 Old 11-21-2011, 01:25 AM   #1
Tunemanjjw's Avatar
Posts: 14   (View Stats)
Tunemanjjw will become famous soon enough
Default HELP! Reconnected battery, now horn won't stop blowing constantly and car won't start
HELP!
2006 mazdaspeed 6 sport (basic) model
Symptom: When battery terminal is reconnected, Horn blows continuously (no pulsing) and all turn signals are lit solid, instrument panel does not light up, car does not respond to key fob commands or key in the ignition (car does not start consequently), interior lights no go, power windows no go, low beams will not turn on, HIGH BEAMS WILL TURN ON.
Backstory: I removed my battery to tighten up my turbo inlet hose, and when I reconnected the battery there was a lot of constant sparking instead of the usual single spark. I cleaned up the terminal some and when I went to connect it, as soon as the terminal touched, the above symptoms go on until it is unplugged. Also notable, the key was in the ignition in the II position (right before cranking position) the entire time. I've not had any electrical problems with this car EVER. There are no aftermarket alarms or such installed on my car.
What I've tried: I've tried cranking the car with the key in the ignition (this is the normal key, not the valet key), pressing and or holding any combination of buttons on the key fob, the interior light and instrument panel fuses had blown so I tried replacing those, they reblew and no difference.
Curious Angles: did my car think it was getting stolen since the battery was reconnected while the key was in the ignition in the next-to-start position -- is this what is supposed to happen given the circumstances? Did having my key in the ignition II position when I reconnected the battery fry the chip in it making it invalid and henceforth my car does not respond to it?
Is there anything I should try, or does anyone have any light to shed on this? Being my only car, it's going to the dealer sometime tomorrow to address this but I'd love to save some pesos and time if there's a slick fix or suggestion. Thanks
Tunemanjjw is offline   Reply With Quote
 Old 11-21-2011, 01:35 AM   #2
i8urgti's Avatar
Posts: 1,659   (View Stats)
i8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the world
Groans: 267
holy jebus wtf did you do? that sounds like VW problems. nothing i can offer except good luck
2006 LPM MS6 GT (totaled)
0-60 mph : 4.2 second (as per DH)
12.83 @ ???MPH 1.67 60ft
2002 Miata Se (convertible whore)
i8urgti is offline   Reply With Quote
The Following User Says Thank You to i8urgti For This Useful Post:
manelscout4life (11-21-2011)
 Old 11-21-2011, 01:44 AM   #3
Tunemanjjw's Avatar
Don't I wish I knew! Totally bizarre. All
I can think of is some weird ecu/immobilizer response (since I'm not familiar with the effects of making it seem like I am stealing my own car or how to
Blow the chip inside the fob) or maybe when I was tooling around in the engine bay I jammed a wire or harness or something...I didnt brute force anything or stretch any wires doing the TIH tightening so I have no idea! No major surgery here.
 Old 11-21-2011, 02:00 AM   #4
eppopipe's Avatar
Posts: 601   (View Stats)
eppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the world
Groaned at 12 Times in 8 Posts
It sounds like what would happen if you put the terminals on backwards.
Could have nuked the ECU. Take the battery off and disconnect the ECU harness, Drain the whole system and then try hooking it back up. Report back.
2010 Blue Mazdaspeed3
CP-E Nano Intake - JBR 88D Trilogy - Cobb AP - Sure Shortcut - 20% tint - Blox 490g shift knob - Big stereo system (WIP) - Singer 400AMP alternator - Turbosmart dual port - KDM V2 FP Internals - 10k DDM HID's (lows) - 12k HID's (fogs) - UR CBE (no mufflers) - Vibrant Ultra Quiet resonator - CP-E TMIC - UR Resonated Test Pipe - Dano Perm Tune - Blockhead Dual Gauge Vent Pod (painted) - Aeroforce Interceptor x2 - 19 inch RonJon Inspyres
eppopipe is offline   Reply With Quote
The Following 2 Users Say Thank You to eppopipe For This Useful Post:
Bucker (11-21-2011), Raider (11-21-2011)
 Old 11-21-2011, 05:42 AM   #5
Sid3wayS's Avatar
Posts: 6,788   (View Stats)
Groans: 97
Your first problem is that you left all the electronics and pumps on while you disconected the battery... Would you just pull the cord mid way threw the boot up of your desktop? Your secound problem is that like @eppopipe said it sounds like you reversed the terminals. Like he said drain the ecu fully and keep your fingers crossed that you didnt fry anything. Good luck and if you figure it out post it on here.
TEAM LUXURY
Sid3wayS is offline   Reply With Quote
The Following 3 Users Say Thank You to Sid3wayS For This Useful Post:
Bucker (11-21-2011), captain slow (11-21-2011), Raider (11-21-2011)
 Old 11-21-2011, 05:50 AM   #6
MZR165's Avatar
Posts: 273   (View Stats)
MZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the world
There is no slick fix...you've shorted something by leaving the key in the next-to-on position while disconnecting and reconnecting the battery and or by possibly crossing the cables on reconnect. Take it to Mazda...this could be expensive. Sorry.
