Notices
Like Tree7Likes
  • 1 Post By chimmike
  • 1 Post By zpele
  • 1 Post By CWP_MS3
  • 1 Post By zpele
  • 1 Post By weakdog85
  • 1 Post By ricknm
 Old 08-22-2012, 09:36 AM   #1
ESB Jiu JItsu's Avatar
Posts: 494   (View Stats)
ESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the world
Groaned at 4 Times in 2 Posts
Default MAF wiring diagram
So in continuing my goal of blow through maf on stock tune I have decide to try and relocated the ait sensor to read my actual intake temps vs now my blow through temps aka boost temps. Even though i do not see much change in range of temps and or any erratic changing of temps this seems to be where most people thing the bottle neck is. I do believe this may help is solving the fuel cut issue im seeing at WOT. Just too much fuel due to the colder readings at the new maf location. So does anyone have any wiring info diagrams pics or ms paint drawings showing which wires are used for ait on the sensor so i can pull those and wire them up to my new sensor.
The sensor i intend on using is either one from a ford lighting
9C1Z-12A697-B (sensor) & 3U2Z-14S411-JZA (pigtail)
I already have a hole in the intake pipe im using where the crankcase line once attached so the plan would be to install this sensor in that spot and hard wire it in.
any questions and comments are welcome as most of this is just speculation based off advice from others on the board and my researched knowledge. also any cheaper ait solutions that will work are awesome as well
Hopefully if i do everything cleanly i could try this out and if it doesn't work just return the parts and revert back and try again LOL
AND YES IF I HAD A COBB AP I WOULD NOT HAVE TO DO ANY OF THIS BUT IM A BROKE AS AND SHIT WHY NOT SEE IF I CAN FIGURE OUT A STOCK TUNE BLOW THROUGH IF IT WORKS THEN YEY IF NOT THEN BOO ON TO THE NEXT
2006 Mazdaspeed6 GT Liquid Platinum Metallic
"because racecar!" " I love this $%&*ing car"
-Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps
-2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete
-TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender
-Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod
-Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge
ESB Jiu JItsu is offline
The Following 2 Users Say NO Thank You to ESB Jiu JItsu For This Un-useful Post:
Easter Bunny (08-22-2012), zpele (08-22-2012)
 Old 08-22-2012, 09:40 AM   #2
Will fuck up ur day
chimmike's Avatar
chimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the world
Groans: 418
Groaned at 206 Times in 122 Posts
donate motherfucker, they're in VIP.
ESB Jiu JItsu likes this.
07 MS3 bone stock?
The original Genpoo Hater
GTX3076r
FenderRollerRental Rent a fender roller, or MZR DISI Timing tools!
Originally Posted by woodfloor View Post
According to Roddiy, A List of Things as funny as fucking with MSF:
  1. Pissing in a bee hive
  2. Bridging the bus bars in an electrical panel with your dick
  3. Running with the bulls
  4. Willingly climbing into the lion habitat at the Zoo
  5. Shooting yourself in the foot on purpose
  6. Jumping up and down on a Fire Ant hill
@kyle undefined loves giving blowjobs to @raider; in truckstop bathrooms
chimmike is online now
The Following 3 Users Say Thank You to chimmike For This Useful Post:
CWP_MS3 (08-22-2012), ESB Jiu JItsu (08-22-2012), Sid3wayS (08-22-2012)
 Old 08-22-2012, 09:42 AM   #3
zpele's Avatar
Posts: 1,611   (View Stats)
zpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the world
Groans: 344
Groaned at 210 Times in 107 Posts
God your dumb.
COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy
zpele is offline
The Following 3 Users Say Thank You to zpele For This Useful Post:
CWP_MS3 (08-22-2012), Easter Bunny (08-22-2012), ESB Jiu JItsu (08-22-2012)
 Old 08-22-2012, 09:45 AM   #4
SFLA Nator's Toretto
Sid3wayS's Avatar
Posts: 4,483   (View Stats)
Groans: 56
Your fuel cut is probably from a lack of fp internals. And nothing you do with the ait sensor will change that.
