
Hello,
They are very similar, but have different part numbers. The SILTR6A-7G is dealer only. The ILTR6A-8G is the option available for purchase in the aftermarket.
Best Regards,
Andrew Hauenstein Technical & Training Specialist NGK Spark Plugs (USA), Inc
Mizzle 05-07-2012 08:57 PM
Note:
Holy crap, I got my hubcentric rings already.
I bought them on 5.3.2012 for $8.90 with free shipping on they're here... cray.
I highly recommend "aaiautomotiveaccessories," on EBay.
Mizzle 05-08-2012 08:15 PM
McGards came in.
One point of contention: The spline-drive nuts have rotating seats so they don't fuck your wheels up.
The locks that came with it do not.
I'm happy because they'll protect my shit, but still... wtf?
Mizzle 05-08-2012 11:20 PM
Purchased:
Ratings, reviews and specifications for Continental ExtremeContact DW tires
http://www.discounttiredirect.com/pr...conhzb.ang.jpg
Now if only THM would give me a tracking number for my shifter...
Mizzle 05-10-2012 08:52 PM
Originally Posted by Mizzle (Post 1401426)
Hello,
Best Regards,
If that's the case, why are the gaps different?
They are .1mm different. That’s just the way that plug was designed.
Best Regards,
Andrew Hauenstein
Any particular reason you list one for the first-gen Mazda Speed 3 and the other for the 2nd-gen?
(awaiting a response.)
Tires came in already:
http://i305.photobucket.com/albums/n...510_222324.jpg
http://i305.photobucket.com/albums/n...510_222457.jpg
http://i305.photobucket.com/albums/n...510_222557.jpg
http://i305.photobucket.com/albums/n...510_222609.jpg
Mizzle 05-12-2012 01:12 AM
Ralco STS + JBR plate = NEED shifter extension.
Page generated in 0.22265 seconds with 11 queries