2007 Mazdaspeed 6 - Hypertech - J Barrone RMM - CS SRI & CS Turbo Inlet Pipe - Kumho Ecsta ASX
TOWER PERFORMANCE ENGINES
"You never get out of the throttle unless you see the timing tower."
“There is no limit to the good a person can do, if he does not care who gets the credit”
MZR165 is offline   Reply With Quote
 Old 11-21-2011, 06:15 AM   #7
Spirry's Avatar
Posts: 700   (View Stats)
Spirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the world
Groans: 31
Groaned at 28 Times in 15 Posts
+1 on the static discharge. Disconnect the battery cables. Touch the two leads together for a few seconds. Wait 10-15 minutes. Reconnect battery cables.
Doubt that will work but give it a try. Just make sure the battery is not connected to anything during the process.
Also, you probably damaged something with a voltage surge...
Spirry is offline   Reply With Quote
 Old 11-21-2011, 06:18 AM   #8
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
If reversed terminal syndrome, the main fuse should have popped, and one of the terminals would have been tough to connect to.
The issue was key on when you disco'd, and that fried something up, as everyone ^ has posted. Keep us posted on what the dealer finds out Might need a $100 ECU reflash to fix it, minimum.
 Old 11-21-2011, 06:21 AM   #9
Tunemanjjw's Avatar
So the terminals were def not connected backwards. I have distinctly different terminals for - and + but I see how this seems like a similarly resultant scenario.
Where do I disconnect the ECU (I haven't tinkered much with this car)
I have disconnected the battery and pumped the brakes several times to drain system and retried with no difference.
 Old 11-21-2011, 07:27 AM   #10
Sid3wayS's Avatar
Groans: 97
The ecu is the 2 big plugs write next to the battery. Each one pops off seperatly by lifting the lever. But if u already drained the battery n no result its likely you fried something. Sorry bro
TEAM LUXURY
 Old 11-21-2011, 07:51 AM   #11
H3llfir3's Avatar
Posts: 255   (View Stats)
H3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the world
its the BCM located in the drivers side cabin fusebox. You more than likely shorted it out.
2006 black Mica MS6 GT- It has tons of shit on it and it's still slow.
NATOR of Florida
H3llfir3 is offline   Reply With Quote
 Old 11-21-2011, 08:00 AM   #12
crazyp's Avatar
Posts: 1,093   (View Stats)
crazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the world
Groans: 68
Groaned at 22 Times in 9 Posts
A friend of mine has an RX8 that did this when we jumped his car. turned out to be an alarm feature. was the door open and ignition on when you installed the battery?
close and lock doors
install batteries.
unlock door with remote
2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC
crazyp is offline   Reply With Quote
 Old 11-21-2011, 11:28 AM   #13
chuckms6's Avatar
Posts: 1,618   (View Stats)
before you get in too deep check ALL fuses and grounds, no matter if you think they are related to the problem or not. sometimes the way a system is wired may cause voltage to backfeed through another unrelated circuit to find ground if its specific fuse is blown. after that and replacing all the blown fuses if there are any disconnect the battery for a while and let the system drain as previously discussed. if you still have problems, THEN take it to the dealership.
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
 Old 11-21-2011, 11:56 AM   #14
captain slow's Avatar
Posts: 5,559   (View Stats)
captain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the world
Groans: 398
Groaned at 50 Times in 34 Posts
I wanna be helpful and an asshole all at the same time. I mean come on, why was the key in the ignition and why was it turned to on???? Try all the previously mentioned things. Other than that, I don't think we can help you here....
captain slow is offline   Reply With Quote
 Old 11-21-2011, 12:00 PM   #15
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,703   (View Stats)
Groaned at 33 Times in 19 Posts
you could disconnect the horn for a start. At least you won;t go deaf diagnosing the problem. lol
MAKE LOVE TO THE CANVAS
WetzMS3 (03-11-2016), _riskibus_MS3 (11-21-2011)
 Old 11-21-2011, 12:06 PM   #16
3mazdaspeed's Avatar
Posts: 485   (View Stats)
3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world3mazdaspeed is the leader of the world
My neighbor had the same problem after her battery died, her husband told her to just drive it around till it stopped. Well she did and it worked out for her.
3mazdaspeed is offline   Reply With Quote
 Old 11-21-2011, 03:58 PM   #17
check your body control module at the drivers footwell. i had the same thing happen to me.
