 Old 08-17-2009, 01:35 PM   #81
ptperformance's Avatar
Posts: 4,123   (View Stats)
ptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the world
Originally Posted by jhershorin View Post
So with the stock pcv valve and no OCC will your "smoke fix" still work for me? I already ordered it so i will still try - just curious. I moved to VA and don't have much motivation to do much anymore haha.
Yes, this has been our test group so far. We have not tested one with the OCC or twin check valves but I would have to say that it would work even better on those applications. Sorry about the move and lack of motivation, I hear ya on the area, been there, done that.
Thanks for the order and keep me posted on how well it works.
ptperformance is offline   Reply With Quote
 Old 08-17-2009, 04:40 PM   #82
GQ_WhiteMS3's Avatar
Posts: 658   (View Stats)
GQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the world
Originally Posted by ptperformance View Post
With a properly working PCV system you can keep the oil vapors under control inside the motor. The oil doesn't get as heated and the oil control is better. The knock you get is from oil contaminated intake charge air (PCV system is dumping this air into the bottom of the manifold) and it takes one WOT pass to clear the intake from all the contaminants in the intake manifold. This is why on long cruises you see people pop their motors, its a huge build up of contaminants in the bottom of the motor that causes them to get sucked up into the motor and go boom. Right now this is just theory due to the testing just starting to verify that it does in fact fix knock.
I will have another thread open in regards to the knock issues and some verification if it in fact fixes it. Thanks.
So basically you're stating that oil from the stock pcv system enters the intake manifold ... slowly on a cruise type scenario, then when you WOT the car it 'gulps' the oil from the IM into the motor thus lowering the octane rating of the fuel it's being mixed with causing knock?
would that be it in a nutshell.
If that's the case, people with OCC's should be safer #1 ... and #2 people with Meth as that will compensate for the dropped octane as well.
just trying to wrap my head around this.
GQ_WhiteMS3 is offline   Reply With Quote
 Old 08-17-2009, 04:49 PM   #83
jon i have done your fix and ill make sure to report my findings!!! i made a plate to block the stock PCV box and i def now understand the flaw in the design.
 Old 08-17-2009, 05:59 PM   #84
708
Erich's Avatar
Posts: 4,274   (View Stats)
This is only half the problem, this thread refers to the other portion, which is still applicable. I also want to get my hands on Mazda's modified PCV valve to see if it makes any difference. Did you still put a catchcan in? I think even with the relocate a catchcan will be value added.
Erich is offline   Reply With Quote
 Old 08-17-2009, 06:02 PM   #85
yah theres def a CC in there and i already ordered the smoking fix lol
 Old 08-17-2009, 06:05 PM   #86
Deadman's Avatar
Posts: 868   (View Stats)
Deadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the world
mine runs flawlessly none of these fixes done. !!!!!!!!!!!!! what now
Deadman is offline   Reply With Quote
 Old 08-18-2009, 12:11 PM   #87
SonnyBonahoe's Avatar
Posts: 241   (View Stats)
SonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond reputeSonnyBonahoe has a reputation beyond repute
Groaned at 7 Times in 6 Posts
Sit tight, your a true player!
SonnyBonahoe is offline   Reply With Quote
 Old 08-18-2009, 12:40 PM   #88
Yes, and yes a OCC should help and make the car run safer but there is still oil vapors in the OCC. Unless you have a separated can with media in it the oil vapors are still going to make it to the intake manifold. Meth will adjust for the drop in octane but not on the fly. The PCM adjusts for the higher octane as well, so when the oily mess does hit the motor... you might still have knock.
Thanks for getting the fix. If you have that installed then yes you do understand that flaw in the system.
Your car should be smoke free and knock free here very soon.
Don't worry about it until there is a problem, simple. Do you have a way to monitor knock? If so, what counts are you getting. If you don't have a way to monitor knock, than how do you know yours runs flawlessly?
Ugh, Ryan! Hows that fix from Mazda working for you, heard that you were burning some oil the other day on the road trip .
 Old 08-18-2009, 08:54 PM   #89
RC08MS3's Avatar
Posts: 154   (View Stats)
RC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud of
you could be proactive and spend the 25 bucks to prevent a future issue..
RC08MS3 is offline   Reply With Quote
 Old 08-19-2009, 05:33 AM   #90
OK .. so I sent this to a buddy of mine who is FAR smarter then me ... and this was his response... please comment, I may get him on here to discuss further...but for now...
Hmm its an ok theory except that oil doesn't lower the octane leve of the gas. If it did, every car with leaky piston rings would blow up darn quick, and there are many blue burning DSMs that are still running. And theres a heck of alot more blue coming out of those cars then a new MS3. Also oil doesn't spontaneously combust hence why its a lubricant, even less so if your using synthetic.
The engine problem does seem resolved or affected by the PCV vale. Heres what I'm thinking.
The IM is connected to the crankcase via the valve. The airflow between the crankcase and IM is unmetered. If this connection were open to the air it would cause the engine to run lean.
