 Old 09-30-2012, 10:20 AM   #1
Hurley 360's Avatar
Posts: 122   (View Stats)
Hurley 360 has a spectacular aura aboutHurley 360 has a spectacular aura about
Default No heat in my 2008 spped 3
Hey guys, last night I was out to grab a few beers with my buddies and once i came back to my car and started driving I noticed that the heat wasn't working (after 30 minutes of driving). I had the heat cranked and there was only cold air coming out of the vents. I lowered the heat to about 24 degrees Celsius and after about 30 more minutes of driving the air coming out was slightly warmer but still nothing like it should be. I just bought the car a few days about and I'm just curious as to what it may be. Also, if this is the wrong section I apologize.
P.s. I tried searching around but i was unable to find and topics with similar issues
Hurley 360 is offline   Reply With Quote
 Old 09-30-2012, 10:30 AM   #2
bryansawiseone's Avatar
Posts: 594   (View Stats)
bryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the worldbryansawiseone is the leader of the world
Prolly thermostat stuck open... That is the usual cause on most vehicles...
2012 MAZDASPEED3 W/ TECH PACKAGE - BNRS3 - HTP 3.5" - GRIMMSPEED EBC - COBB FMIC - COBB AP - CP-E RMM - JBR 80 DURO PMM AND TMM - AUTOTECH FUEL PUMP INTERNALS - JBR SOLID BUSHINGS - CP-E CATTED DOWNPIPE - CP-E TRITON CBE - FORGE V2 BPV - CORKSPORT OCC - DEVILS OWN DVC-30 WMI D10 50/50 - NGK LTR7IX-11 PLUGS - EVOX WHEELS - FREEK TUNED
bryansawiseone is offline   Reply With Quote
The Following User Says Thank You to bryansawiseone For This Useful Post:
Tokay444 (09-30-2012)
 Old 09-30-2012, 10:44 AM   #3
Hurley 360's Avatar
wouldn't the open thermostat throw a code? Also my temp gauge was reading normal the entire time.
 Old 09-30-2012, 10:52 AM   #4
AJ713's Avatar
Posts: 291   (View Stats)
AJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the world
Heater core clogged or air bound in certain areas? Blend door stuck to the cold position not allowing any hot air into the vents, just outside cold air? hope this helps. I just did some similar work to my wife's car.
~AJ
AJ713 is offline   Reply With Quote
The Following User Says Thank You to AJ713 For This Useful Post:
CWP_MS3 (10-03-2012)
 Old 09-30-2012, 11:47 AM   #5
I wouldn't think so... Since it is mechanical and the car is reaching a temp high enough to turn the cold start sensor off...
 Old 09-30-2012, 11:53 AM   #6
Posts: 7,290   (View Stats)
Nah, Heater core by-pass mod.
Nator is what it does.
 Old 09-30-2012, 06:46 PM   #7
Switters's Avatar
Posts: 126   (View Stats)
Switters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond repute
Definately check to make sure the heater core hasn't been bypassed first. Most likely thermostat stuck open tho. coolant full? whats your mileage?
13 BM MS3 Tech-current
JBR
07 CBM MS3 GT-traded
JBRTRMotorsportCorksportHTPTRZDashhawk
fierce invalids home from hot climates.
Switters is offline   Reply With Quote
 Old 10-01-2012, 07:16 AM   #8
vballbwing's Avatar
Posts: 174   (View Stats)
vballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant future
+1 for heater core. had that happen on a previous car.
vballbwing is offline   Reply With Quote
 Old 10-01-2012, 06:20 PM   #9
Hurley 360's Avatar
Turns out that I had a coolant leak. I guess the dealership didn't notice when they were looking over the car but its still under warranty so I'm taking it in, in the morning.
 Old 10-01-2012, 06:21 PM   #10
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
move the fuck out of canada?
It's still 90* here.
07 MS3
The original Genpoo Hater
The Following 2 Users Say Thank You to Chimmike For This Useful Post:
Atlanta (10-02-2012), ScarMS3 (10-01-2012)
 Old 10-01-2012, 06:55 PM   #11
Hurley 360's Avatar
Might have too! It's getting down to about 14°C during the nights which is about 57°F.
 Old 10-02-2012, 08:20 AM   #12
crankshaft's Avatar
Posts: 541   (View Stats)
crankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the world
If you had a coolant leak so bad that the heater doesn't work....then you didn't have enough coolant to cool the engine.....
2012 MS3, CWP
1986 Buick T-Type, square
crankshaft is offline   Reply With Quote
 Old 10-02-2012, 06:00 PM   #13
Hurley 360's Avatar
That's what made me notice. I was driving home from work and i saw the temp gauge rise up a little bit above normal and when I pulled over I noticed that there was no coolant. Luckily I noticed it before she overheated. Once I put the coolant in the heat started working again so I tracked down the leak in one of the hoses that goes to the radiator.
Also the leak wasn't that bad, just enough that the dealership didn't catch it and didn't bother filling the coolant.
HTML code is On
Spped 6 dyno bcmurphy87 MazdaSpeed 3/6 - Dyno Sheets/Discussions 22 07-24-2012 10:17 AM
Spped 3s at pbir last night you on here Solsticegxp Street Racing Stories ( Bench Racing ) 1 04-29-2010 06:55 AM
CES 2008: Hands on with heat-sensing FLIR-equipped BMW Haltech Automotive News 0 01-09-2009 09:30 AM
2008 BMW M3 vs. 2008 Lexus IS F vs. 2008 Mercedes-Benz C63 AMG Wallpaper Gallery Haltech Automotive News 0 04-29-2008 10:10 AM
Page generated in 0.33938 seconds with 27 queries
