 Old 06-19-2017, 07:35 AM   #1
Xxblinddzxx's Avatar
Posts: 109   (View Stats)
Xxblinddzxx is a splendid one to beholdXxblinddzxx is a splendid one to beholdXxblinddzxx is a splendid one to beholdXxblinddzxx is a splendid one to beholdXxblinddzxx is a splendid one to beholdXxblinddzxx is a splendid one to beholdXxblinddzxx is a splendid one to beholdXxblinddzxx is a splendid one to behold
Groaned at 26 Times in 11 Posts
Default Noise when turning left + DSC Flashing
Hi guys Brownie here with some help needed,
Since 2 weeks now i've been experiencing some trouble with my speed 3. Basically whenever i take a curve a little fast there's a "clock clock" noise comming from passenger wheel and the DSC goes on (flashes). The axle has been changed last week and still having the issue. Anyone has an idea what it could be?
Thanks in advance for your suggestion !!!
Xxblinddzxx is offline   Reply With Quote
 Old 06-19-2017, 09:41 AM   #2
Thor Hammer's Avatar
Posts: 907   (View Stats)
Groans: 35
Jack up the offending wheel. Grab the tire at 12 and 6 o'clock. Push at the top, pull at the bottom a few times. Is there any play or noise? Do the same at 9 and 3 o'clock. Post results.
Check your abs sensor. Ensure its firmly bolted in place.
Waiting for Install: Damond OCC/ CS Injector Seals/ WMI/ Torque Solutions Shifter base bushings
 Old 06-19-2017, 10:21 AM   #3
I did check if there was any play/noise and there wasn't none .. as for the abs sensor I'll check it out asap
HTML code is On
Car jerks when turning left all the way? Vex MazdaSpeed 3/6 - Suspension & Brakes 19 03-20-2015 11:31 AM
Clack sound when turning Left? SasquatchMS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 09-25-2013 03:02 PM
Scraping sound turning left ukrbyk MazdaSpeed 3/6 - Suspension & Brakes 1 06-29-2013 08:10 AM
Weird noise when turning left or right from front coils Mazdaboy91 2010 MS3 - Suspension & Brakes 3 10-28-2012 08:36 AM
Noise when turning left Kindred MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 01-31-2010 12:47 PM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Page generated in 0.22202 seconds with 21 queries
