Like Tree3Likes
  • 1 Post By Thepedigree13
  • 2 Post By Varomnia
 Old 11-13-2017, 11:04 PM   #1
AngelJDM2019's Avatar
Posts: 1   (View Stats)
AngelJDM2019 can only hope to improve
Groaned at 5 Times in 1 Post
Default Help a noob lol
So Iím hoping to make my car louder I want to straight pipe the car but leave the stock muffler I have boost gauge and I donít get on full throttle and I donít have turbo control can I still straight pipe with out have engine problems ??
AngelJDM2019 is offline   Reply With Quote
The Following 5 Users Say NO Thank You to AngelJDM2019 For This Un-useful Post:
g00s3y (11-14-2017), rymanmazda (11-15-2017), stockms3 (11-14-2017), Thor Hammer (11-16-2017), Vansquish (11-14-2017)
 Old 11-14-2017, 12:20 AM   #2
KhalidBiary's Avatar
Posts: 34   (View Stats)
KhalidBiary is on a distinguished road
You are going to get slaughtered by so many people by posting this. I'll try to be nice and answer before a roast sesh begins. First, do you use the search feature and YouTube. I've heard guys say that straight pipe sounds like trash. I personally do not want to go around telling people I'm straight piped cuz then you sound like a lil bitch. Our cars have great tone and straight piping will give you a ricey sound. I currently have both resonators deleted with and it sounds phenomenal. As for engine problems , If you mean straight pipe from the cat back with a muffler , all you're doing is getting rid of the resi's. , no engine problems there. So it's not a straight pipe. But once you start messing with the first cat (if I recall correctly ) , then you will run into turbo problems , fuel pressure problems and more.
KhalidBiary is offline   Reply With Quote
 Old 11-14-2017, 01:40 AM   #3
g00s3y's Avatar
Posts: 2,084   (View Stats)
Groans: 412
Another speed that's going to sound like shit...
The Following 3 Users Say Thank You to g00s3y For This Useful Post:
Thepedigree13 (11-15-2017), Thor Hammer (11-16-2017), Vansquish (11-14-2017)
 Old 11-14-2017, 06:28 AM   #4
Sandman978's Avatar
Posts: 1,438   (View Stats)
Sandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the world
As respectfully as I can.
Remove first cat...
Install Magnaflow...
Straight pipe from there to rear of car...
I think that's about all you're ready for...
Fapped over pictures of Laguna Seca
2012 CWP Speed3 |:| Cobb V3 AP |:| Resonator Delete |:| Magnaflow Exhaust |:| 4" Exhaust Tips |:| CorkSport SRI |:| Autotech Internals |:| SnailPerformance
Sandman978 is offline   Reply With Quote
 Old 11-14-2017, 01:33 PM   #5
Db09ms3's Avatar
Posts: 112   (View Stats)
Db09ms3 has much to be proud ofDb09ms3 has much to be proud ofDb09ms3 has much to be proud ofDb09ms3 has much to be proud ofDb09ms3 has much to be proud ofDb09ms3 has much to be proud ofDb09ms3 has much to be proud ofDb09ms3 has much to be proud of
I bought my car used with the 2nd cat deleted and muffler deleted too. Sounds good. Nice and throaty with slight droning at highway.
 Old 11-14-2017, 02:11 PM   #6
nate montoya's Avatar
Posts: 28   (View Stats)
nate montoya is an unknown quantity at this point
I would recommend a second cat delete at the most right now. If you want to actually run a straight pipe which I take as a catless downpipe and 2nd cat delete and maybe resonator delete you are going to need an accessport and upgraded hpfp internals. Atleast internals at the least but I wouldn't risk it. If you don't have the internals and you remove your stock dp get ready for zoom zoom boom. You should be able to get away with jusy a second cat delete though and have a sporty exhaust sound if that's what your looking for.
nate montoya is offline   Reply With Quote
 Old 11-14-2017, 02:28 PM   #7
AveryPlaysBass's Avatar
Posts: 266   (View Stats)
AveryPlaysBass has a brilliant futureAveryPlaysBass has a brilliant futureAveryPlaysBass has a brilliant futureAveryPlaysBass has a brilliant futureAveryPlaysBass has a brilliant futureAveryPlaysBass has a brilliant futureAveryPlaysBass has a brilliant futureAveryPlaysBass has a brilliant futureAveryPlaysBass has a brilliant futureAveryPlaysBass has a brilliant futureAveryPlaysBass has a brilliant future
Groaned at 6 Times in 4 Posts
Though its cheap, a "straight pipe" won't sound as good as a quality exhaust and the only things that will eliminate the highway drone are resonators. Just save and get a quality exhaust, something like an axle back from Ultimate Racing.
It's OK to cry" - Lil B
2012 MS3 w/Tech Package
Engine: CS SRI/Tip, AutoTech internals, Damond Banjo Bolt, CFM Mount, CS Racepipe, Resonator delete, Tuned by FREEKTUNE
Trans: CS insert, CS bushings, Damond Shifter Plate
Suspension: Koni Orange with CS springs, Konig Controls 17x7.5 with 225/45 Conti DW's
Appearance: Plasti Dipped Emblems, Bumper Guard, CS Steering wheel/Shift knob/E-brake handle,dumb stickers
AveryPlaysBass is offline   Reply With Quote
 Old 11-14-2017, 03:23 PM   #8
stockms3's Avatar
Posts: 798   (View Stats)
Groans: 64
Groaned at 6 Times in 6 Posts
You guys are too soft.....
