-   Mazdaspeed3/6 General Discussion (http://www.mazdaspeedforums.org/forum/f505/)
-   -   MS 6: HAWK PADS, Lines, +more are stocked (http://www.mazdaspeedforums.org/forum/f505/ms-6-hawk-pads-lines-more-stocked-38675/)
Race Roots 09-25-2009 03:05 PM
Lucky MazdaSpeed 6 drivers :beerchug:,
We are stocked up and ready to ship Hawk Ceramics, HPS, and HP+ pads. We also have Stainless Steel brake lines and brake fluids. To help some of you on deciding which pad is best for you I will try to describe the characteristics of each pad.
First off these pads are street pads, so they are legal to drive on the streets.
I will go in order of luxury to straight performance, so to start off:
http://i118.photobucket.com/albums/o...ramic_pads.jpg
1.Hawk Ceramics – These pads will have better braking bite then OEM, and have low dust and noise output. This is perfect pad for daily driving in the city, and emergency braking situations. These pads are popular among show cars as they prevent wheels from getting layers of hard to remove brake dust. These pads can also be used during autocross events, but they might suffer from overheating (brake fade) over long term continuous braking and will wear fast under spirited driving.
http://i118.photobucket.com/albums/o...1-1000-2-1.jpg
2.Hawk HPS – These pads are also great for daily driving with their carbon/metallic compound. From customer reviews these pads tend to have a little less initial bite than Ceramics, but these pads also have much better braking over OEM. The reason why Carbon/metallic compound is used is because they wear slower, and last longer. These pads have low noise and low dust output, but not as low as the ceramics. These pads can also be used for autocross events, and they should hold up rather well. These pads might not hold up in racing conditions that exceed autocross speeds.
http://i118.photobucket.com/albums/o...wk_hp_plus.jpg
3.Hawk HP+ (plus) – The HP+ pad is the ultimate performance street pad. This pad is made to stop you and do it reliably. The HP+ has an aggressive carbon/metallic compound that gives you race level braking, but comes with consequences with higher dust and noise output. These pads will most likely squeal occasionally, but that’s just the characteristics of performance brake pads. Lastly these pads are meant for continuous hard braking, and will hold up at higher temperatures (brake fade prevention)
Here are the links to the pads and lines on Race-Roots. (oh yeah and FREE SHIPPING when you order a front and rear set of pads)
Hawk Ceramnics (Front) - $85
Hawk Ceramnics (Rear) - $70
Hawk HPS (Front) - $75
Hawk HPS (Rear) - $60
Hawk HP+ (Front) - $105
Hawk HP+ (Rear) - $89
With your pad change we highly recommend changing out the spongy rubber brake lines and getting some DOT Certified Stainless Steel Brake Lines. We have Racing Brake SS lines that will meet your needs in increasing pedal feel! We have both Mazdaspeed 6 and Mazdaspeed 3 Brake lines in stock!
Mazdaspeed 6: Stainless Steel Lines (racing brake) - $95
http://i118.photobucket.com/albums/o...l014-t-2-2.jpg
We now also have our Staged Upgrades and Combos available for easy purchase off our site!
Hawk HPS Stage 1 Brake Upgrade
Hawk Performance Ceramics Stage 1 Brake Upgrade
Hawk HP Plus Stage 1 Brake Upgrade
Thanks from Race-Roots,
Dimitri
www.raceroots.com
AmillieMS6 09-29-2009 06:37 PM
damn that be nice if u guys had some rotors cuz im in need of some
bf360 09-29-2009 09:34 PM
are the ms3 parts the same?
Race Roots 09-30-2009 08:45 AM
The ms3 and ms6 share the same front pads, but the rear pads are different. We will have all the rears stocked up in about week for the MS3. I will let everyone know as soon as they come in.
If you meant the same Deal? Yes, we will be extending the same deal to the MS3. Any order that comes through our site with pads and lines we will put in one can of ATE Super Blue.
Race Roots 10-25-2009 07:56 PM
We now also have our Staged Upgrades and Combos available for easy purchase off our site for Mazdaspeed 6!
Race Roots 12-29-2009 06:19 PM
Some HP+ looking for a nice home!
memin 12-29-2009 07:36 PM
That is a bad ass deal
gte024h 12-29-2009 08:50 PM
Do the brake lines mount exactly like the OEM ones? I have heard that some brake line kits for the MS6 have a non-OEM fitment and can rub on the suspension.
Race Roots 12-30-2009 08:06 AM
Mounts just like OEM.
Page generated in 0.18220 seconds with 11 queries
