![]() | ![]() | #1 | ![]() |
![]() Join Date: Aug 2014
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
(Thread Starter) | ![]() ![]() ![]() |
![]() | ![]() | #2 | ![]() |
![]() Join Date: Feb 2012 Location: Bryan, TX
Rep Power: 5045 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,689
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|Trofeo R|ACE 350|flex fuel|Delicious tuned | |
![]() | ![]() | #3 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Thanks that thread is just what I was looking for. Not sure if I want to go the alternator route though but I saw that an mx-5 non ac idler pulley will work with an 87.5 belt. Worth a shot ac's been out for 3 days and just want to get it back on the road as of right now. Thanks for the thread! |
![]() | ![]() | #4 | ![]() |
![]() Join Date: Aug 2012 Location: Mundelein, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 322
| ![]() ![]() ![]() I believe that dorman makes an a/c bypass pulley that will work. It's cheap too. The 2001 ford ranger was the first use of the mzr/duratec 2.3 block. The a/c compressor on those blocks is a 3 bolt design and the block only had 3 bolt holes. Our version of the block has a 4 bolt hole pattern. I have a ranger 2.3 block with the 3 bolt holes in my 07 focus and the 4 bolt compressor bolted in perfectly just using the 3 bolts. I am not 100% sure on this but check out dorman part number 34184 it is a bypass pulley for the 2001+ ranger 2.3 dohc. It could very well work for our cars. It's only about $30 and if it does not work for you you could always return it.
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! |
The Following 2 Users Say Thank You to Turbo_Steve For This Useful Post: | Code Monkey (08-14-2014), redneck4Christ (07-28-2016) |
![]() | ![]() | #5 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Thanks I just looked it up at my local parts store and they do have that bypass pulley in stock. Like you said it's only around $30 and if it doesn't work I'll drive the 2 miles and bring it back. If it doesn't fit I'll mark it and go from there. Either way I'll def let you know what works and what doesn't. Thanks for your help. |
![]() | ![]() | #6 | ![]() |
(Thread Starter) | ![]() ![]() ![]() It does fit, kind of. I need to thread out the mounting position on the block. One of the 3 holes the bracket lines up with is sealed off. Not exactly a surprise as the block has been used by many different models over the years. Tap it out in the morning and go from there. Also the spacer seems a little narrow so picking up one that is a little wider. 3rd issue is the bolts are a little long by roughly a 1/4''. This will work just needs to be worked on a bit but nothing serious. Really appreciate your help on locating the right pulley though it's a huge help. Let you know how it works out when I fire it up, finally. |
The Following 4 Users Say Thank You to Ams1265 For This Useful Post: |
![]() | ![]() | #7 | ![]() |
| ![]() ![]() ![]() Post up some pics of it installed. Thanks
![]() | ![]() | #8 | ![]() |
![]() Join Date: Jun 2016
Rep Power: 0 ![]() Thanks: 0
The Following User Says NO Thank You to tony mongell For This Un-useful Post: | g00s3y (07-28-2016) |
![]() | ![]() | #9 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 1041 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,234
Groans: 131
| ![]() ![]() ![]() Maybe PM the previous poster? Chances are just about 100% he is not following a thread now almost two years old.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2, EPL tune, JHM overdrive crank pulley, ZF8 TCU tune, aFe/034 intake, modified air box. Sold 1/25/2019: Sunlight Silver '08 MS3 GT Mods: BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. |
![]() | ![]() | #10 | ![]() |
![]() | ![]() | #11 | ![]() |
![]() Join Date: Dec 2013
Rep Power: 0 ![]() Thanks: 8
The Following User Says Thank You to leifmadsen For This Useful Post: | kTaLgsTo (06-12-2018) |
![]() | ![]() | #12 | ![]() |
![]() Join Date: Nov 2014 Location: Fresno, CA
| ![]() ![]() ![]() bump...bring this post back from the dead but what is the part# for that bypass leifmadsen? also belt # |
![]() | ![]() | #13 | ![]() |
![]() | ![]() | #14 | ![]() |
| ![]() ![]() ![]() Thanks...can't believe i missed that part. what other modifications did you have to do besides cutting the edge of the plate to make it fit? |
![]() | ![]() | #15 | ![]() |
![]() | ![]() | #16 | ![]() |
| ![]() ![]() ![]() Are you sure???? I just bought the part with the part number listed and it does not look the same. the second bottom bolt seems to be cut and modified in your picture you posted to fit the bolt and a washer has been added to extend the pulley out further. just look at the picture comparison of what was posted and what i bought with the part number given. it does not look the same. ![]() |
![]() | ![]() | #17 | ![]() |
| ![]() ![]() ![]() This was installed during the engine build and I didn't do the build. It does seem like it was modified. What I was thinking was around the thread that said someone had to tap the block, and my builder said that he didn't have to do that. Likely where I got confused. |
Display Modes | |
Mazda crank pulley tool vs Ford crank pulley tool | SPEED6 KILLAH | MazdaSpeed 6 - Engine, Transmission & Driveline | 52 | 03-11-2017 09:46 AM |
Bad Pulley, VVT, or both? | g00s3y | 2010 MS3 - Troubleshoot/Diagnostics | 24 | 06-05-2014 07:50 AM |
MS3 LW Crank Pulley | Alpha | CorkSport | 3 | 04-22-2011 12:07 PM |
Crakshaft pulley | clos561 | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 07-09-2009 06:13 AM |
