 Old 01-12-2011, 10:09 PM   #1
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Default HP limit with cobb Sri maf ?
What would be the HP limit of say a cobb Sri ? Before needing a bigger maf set up. ?
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 01-12-2011, 10:13 PM   #2
2zz mr-s
dooderek's Avatar
Posts: 5,116   (View Stats)
Groans: 239
till you get a turbo with a bigger inlet
The Following User Says NO Thank You to dooderek For This Un-useful Post:
FreeFlyFreak (01-12-2011)
 Old 01-13-2011, 12:03 AM   #3
jracer's Avatar
Groans: 89
Well I guess 350-400 HP .. Since Lenny / driver311 are around those numbers
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 01-13-2011, 12:19 AM   #4
m4tic's Avatar
Posts: 4,922   (View Stats)
If you have to ask... Not yet grasshoppah
2007 MS6 w/ Cheez
The Following User Says Thank You to m4tic For This Useful Post:
jracer (01-13-2011)
 Old 01-13-2011, 01:03 AM   #5
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
i think 370-380whp would be the cut off. problem is once u hit that cut off its gonna be a nasty drive
The Following User Says Thank You to rodrigo For This Useful Post:
jracer (01-13-2011)
 Old 01-13-2011, 02:04 AM   #6
jracer's Avatar
Groans: 89
I think I would be happy with 375 HP
Maybe one day ! Just need to save to build my other motor...
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 01-13-2011, 02:39 AM   #7
EwMPS's Avatar
Posts: 140   (View Stats)
EwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond repute
I'm going to run the Cobb SRI with a customs made TI for my GT30, hoping this will work...
EwMPS is offline   Reply With Quote
The Following User Says Thank You to EwMPS For This Useful Post:
jracer (01-13-2011)
 Old 01-13-2011, 04:34 AM   #8
gtarman77787's Avatar
Posts: 1,872   (View Stats)
gtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the world
Groans: 444
Groaned at 154 Times in 97 Posts
someone please correct me if i'm wrong -- and i'm just speaking from SOME possible knowledge...
but my understanding is if you run a reduction coupler... lets use easy numbers... like 4" tubing to a 3" tubing, you'll only really get to use the full capacity and flow of the 3" and the 4" tubing isnt really serving its purpose...
now if you run a 3" with a coupler that brings it to 4" -- like your picture -- aren't you only going to get whatever air comes through the 3" and not fully fill up the 4" TIP?
in other words...
from my first example, if you take 20 cubic inches from a 4" tube and try to put it in a 3" tube, you'll probably only get about 15 cubic inches to fit inside
from my second example, if you take 15 cubic inches from the 3" tube and try to fit it in the 4" tube, you'll still only have 15 cubic inches
some one please correct me if i'm wrong -- but thats just my logic and simple knowledge of space consumption
gtarman77787 is offline   Reply With Quote
 Old 01-13-2011, 05:30 AM   #9
TRex's Avatar
Posts: 3,139   (View Stats)
TRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the world
Groaned at 106 Times in 69 Posts
well...speaking from a flow perspective (using bernoullis equation)...and assuming your flow rate stays constant....increasing the cross section will cause the velocity of the fluid to decrease and a pressure increase...you will have the same volumetric flow rate (and the same mass flow rate assuming your density hasnt changed)...ie...the volume of air in the 3" pipe has expanded to fill the 4" pipe and in doing so has slowed down...you are always going to fill up the container you are putting the air in...by its nature air will expand to fill whatever it is in...but something will change...whether that be velocity or density or whatever....it all depends on the conditions....now...what does that mean for the turbo and why you wouldnt just stick with a constant 4" or 3" pipe...that I am unsure of
but i think what you want to do is minimize your pressure drop across the intake track...if you go from a 2" sri to a 4" inlet you are going to have a huge pressure drop...where if you go from a 4" to a 4" you will have no pressure drop and that is most efficient...
so what that means is ideally...you want an intake track the EXACT same cross section as your turbo inlet (the inlet on the turbo itself)
see attached hand calcs and see if they make sense....
TRex is offline   Reply With Quote
The Following User Says Thank You to TRex For This Useful Post:
gtarman77787 (01-13-2011)
The Following User Says NO Thank You to TRex For This Un-useful Post:
FreeFlyFreak (01-13-2011)
 Old 01-13-2011, 05:35 AM   #10
Groans: 444
Originally Posted by TRex View Post
well...speaking from a flow perspective (using bernoullis equation)...and assuming your flow rate stays constant....increasing the cross section will cause the velocity of the fluid to decrease and a pressure increase...you will have the same volumetric flow rate (and the same mass flow rate assuming your density hasnt changed)...ie...the volume of air in the 3" pipe has expanded to fill the 4" pipe and in doing so has slowed down....now...what does that mean for the turbo and why you wouldnt just stick with a constant 4" or 3" pipe...that I am unsure of.
thank you for nerd-ifying that -- and thats EXACTLY what i was going for
but seriously thank you lol -- i'd like to understand, myself, if there are any benefits or disadvantages to the increase in cross section
 Old 01-13-2011, 05:58 AM   #11
TRex's Avatar
updated post with how i think the changes in cross sections will affect things
 Old 01-13-2011, 06:39 PM   #12
Groans: 444
bump this -- can anyone verify this data please?
 Old 01-13-2011, 07:09 PM   #13
you can only flow as much as your greatest restriction will allow, unless u use force but u dont have anything pushing on the inlet side of the turbo
jack_hammer (01-14-2011)
 Old 01-13-2011, 07:16 PM   #14
Danish's Avatar
Posts: 595   (View Stats)
Danish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the world
Groaned at 249 Times in 46 Posts
Wouldn't worry about it until you get there.
My throttle body was the biggest choke point on my last car. I had a MAP setup after I realized MAFs are garbagio.
Danish is offline   Reply With Quote
 Old 01-14-2011, 04:08 AM   #15
Groans: 444
FFF -- you groaned TRex, care to explain why?
if you have a better way of explaining, lets hear it -- i'd honestly like to educate myself on this
 Old 01-14-2011, 05:15 AM   #16
TRex's Avatar
me too....that was just my scribbles on the subject of how i thought it would work....it would be good if you could enlighten me
 Old 01-14-2011, 10:45 AM   #17
TRex's Avatar
bump...
gtarman77787 (01-14-2011)
 Old 01-17-2011, 04:06 AM   #18
Groans: 444
bump bump bump it up for FFF
HTML code is On
stock turbo limit tiness69 MazdaSpeed 3/6 - Turbo Induction 18 04-14-2010 09:55 AM
Cobb Accessport flash remove boost limit in 1st and 2nd? TongMan MazdaSpeed 3/6 - ECU Computer Tuning 24 11-20-2009 06:21 PM
Flashing Limit? 100? Fobio
Cobb ATR Support
4 04-29-2009 07:19 PM
Boost Limit in 1st/2nd gears Super Unique MazdaSpeed 3/6 - ECU Computer Tuning 3 10-26-2008 05:12 PM
what is the limit??? protur03 MazdaSpeed 3 - Engine, Transmission & Driveline 4 10-18-2008 05:47 PM
Page generated in 0.38206 seconds with 29 queries
