Kinda Freaking Out I cannot seem to find really any threads about running a 18x8.5 with 48mm offset rim (w/ 225/45r18 tire) on a speed6. I bought them out of impulse at last minute, because they were so cheap and clean; got them on craiglist. Btw I am running stock suspension ..... So far i've read that my suspension might rub on part the wheels, but before I bought them I stupidly trusted a guy at American Tire who said I can pull it off with no problems. If you wondering what the wheels are they are xxr 518's. :sad2: thanks, |
probably not a big deal. |
Yea thats what I was thinking after I just put them on to see how they will fit. I still have around a finger width between the suspension parts and the tire (which is the same on my stock tires and rims). |
I'm running 18x8.5 with a +38 offset and the same tire dimensions as you are and am not having any problems on my speed3. Keep in mind however my fenders are rolled flat in the rear. |
Yea I found a lot of people running my setup on a speed3 but nothing on a speed6. Haha Im only freaking out because Im running on a budget, and don't have time to play around until summer. |
is anyone running this setup on a speed6? :x |
1 Attachment(s) Quote:
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2 |
Btw do you think I should roll my fenders a little? :usa: |
went from 215 45's to 225 45's on my speed6 a few days ago..that lasted all of 14 hours and 5 miles (home..and back to discount tire)... I immediatly took em back..doing a even trade for 225 40's...BUT i'm lowered. since you still on 4x4 mazda offroad suspension you are prolly ok. |
same here, 18x8et40 and was running 225/45r18 on stock suspension. rubbed with rolled fenders, too tall of a tire. |
ahhh but you think it makes a difference that i'm running a speed6? |
18x8.5 ET45+ here. Initially had 225/45-18. Rear fenders rolled. No rubbing at all. Just swapped to 235/40-18 with rubbing only on low dips in the road. |
Correct. |
Kinda Freaking Out 18 x 8.5 et 45 with 245/40 tires on KW V1 coilovers. My rears are rolled & pulled and I still rub under hard compression. EDIT: just noticed OP has a MS6 and I have a GenJuan MS3. Nevermind. |
Worse comes to worse ...get a baseball bat, a cloth and a heat gun and roll your rear fenders. I was running some +35 offsets and they rubbed baaaad before I rolled. If you run a +48 you will be fine. I think that's close to stock ... maybe they were +55 i cant remember. If you feel a bit of rubbing, go to home depot, buy a heat gun, borrow a baseball bat and get a towel and roll your fenders. Return the heat gun :) FREE Fender Roll. |
This is brilliant |
Thanks everyone |
[QUOTE=15driley15;1988950]This is brilliant[/QUOTE] cant take xredit. TiGray posted that tip ages ago :-) i just happened to be to cheap to rent a fender tool |
| All times are GMT -7. The time now is 01:00 AM. |
