-   Mazdaspeed3/6 General Discussion (http://www.mazdaspeedforums.org/forum/f505/)
-   -   Injector Seal question? (http://www.mazdaspeedforums.org/forum/f505/injector-seal-question-200458/)
racersir 04-01-2016 05:57 AM
I'm installing the Toyota seals tomorrow. I was planning on using the same o- rings that go to the rail the blue ones since I don't have them available locally. Do you guys replaced the blue o-rings also or can I use the same ones if they're in good condition? Thanks
Code Monkey 04-01-2016 06:03 AM
If they are in a good condition, reuse them. Make sure to lubricate them (I use gas) before popping the fuel rail back in.
anavrinIV 04-01-2016 06:19 AM
they're fine to reuse but be careful when you install them. If you tear them they're stupid expensive.
I used a little vaseline when I did mine and got them all on no problem
racersir 04-01-2016 11:29 AM
Thanks for the help
Page generated in 0.17262 seconds with 11 queries