2010 MS3 W/tech pkg Liquid Silver-Still Slower Then An Asthmatic Snail
Full Race:Verticle Flow fmic//HTP:3" Inatke//ATP:Catless DP
JBR:Holy Trinity,Rsb,Tigs//Forge:v.2 BPV//NGK:Plugs//AutoTechs:FP Internals
PTP:Seals&studs//Bosch:3-Bar//Grimmspeed:3-port EBCS//Stratified:G.A.//KW:v.1's//RotaGrids:18x9.5+38
Meth//E85//Nitrous Tunning by ms3blackmica
Sid3wayS is online now
The Following 3 Users Say Thank You to Sid3wayS For This Useful Post:
chimmike (08-22-2012), CWP_MS3 (08-22-2012), ESB Jiu JItsu (08-22-2012)
 Old 08-22-2012, 09:56 AM   #5
Can be bought...
CWP_MS3's Avatar
Groans: 103
Groaned at 33 Times in 27 Posts
Subbed for fail and told-you-sos
CP-e S2 RMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE //
Ebay Downpipe // Cobb AP // Autotechs // PG TIP // TurboXS BOV // NGK Iridiums
Rich Tuned
326WHP and 361TQ
4-13-13 Moore Automotive
CWP_MS3 is online now
 Old 08-22-2012, 11:34 AM   #6
Originally Posted by zpele View Post
God your dumb.
thanks! No need to be an asshole but thats on you!
 Old 08-22-2012, 11:46 AM   #7
internals are fine and working well as far as i can tell. staying well about 1600 in wot. The only time it wasnt is when i had boost leaks and thats not an issue anymore.
Also so your saying the air temps are not used AT ALL to determine the A/FR? thats not what i have read from others posts..... please educate me! Also i think i am really seeing load cut and i heard load can increase as AFR values increase without proper tuning and since i dont really need my AFR to change its just doing so because it thinks its seeing cooler temps now with the ait sensors new location.
Im just trying to learn here folks. I never said i think i know everything im just trying something new. i have seen similar success so why not give it a shot. If i blow its on me.... so im not sure why some people feel the need to be so rude when it comes to posting. If i fail thats a success and if i succeed thats a success as long as i learn from it either way and thats what im attempting to do. I will take it till i cannot any farther and learn learn learn. So hate on me, thats cool but im just trying. So good i cant wait for the i told you sos! but i will say i hope they come from me ! lol but probably not and thats cool too
 Old 08-22-2012, 11:58 AM   #8
zpele's Avatar
Groans: 344
You sound like a pussy. Don't waffle and trust yourself or do what we tell you to. Don't stay in between you pansy ass muffintop.
Also, I am an asshole and will continue to be one if your ideas continue to be stupid.
Also, your stupid.
zpele is offline
The Following 2 Users Say Thank You to zpele For This Useful Post:
 Old 08-22-2012, 12:04 PM   #9
Also, your stupid.
Off Topic:
Awesome! Thanks! your input is EXTREMELY helpfull
Back on topic:
btw i think i really mean density of air vs temp. I think the hotwire on the maf is having a harder time adjusting to the new air density blow through then it was draw through.
 Old 08-22-2012, 12:11 PM   #10
zpele's Avatar
Groans: 344
Still stupid. I will now post random useless shit.
zpele is offline
The Following User Says Thank You to zpele For This Useful Post:
 Old 08-22-2012, 12:16 PM   #11
thats actually awesome I love cucumbers and cucumber sandwiches. I wonder how they grew them like that and if they can go blow through on a stock tune.....hmmmmmmm ait sensor relocate maybe?
 Old 08-22-2012, 12:19 PM   #12
Can be bought...
CWP_MS3's Avatar
Groans: 103
How do you know what your FP is if you don't have an AP?
Rich Tuned
326WHP and 361TQ
 Old 08-22-2012, 12:38 PM   #13
08.5MS3's Avatar
Posts: 3,272   (View Stats)
Groans: 69
Groaned at 37 Times in 26 Posts
DashHawk.
COBB AP (Hypnotic Tuned) : CP-E Nano : CP-E Nviscid : ETS TMIC : COBB XLE BPV : AT Internals : GrimmSpeed EBCS : CorkSport TBE
TWM STS : TWM Shifter Bushings : SURE CounterShift : CP-E Stage 2 RMM : CP-E 75 PMM : CP-E 75 TMM
Hotchkis RSB : Matt Damond OCC : Bnoon Banjo Bolt
: ITV-22 : JBR TB & IM TIG
328/355 - R/T Tuning - 10/1
3/12
08.5MS3 is offline
The Following User Says Thank You to 08.5MS3 For This Useful Post:
 Old 08-22-2012, 12:41 PM   #14
Can be bought...
CWP_MS3's Avatar
Groans: 103
Originally Posted by 08.5MS3 View Post
DashHawk.