2007 TR MazdaSpeed3:Autotech FP inernals, Cobb AP, Toyota Injector Seals, FR stud mod, FMIC, Fidanza flywheel/stock clutch, Forge BPV, CorkSport Stage 2 RMM, COBB SRI/PG Inlet pipe, Wiseco .20 Pistons/Manley Rods/BSD, DM/ebay catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, CNT catback
Soon to come: CS turbo, TR8 front mount, JBR 3" intake, EBCS, and maybe a clutch.
2005 Mazda 3 SP23: mod include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too.
The Following 2 Users Say Thank You to stockms3 For This Useful Post:
 Old 11-14-2017, 04:39 PM   #9
aackthpt's Avatar
Posts: 1,444   (View Stats)
aackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the world
This thread needs MOAR SARCASM
2013 'speed3, silver
Stage Bro
aackthpt is offline   Reply With Quote
 Old 11-15-2017, 07:06 PM   #10
Thepedigree13's Avatar
Posts: 608   (View Stats)
Thepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the world
Groans: 64
That shit is so full of fail I thought it was one of the OG msf guys trolling out of boredom.
Wtf is a turbo controller first of all. And why boost gauges if you don't go WOT. Matter fact why boost gauges at all unless you just want pretty colors on your cluster.
Bro if you want it louder take the exhaust off completely. Why waste your time straight piping when you could be straight gangsta and go exhaustless.
BOOM.
Db09ms3 likes this.
~2013 BLACK MS3~
COBB: (APV3//Exhaust Hangers)
CS: (TMIC//RP//Leather Knob//Battery Box//Interior LEDs)
JBR: (3" SRI//80 Threesome//SSP//SSB//TB TIG//Coolant Bypass//Rice Flaps, EGR delete, OCC)
Magnaflow CBE//GFB BOV//FREEKY DEEKY OTS+
》》》SUPPORT YOUR MSF VENDORS《《《
Thepedigree13 is offline   Reply With Quote
 Old 11-15-2017, 08:52 PM   #11
rymanmazda's Avatar
Posts: 1,521   (View Stats)
rymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the world
Groans: 115
Groaned at 4 Times in 2 Posts
Fucking damnit. FUCKING SEARCH!
2006 BCM Mazdaspeed 6 GT w/navi
Freektune: 400whp/387awtq
Mods: Cobb AP, MSD Dashhawk, GT3076r, HTP 3" SRI, FMIC w/ tr8, Wiseco Pistons (9.5:1), Manely Rods, HPFP AutoTech Intenals, NJSPEED3 Ported Intake Manifold w/ VCTS Delete, Turbosmart BPV, Grimspeed 3-Port EBCS, NGK Iridium One Step Colder Plugs, 3.0" ATP Turbo Dowpipe w/ high flow cat, Devil's Own Stage 1 Methanol/Water Injection Kit, 50/50 Methanol, ACT 6 puck sprung w/ streetlite flywheel, Block8head vent pod, Prosport Performance Boost Gauge Amber/White, Cipher Auto Harness Bar, Cipher Auto 4-point Racing Harness, BC Racing Coilovers, CP-E rear diff mount, JBR RMM 80A, SPC Front Adjustable Ball Joints, Enkei Raijin Hypersilver 18x8 +45, 225/45/18
-Autocross Setup-
17x8 +38, BF Goodrich R1 225/45/17
Other Rides:
2006 Mazdaspeed6 GT BCM: 114k miles, never modded (Totaled March 2013)
1969 Ford Ranchero: 351 Windsor, Edelbrock 600cfm, fully re-done interior (w/ Grant steering wheel, '91 T-Bird SC racing bucket seats), C-6 Automatic Trans w/ shifter kit, First, body work, then drag racing and dumping money into it.
1969 Pontiac Firebird: 4:11 gears, 28x10 ET Streets (Middle of restoration with father)
1998 Toyota Tacoma 4x4: 174k miles, 5 speed, Fiberglass Baja Front clip, 2in body lift, 4in suspension lift, 33x10 BFG All-Terrains, Custom Smittybuilt Bumpers, Custom Intake (SOLD)
rymanmazda is offline   Reply With Quote
 Old 11-15-2017, 08:54 PM   #12
Varomnia's Avatar
Posts: 388   (View Stats)
Varomnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the world
Yes. You'll want a tune if do a full turbo back straight pipe. And fuel internals. Read your welcome PM. Goes over this shit.
Hope you don't have emissions testing in your area...
ETS TMIC, Cobb TBE, Intake, TIP, AT Internals, JBR trilogy mounts, EBCS, EGR Delete/blockoff, Bosch 3.5 MAP Bar sensor, Stripped interior #racecar
Varomnia is offline   Reply With Quote
 Old 11-16-2017, 05:56 AM   #13
KiwiFlavor's Avatar
Posts: 2,315   (View Stats)
Open down pipe is always the way to go.
2012 NASA Spaceship Gray MS3
 Old 11-16-2017, 07:26 AM   #14
Varomnia's Avatar
Only to be beaten by a open headers turbo delete!
KiwiFlavor and Db09ms3 like this.
The Following User Says Thank You to Varomnia For This Useful Post:
KiwiFlavor (11-16-2017)
 Old 11-16-2017, 03:12 PM   #15
Thor Hammer's Avatar
Posts: 1,297   (View Stats)
Groans: 102
Solid first post ricer. How the fuck can you not have "turbo control"? Do you just blow on a tube off the BCS located next to your steering wheel in between sucking off your passenger? You have no clue what you are doing or talking about.
Waiting for Install: BNR S3/HTP 3.5 Intake/Damond OCC/ CS Injector Seals/ WMI/MAPerformance Rev3 Intake Manifold
HTML code is On
©Copyright 2008 ; 2014 Cymru Internet Services LLC | FYHNô Autosports HQ
Page generated in 0.42042 seconds with 33 queries
