 Old 11-28-2019, 03:15 PM   #1
JCole's Avatar
Posts: 4   (View Stats)
JCole is an unknown quantity at this point
Default MS6 Rockers
So my gen 1 needs rockers and I'm having significant trouble locating some OEM's here in Canada.
Found the ones on OnlineMazdaParts but they won't ship to Canada.. fml
Local Mazda Dealership can't get em either apparently.
Does anyone know if regular 6 rockers will fit the MS6?
I work for a small body shop and my boss can't locate any, as well as my mother works for a shop that can't seem to find any either.
Anyone here in the north got a source for some? I can fab my own if I have to, but I'd like to have all my parts be OEM on my baby if possible. They'll fit better too.
Sorry for the brownie post if its in the wrong area or something. Mostly a lurker/haven't been here long.
JCole is offline   Reply With Quote
 Old 11-29-2019, 11:40 AM   #2
MSMS3's Avatar
Posts: 2,746   (View Stats)
Groans: 154
Do you mean rocker panels ?
 Old 11-29-2019, 03:36 PM   #3
Jeff23spl's Avatar
Posts: 2,149   (View Stats)
i expect it is about the metal part below doors? or the wheel arch ? i would expect the 6 would fit. maybe you will need some holes to drill for the skirt...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
HTML code is On
Indie rockers Local Natives perform from back of Nissan Rogue Haltech Automotive News 0 07-16-2014 03:30 PM
Rockers adjustment ukrbyk MazdaSpeed 3 - Engine, Transmission & Driveline 25 06-18-2012 05:20 PM
Page generated in 0.23203 seconds with 22 queries