Ah, didn't see mention of it.
Rich Tuned
326WHP and 361TQ
 Old 08-22-2012, 12:51 PM   #15
I have an AP to monitor but it is not mine to use to tune with. Also i have dashcommand and torque to monitor on my phone on off times when i cant use the AP. So I can see that the only differences after going blow through is slight change in AFR, and in maf voltage. But i think both of those slight changes are combining to give me load cut at WOT on the stock tune. Also both of those figures are probably also causing a bit of overboost as i can tell the car is making more power and much faster (500rpms to be exact) car runs amazing just not under WOT even pegging 14 psi is good but as soon as i go WOT its just too much and hit load cut. its just obviously too much for the stock tune but if I can reduce the factors that are leading to the load cut i can back my way into it and possible run WOT on the stock tune. Honestly if you drove my car pre blow through and post you would be chasing this setup too! It runs so much better besides WOT its insane. No after fires, clean smooth idol, runs much smoother and no dips in part throttle acceleration. Really made a big difference, thats why i hate to be so close....and yet so far (without a tune).
The Following User Says Thank You to ESB Jiu JItsu For This Useful Post:
08.5MS3 (08-22-2012)
 Old 08-22-2012, 01:09 PM   #16
Will fuck up ur day
chimmike's Avatar
Groans: 418
how can you connect an AP to the car and not marry it for inspection? Doesn't work that way.
oh.
forgot Jonny Quest
07 MS3 bone stock?
GTX3076r
 Old 08-22-2012, 01:35 PM   #17
you can unmerry it from a car and save that tune on your computer then merry it to another car to use but then you have to unmerry it once more and merry it back to the original car and upload the tune again. So basically you have to find one of the nicest people in the world to go through all that shit so you can test and tune your car every few days lol. But he is also interesting in going blow through and he actually could once he gets a FMIC. but for now he is watching and helping me and also providing his AP!
I just read something else that i found interesting... so i remember the old school resistor trick inline with the IAT sensor to false the reading of the IAT to increase timing. Could i not technically do this but to pull timing as well? Any electric gurus out there?
this is what im talking about......
Tuning For Mileage
also i ran across this which seem to help change afr
http://forum.mazda6club.com/mazdaspe...-question.html
any insight is appreciated learning the best i can Read...Search....Read.....Ask....Read more
 Old 08-22-2012, 01:42 PM   #18
Sid3wayS's Avatar
Groans: 56
Are you just monitoring or actually taking logs. I never said the ait does not affect the afr I said the ait will not affect a fuel cut caused by failing internals. If you are simply monitoring and not logging then it is very possible that you are indeed dropping below 1600 because the sample rate is not the same for logging and monotoring. Like I said in your other thread Im all for doing things diferently but make aure you know how your car is reacting precisely and dont just make assumptions because "it feels good".
 Old 08-22-2012, 01:58 PM   #19
I am logging its just the last logs i posted in my other thread directly related to the blow through setup I had a boost leak. So i am well aware of whats going on and honestly the logs do not look that different from stock just a bit higher volts, afr, and boost. Hope to have more stable logs this weekend, because she is boosting like crazy. And yeah i keep saying fuel cut but i think its load cut, which i know essentially are the same but I believe Im hitting load values too soon and then over boosting on top of it due to FMIC and blow through. But i figured if i can calm down my afr then the timing will reduce and boost will calm and load values will lower allowing me to zoom zoom and no boom boom or cut at all.
So basically im simply trying to figure out a way to lean the car out just a bit without using a tuner and i feel this will level everything out for me.
 Old 08-23-2012, 08:30 AM   #20
broke mans cobb AP?
Potentiometer Potentiometer
inline with e ait sensor to vary resistance and change afr values based on hotwire ait readings..... lol .....dreaming?
 Old 08-23-2012, 08:46 AM   #21
weakdog85's Avatar
Posts: 385   (View Stats)
weakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the world
Groaned at 15 Times in 3 Posts
jesus f christ. i thought this board was for informational help and not about people throwing every fucking idea out the window before trying every possibility. You're all going to feel real fucking stupid when we get this project to work I have been there almost every step of the way with this build from the start of the blow through. Believe me when i say he's done his research, we are monitoring everything we possibly can and logging everything for comparison.
