-   Mazdaspeed3/6 General Discussion (http://www.mazdaspeedforums.org/forum/f505/)
-   -   Moving to NC worried about passing Inspection. (http://www.mazdaspeedforums.org/forum/f505/moving-nc-worried-about-passing-inspection-88623/)
rremente 08-12-2011 11:15 AM
Hi All,
I am moving to Charlotte, NC next year and I am worried about passing the emissions/vehicle inspection. I have full turbo-back exhaust, reworked turbo, full Cobb intake, FMIC, HP Fuel Pump, Forged Pistons & Rods.
Does anyone know how the inspection is conducted and if I am going to have issues passing the inspection? I am seriously considering to move to Fort Mill, SC instead because of this issue.
Any input would be appreciated.
Rich-PMS 08-12-2011 11:29 AM
You have a cat? Or is your exhaust catless?
glndrums 08-12-2011 12:58 PM
i just passed with a testpipe and they didnt even question me, each inspection station is different but for the most part as long as there is something that looks like a cat and a "muffler" somewhere it should be fine.
Dizzel 08-17-2011 09:31 AM
For emission they just plug up to the OBDII and see if the ecu says everything is running OK. They may look at the exhaust when they check the breaks but I don't know. I have a catted dp and it passes.
BrandonDrums 08-17-2011 09:41 AM
I believe NC actually no longer does an actual emissions test. I'm in NC and I'm totally catless and I just have the Converter efficiency error codes disabled. When they read the codes on the OBD system they see that the car thinks everything is fine.
If not, I'm sure there are some tuner shops that will pass it for you around there.
rremente 09-03-2011 08:42 AM
Thanks for the feedback.
mzr0818 09-03-2011 09:08 AM
Yeah, no light it will pass. But if you have a problem. Road trip to gboro and I'll pass it for you.
NC MSP 09-03-2011 07:54 PM
just make sure you have a cat and a muffler and no c/i light and youll be okay. or just go to a place and make friends with the guy and give him a 20.
mizboo102 09-03-2011 07:55 PM
Like they said, if you have no codes you're good to go. If you're still worried, PM me around inspection time
kgeier82 09-06-2011 07:24 AM
I was just told in MD that as long as no codes come up, and no lights are on, youre good. MD is pretty strict.
dkapetansky 09-13-2011 06:31 PM
I have an '07 MS3 with a gutted 2nd cat, and on 9/13/11 it passed GA emissions without any glitches or drama.
Skipper 09-14-2011 09:21 AM
You should be okay on the inspection, however some of the cops have a hard-on for noise around here. Perhaps that's just me though.
Page generated in 0.16643 seconds with 11 queries