Turbo engines sometimes see blowby. This causes the oil dipstick to come out of place, sitting just outside its holder in some DSM's. With an ineffective valve, the blowby, could push unmetered air of high or normal oxygen content into the IM.
Typical blowby is very little but it is repetitive and it does put the crankcase under pressure. Under cruising, the AFR is leaner in combustion chamber, so the blowby is of greater oxygen content then WOT.
Overtime the engine is ingesting alot of unmetered air of higher oxygen content, when it is already running its peak timing and leanest AFR values. Its not a catostrophic failure but rather a continual part throttle knock that reduces the longevity of the motor, resulting in a greater per capita rate of failure.
Removal, replacement of the valve or closure of the IM to Crankcase path seems to stop the problem by forcing all air to be metered by the MAF/MAP, but the oil could play a role too. Read on.
Knock in an of itself is a post ignition process. As the flame front spreads across the top of the piston it slowly pushes it downward. The graph of force would be sinusodal or gradual.
With a knock, the charge starts to spread slowly across the piston, after the spar,k but due to volatility of the gas, and the piston still rising (this compression is related to spark advance), and the compression the change itself is creating, it spontanesouly ignites and strikes the piston like a hammer instead of a gentle push. The graph of force would be a spike.
The only thing that good quality synthetic oil COULD do to increase your risk of knock, is to increase the dynamic compression. Like during a compression test, you do one test with oil, and one test without oil. The oil increases compression typically. If it increases it too much you have a bad engine due to the difference between the readings. However OIL will typically increase compression. Especially good oil.
So if your engine is ingesting alot of oil, its going to be running alot more compression, but unlike a blue burning beater, this oil isnt from leaky piston rings (reduced compression) so thats why cars with bad rings don't blow up they have low compression to begin with and the oil is a sympton not a cause. No, this oil is from the PCV valve, and your rings are still good. So there will be increased dynamic compression in the cylinder, which would increase the likely hood of knock, even if the oil itself was not volatile. It could just be acting like a catalyst.
Combine the increased compression, with lean AFR's, advanced timing, and the ONLY reason the oil is there to begin with is because of a bad PCV valve and a bit of blowby and unmetered air.... and your increased risk of engine failure becomes apparrent in the failures per capita.
Just some theories that may be linked to the problem. It does sound like a bugger to find.
 Old 08-19-2009, 06:41 AM   #91
stealthspeed6's Avatar
Posts: 136   (View Stats)
stealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant future
i think he is wrong when he says the airflow between the crankcase and IM is unmetered. it is actually accounted for which is why if you did disconnect it from the IM and left it open you would run lean because there would be more air then whats accounted for, that is if you can keep the car from stalling out because what you have there is a giant vacuum leak.
its a good theory on the oil causing more compression on good cylinders though and i think thats what john is trying to get at. the fact that these cars do ingest from the pcv is a fact and over time if you don't have a occ then it builds up until finally it just takes a drink and boom. if you are running at a constant highway speed in which most cases you'll be in vacuum then your pcv valve will most likely be open that whole time thus allowing for more oil to be injested and then finally once again boom.
i also want to say that i can almost always know when i should empty my occ just from the fact when i start to see more random part throttle knock. as soon as i empty it bam its gone.
stealthspeed6 is offline   Reply With Quote
 Old 08-19-2009, 12:56 PM   #92
Agreed, but some have to be proven wrong before the take the steps to fix a problem. Thanks for the post!
First off, oil vapors due induce knock. It may be from a lower octane or it could be cause from the lack of proper air volume in the motor. Either way it has been noted that excessive crank case oil vapor into the intake manifold will cause a loss of power and induce knock, thus being a bad thing and could have a relative relationship to lowing the octane.
Next and I really get pissed when I see this, we are not talking about a DSM, or a VW or any other car on the market. Its a MAZDA! I know he doesn't mean any harm but until you have seen the operation parameters of the car you have no idea what your talking about, so some of his points are moot and don't apply. We can not push the dipstick tube ouf of our cars because there are to many open holes for the pressure to escape to, thus is why we don't have properly working PCV system on the car. Sorry.
All of his knock and oil consumption ideas I agree with. The one thing I want to point out is you have to see vacuum in the motor to achive proper ring seal (think crank case evac systems on race cars) if you never achive vacuum in the motor you will have poor oil ring control that puts additional strees on the scraper ring. When this happens you end up with even more oil in the combustion events causing additional problems. This is why we are starting to see customers running with the fix getting more power and smother power delivery after a few days of driving around on them.
The system was broken from the factory and we have a fix for it.
The OCC knock, see that been there. You are correct, we are trying to establish a proper ring seal on the piston with our fix, we are trying to keep the oil in the crank case under control so we don't have to run OCC's, multilple check valves, and other fixes to cure the problem. Get the crank case pressure under control and you will see a huge reduction in knock, increase in power and hopefully an increase in MPG (testing this now). Overal, this little part could very easily pay for itself in the peace of mind or possibly in the MPG you gain after the install. I will keep you guys posted, thanks.
 Old 08-19-2009, 01:00 PM   #93
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groans: 31
Groaned at 86 Times in 65 Posts
Should i put the stock banjo oil feed bolt back in? Or does it not really matter?