Fuel pressure isn't the problem. I really feel it's load cut as well because stock maps cut fuel at just over 2.0 load around 3k and his logs showed a load of over 2.0 with a boost leak. now that the leak is fixed wouldn't it make sense he's over loading the stock commands. he wasn't seeing load cut with the boost leak.
we're not noobs when it comes to our platform so go harass someone else and stop wasting board space with your useless shit. it really only motivates us to shut you up.
07 MS6 Sport.............
JBR SSP * JBR Shifter Bushings * JBR RMM * SURE SRI * VG Sharkfin Antenna * 20% Tint * Cobb AP * Grimmspeed EBCS * Coolant Bypass * PG TIP *
weakdog85 is offline
The Following User Says Thank You to weakdog85 For This Useful Post:
ESB Jiu JItsu (08-23-2012)
The Following User Says NO Thank You to weakdog85 For This Un-useful Post:
chimmike (08-24-2012)
 Old 08-23-2012, 08:55 AM   #22
No friends from 9-5
ricknm's Avatar
Posts: 766   (View Stats)
ricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the world
OPs posts are extremely long.
2012 CRYSTAL WHITE PEARL
tuned by RFINKLE2 w/ 4gallon E85 mixture
soon to be BNR powered
ricknm is offline
 Old 08-23-2012, 08:56 AM   #23
hahahahahaha! just call us the broke ass builders!
please read them though i have lengthy explanations but I could certainly use advice if you have the time. thank you!
Last edited by ESB Jiu JItsu; 08-23-2012 at 08:56 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-24-2012, 06:01 AM   #24
ryein7's Avatar
Posts: 54   (View Stats)
ryein7 has much to be proud ofryein7 has much to be proud ofryein7 has much to be proud ofryein7 has much to be proud ofryein7 has much to be proud ofryein7 has much to be proud ofryein7 has much to be proud ofryein7 has much to be proud ofryein7 has much to be proud of
Modding 101: Do not mod if you cant afford to do it correctly.
06 MS6- GT2871r, TR11 intercooler, AT internals, ATP DP, JBR TMM, AWR RMM,
ryein7 is offline
 Old 08-24-2012, 06:13 AM   #25
Thats rule number one? i thought it was righty tighty lefty loosy Thanks!
Just had a nice break through..... found some info on the MAF
MAF
So I have a few ideas i will be trying.
 Old 08-24-2012, 06:21 AM   #26
Scammer Hunter
Raider's Avatar
Posts: 15,296   (View Stats)
Groans: 462
Groaned at 110 Times in 93 Posts
God your dumb.
*you're.
OP, you should have cleaned the MAF before even posting. The manual is in VIP. Donate, you will have access. I swear i have had to tell you this before, too.
Fuck this thread.
1) Looking to Buy a used Mazdaspeed? Read this!
2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here.
3) Wanna buy and sell here? DONATE for VIP
4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting!
5) Help MSF grow with FAQ threads!?
Raider is offline
The Following 2 Users Say Thank You to Raider For This Useful Post:
chimmike (08-24-2012), zpele (08-24-2012)
 Old 08-24-2012, 06:21 AM   #27
Will fuck up ur day
chimmike's Avatar
Groans: 418
All I see is "we're trying all these ghetto ass ways to get around stock tune limitations because we're broke but we wanna make big power"
I've been in the game long enough to know that the saying "you gotta pay to play" is NO FUCKING JOKE.
If you can't afford an AP, you pretty much have no fucking business modding this car beyond an intake. This is fact. The AP addresses every single issue you're working on in one fell swoop.
You can have 2 things, and only two of the following: cheap, fast, reliable
you can be cheap and reliable, but not be fast
you can be cheap and fast but not be reliable
or you can be fast and reliable but not be cheap.
make your fucking choice.
Blackedout1978 likes this.
07 MS3 bone stock?
GTX3076r
atvfreek (08-24-2012), SKiZ0TT (08-24-2012), zpele (08-24-2012)
HTML code is On
NON BOSE wiring diagram mrmonk7663 2010 MS3 - Car Audio & Electronics 14 07-05-2012 07:48 AM
Electronics/Wiring Diagram? T3k3l CX-7 > Car Audio & Electronics 3 04-13-2012 06:07 AM
Anybody with an MS6 AND an MS3 wiring diagram book... ATE BALLER MazdaSpeed 3/6 - ECU Computer Tuning 13 06-05-2009 02:43 PM
Need apexi afc neo wiring diagram??? (help please) thisguymengy MazdaSpeed 3/6 - ECU Computer Tuning 4 12-11-2008 08:04 AM
Page generated in 0.50197 seconds with 29 queries