Vansquish (06-17-2013)
 Old 11-21-2011, 04:09 PM   #18
_riskibus_MS3's Avatar
Posts: 180   (View Stats)
_riskibus_MS3 is the leader of the world_riskibus_MS3 is the leader of the world_riskibus_MS3 is the leader of the world_riskibus_MS3 is the leader of the world_riskibus_MS3 is the leader of the world_riskibus_MS3 is the leader of the world_riskibus_MS3 is the leader of the world_riskibus_MS3 is the leader of the world_riskibus_MS3 is the leader of the world_riskibus_MS3 is the leader of the world_riskibus_MS3 is the leader of the world
poltergeist
_riskibus_MS3 is offline   Reply With Quote
 Old 06-17-2013, 09:48 AM   #19
Mistersix's Avatar
Posts: 2,585   (View Stats)
I'm having the same issue after installing tail lights after a paint job. I crossed something and got a short and the horn blares and 4 ways blink etc. What ended up being the fix for you? How do you check the bcm?
 Old 10-13-2014, 09:25 AM   #20
teddy's Avatar
Posts: 3   (View Stats)
teddy is an unknown quantity at this point
Default mazda3 all lights, horn and wipers on everything else is dead...
Hi guys,
I have a similar problem: I just replaced the battery on my 2006 Mazda3 GT and when re-connected, all lights and horn are solid on. Everything else is dead. No dashboard light, nothing... I tried to open the trunk with the key - it didn't work. I tried open-close/open-close sequence on the driver's door with the key. Doesn't work. I tried to put the key in on position and then re-connect the battery: doesn't work either. But, in this case, with the battery still connected, I turn the key to off position and now the wipers stopped.
Can anybody help me with some ideas...?
Kindly appreciated!
teddy is offline   Reply With Quote
 Old 10-13-2014, 09:33 AM   #21
thehead's Avatar
Posts: 1,141   (View Stats)
thehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the world
Groans: 143
to turn off the alarm, you stick your key into the driver's door, and turn the key to the unlock position until it stops.
2016 BMW M235i
[Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles
Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals
Electrical - GS EBC - Cobb AP Richtune in progress
Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's
Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40.
thehead is offline   Reply With Quote
 Old 10-13-2014, 09:35 AM   #22
teddy's Avatar
tried that, it didn't work... ;(
 Old 10-13-2014, 02:22 PM   #23
teddy's Avatar
I also found that the "ROOM" fuse is blowing up each time I re-connect the battery.
 Old 03-11-2016, 03:17 PM   #24
hza47's Avatar
Posts: 1   (View Stats)
hza47 has a little shameless behaviour in the past
BUMP
Has anyone had any luck figuring out this issue?
hza47 is offline   Reply With Quote
The Following User Says NO Thank You to hza47 For This Un-useful Post:
 Old 03-11-2016, 06:32 PM   #25
Say Chi Sin Lo's Avatar
Posts: 861   (View Stats)
Say Chi Sin Lo has disabled reputation
Groaned at 62 Times in 28 Posts
Sorry to laugh, but this sounds like something the guys at the (old) Top Gear would do. Hahahahaha
Say Chi Sin Lo is offline   Reply With Quote
 Old 03-11-2016, 07:41 PM   #26
sh4d0w's Avatar
Posts: 565   (View Stats)
sh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the world
Groans: 45
Groaned at 7 Times in 4 Posts
O.K. So obviously something is shorting out that's on the room circuit. Disconnect everything that runs in the room circuit one at a time until the room fuse doesn't blow when you turn the key on. Might cost you a bit in fuses but at least you should end up finding the issue.
Or just disconnect everything that runs on the fuse and just start connecting things one at a time until it blows. This is prolly cheaper lol.
lol i'm answering a 2 year old question nice.
2010 Black MS3
Cobb AP // Cobb EBCS // Cobb Downpipe // Cobb RMM // JBR Tru 3.5'' Intake // JBR TMM // JBR PMM // JBR RSB // CP-E Cat Back // NGK One step colder plugs // GT 3071r // Azenis 615k // Bilstein PSS B14 Coilovers // Treadstone TR8 FMIC // Bully Stage 4 Clutch // Damon EGR Delete // Autotech HPFP // AEM V1 Meth Kit 50/50 // Freektuned 94 Oct
Last edited by sh4d0w; 03-11-2016 at 07:41 PM. Reason: MSF Database - Automerged Doublepost
sh4d0w is offline   Reply With Quote
The Following User Says Thank You to sh4d0w For This Useful Post:
blackms3_71 (03-11-2016)
HTML code is On
Some Ford models get start-stop in 2012 Haltech Automotive News 0 12-26-2010 10:10 PM
2011 BMW M3 to get start-stop tech Haltech Automotive News 0 07-13-2010 05:20 PM
How to Stop Car Battery Drains: DIY Auto Haltech Automotive News 0 06-07-2010 11:50 AM
Kia eyes 15% fuel savings from new stop-start engine Haltech Automotive News 0 01-14-2009 01:30 PM
All Smarts to get start-stop standard Haltech Automotive News 0 07-11-2008 02:50 PM
Page generated in 0.45348 seconds with 40 queries
