Like Tree2Likes
  • 1 Post By darkmx-6
  • 1 Post By Fstrnyou
 Old 06-11-2018, 08:03 PM   #1
ProjectMPS's Avatar
Posts: 1   (View Stats)
ProjectMPS is an unknown quantity at this point
Default New motor - Will crank, but not start
I bought a 2007 Mazda Speed 3 in the winter with a shot motor. The past 2 months have been very busy swapping in a new motor. The motor is from 2012 Mazda Speed 3 (used motor with about 90,000KM). From my knowledge there are not too many differences between the 2 motors.I replaced anything that was worn or broken: new clutch, new spark plugs, fresh fluids etc. I am using the transmission only the long block is newer it is a used motor. The motor turns over but doesn't spark. I have fuel. I have to check for spark.
I moved any parts I needed that the motor didn't come with from the old longblock to the new one.
The engine is cranking but won't start. It is throwing a P0335 - crankshaft positioning sensor circuit fault. I don't know what else to test.
If you need any other information please leave a message!
ProjectMPS is offline   Reply With Quote
 Old 06-12-2018, 06:13 AM   #2
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Assuming the engine is in tip top shape, check all of your grounds, missing ground straps/wires can really eff you up.
 Old 06-12-2018, 06:24 AM   #3
Fstrnyou's Avatar
Posts: 2,149   (View Stats)
I would think a CPS fault will trigger a no-start safety measure in the ECU. How would it know when to fire the coils if the ECU doesn't know where the crank is?
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
 Old 06-12-2018, 09:43 AM   #4
5doorsoffury's Avatar
Posts: 1,070   (View Stats)
Groans: 74
Well the first thing i would do is get a meter out and test for continuity end to end on that CPS harness and the ecu harness. Next is if it says cps fault i would swap in a known good sensor for testing. Then i would check the infamous coil ground wire that is on the bracket in front of the HPFP. It grounds the coils.
MECP
2012 BM
Rfinkle tune in progress
 Old 06-12-2018, 12:35 PM   #5
danb's Avatar
Posts: 148   (View Stats)
danb is a splendid one to beholddanb is a splendid one to beholddanb is a splendid one to beholddanb is a splendid one to beholddanb is a splendid one to beholddanb is a splendid one to beholddanb is a splendid one to beholddanb is a splendid one to behold
Which wire harness did you use?
2007 speed3 GT. cobb rmm, JbR pmm, twm solid shifter bushings, AP3, Autotech, corksport turbo, HTP 3.5, Depo catless dp, Turbosmart Kompact bpv, Corksport 3port, cpe BlockD, Guardian Angel V3, DO DVC-30, SU TMIC Freektune 93 and e85 maps
2011 mazda 6 95k. wifes ride
danb is offline   Reply With Quote
 Old 06-14-2018, 09:52 AM   #6
darkmx-6's Avatar
Posts: 126   (View Stats)
darkmx-6 is just really nicedarkmx-6 is just really nicedarkmx-6 is just really nicedarkmx-6 is just really nicedarkmx-6 is just really nice
Make sure you used all the electronics from your car not the 2012. As there may be some unseen differences.
danb likes this.
darkmx-6 is offline   Reply With Quote
 Old 06-14-2018, 10:34 AM   #7
Polish_Eagle's Avatar
Posts: 402   (View Stats)
Polish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the world
Are the camshaft trigger wheels the same on a 2012 and 2007? If not, you'll need to partially disassemble the engine and swap the camshafts.
2011 MAZDASPEED3 Hypnotic Tuned - Rob
CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) -
Polish_Eagle is offline   Reply With Quote
 Old 06-14-2018, 10:59 AM   #8
Fstrnyou's Avatar
Both cams have the same P/N from 2006-2013
danb likes this.
Other rides:
History:
 Old 06-14-2018, 11:35 AM   #9
Solarsurge's Avatar
Posts: 570   (View Stats)
P0335 Crank Position Sensor A Circuit Malfunction
There's literally a step by step diagnostic guide on the forums for this.
 Old 06-14-2018, 02:19 PM   #10
danb's Avatar
Yes, you must use the gen 1 harness on the gen 2 motor. I just did this swap a month ago
 Old 06-21-2018, 04:39 PM   #11
jlr8185's Avatar
Posts: 12   (View Stats)
jlr8185 is an unknown quantity at this point
if using tuning software or a AP, i would check the MAF voltages and make sure you didnt give voltages for too low a value. i know somewhere in the forums it talks about a minimum limit to which the MAF volts can go and anything voltages above 0 (zero) in that table below the minimum results in error code. happened to me a few times.
jlr8185 is offline   Reply With Quote
 Old 06-21-2018, 04:48 PM   #12
Fstrnyou's Avatar
I want to say all MAF values below 0.9v should be zero.
Other rides:
History:
 Old 06-22-2018, 07:44 AM   #13
Djohns's Avatar
Posts: 3,945   (View Stats)
Groans: 112
Don’t forget the ground by the fuel pump. Everyone forgets that one.
2010 black mica speed3
Soon:built motor
The Following User Says Thank You to Djohns For This Useful Post:
KiwiFlavor (06-22-2018)
 Old 07-17-2018, 02:19 PM   #14
ZoomZoomT's Avatar
Posts: 23   (View Stats)
ZoomZoomT is an unknown quantity at this point
When i was replacing my vvt and timing chain, after I put everything back together i had same thing with the crank but no start and that engine code. Turns out i forgot to plug in my crankshaft sensor. lol
ZoomZoomT is offline   Reply With Quote
HTML code is On
Ms6 won't start no crank Kevopg MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 12-10-2016 05:58 PM
No crank, No start 570msp MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 10-23-2015 02:03 PM
Crank But No Start Pagan47 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 10-21-2015 08:32 PM
mazdaspeed 6 crank no start Mazdaspeedmike07 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 10-11-2015 10:48 AM
Long Crank at cold start maikell77 2010 MS3 - Troubleshoot/Diagnostics 4 03-13-2013 08:54 PM
Page generated in 0.34448 seconds with 30 queries