-JEWBERT
jhershorin is offline   Reply With Quote
 Old 08-19-2009, 01:29 PM   #94
I would leave that up to you, talk with bnoon about it and lets see how he feels about it. I know that it will work with either one on the car.
 Old 08-19-2009, 01:43 PM   #95
Speedie6's Avatar
Posts: 1,838   (View Stats)
Speedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the world
I think JMHinkle said he has done exactly that, but, I think he has lots of mods.
Speedie6 is offline   Reply With Quote
 Old 08-19-2009, 01:49 PM   #96
m4tic's Avatar
Posts: 4,928   (View Stats)
so the original valve cover breather, i have disconnected from the intake, added a air separator with some steel wool and venting it outside.... would i stiil need your pcv fix and/or should i hook this vent back up?
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 08-19-2009, 01:52 PM   #97
Or a lot of blowby. That is about the only reason you could push the dipstick tube out of the motor, to much pressure.
The PCV fix would not effect any of the set up that you have now. So, you would be good with it and the current configuration of the OCC and lines.
 Old 08-19-2009, 01:59 PM   #98
Speedie6's Avatar
John,
As you may recall, I ordered a pump, oil burning fix, replacement WI bung and replacement intake screen. I just called and talked to one of your people. He said the pumps haven't gone out yet, you are going to test them, or something like that. At any rate, I ordered over the phone and I don't have an order number or tracking number or anything. Has anything been shipped yet, or are you going to ship it all together? You can respond by PM if you prefer.
 Old 08-19-2009, 02:24 PM   #99
First off ... slow down lol ... I know we're not talkign DSM's. He isn't trying to disprove anything by this, he's simply trying to help out, he is a DSM and Honda guy but a car guy first, on top of being a very smart systems engineer.
All he said was if the knock was caused by oil, it wasn't due to octane lowering, but more so it was caused by increase in cylinder pressures... or at least thats how I read it.
 Old 08-19-2009, 02:25 PM   #100
Ghost Rider's Avatar
Posts: 248   (View Stats)
Ghost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the worldGhost Rider is the leader of the world
ordered the fix. I have not had any problems thus far, but I have started to do more mods (SRI, TIP, BPV...) and figured it couldnt hurt. I am going to have to get a dashhawk next just to see what my car is really doing
Ghost Rider is offline   Reply With Quote
 Old 08-19-2009, 06:44 PM   #101
John,
Yes it ships all together today, you should have tracking in your email early tomorrow morning or later this evening. Thanks.
First off ... slow down lol ... I know we're not talkign DSM's. He isn't trying to disprove anything by this, he's simply trying to help out, he is a DSM and Honda guy but a car guy first, on top of being a very smart mech. engineer.
No, I understand but you have to know the operating parameters of this car. DI is so different then any PI car I have ever worked on. There are testing numbers that really make me thing that the car is broken from the factory when in all reality they are suppose to run this way (wow!). He also has to understand that the DI has no contamination in it from oil vapors, so the intake, rings, ect ect can all feed full contaminated air to the motor. Cyl wash down is near impossible to make happen with a DI motor outside of anything other than idle. WOT wash down is just about impossible.
I do appreciate his help and I was not jumping on anyones arse about what they do and don't know about cars.... there is just so much difference between DI Mazda motors that you have to own one/work on one in order to get an understanding. Tell him thank you for his input, it is appreciated.
Thanks for the order and no it will not hurt anything with the car or PCV system. Please do and post the results of before and after if you can. Thanks!
 Old 08-19-2009, 06:45 PM   #102
John... here's another response to your post lol ... I'm trying to get him to get an account on here, I really think this kind of discussion is healthy and beneficial. Keep in mind I DID order your fix
towards the end ..he gets a little snippy, but it's just a rebuttle to you getting snippy about dsm's.
Sorry, I didn't want to start a debate, and didn't know my response to you would be posted, so some of is for refernce for you. Like your knowledge of my experience with DSM's.
However, he misunderstood my post. Oil vapours could induce knock, I do not dispute that. Seems to me like he just skimmed over the post.
What I mean by indirectly or catalyst effect is oil itself is not volatile, it will not ignite under typical spark, heat or pressure. It is engineered that way and is designed to lubricate the cylinder walls and therefore see day to day combustion, this is typical burn off.
We mix oil with high octane gas intentionally in high performance, knock sensitive, 15,000 RPM, 2 stroke engines. In this case even a few counts of knock can destroy the engine, unlike more robusk 4 strokes. However the compression is lower and is designed with the oil lubricant in mind.
In general motor oil improves lubrication, and does not interact with the charge itself, aside from taking the place of oxygen and increasing emissions. If there is increased knock it is a catalyst effect. The oil itself does not sponteanously ignite under heat and pressure, and neither does high quality gas.
As for performance, since oil is taking the place of oxygen in the cylinder it would definetly have a performance effect, I did not dispute that. This is because the same amount of fuel is still needed to maintain a target AFR, but now theres extra oil in the charge taking up space as well.
My comment about the DSM blowby was again just for reference. It is a symptom of blow by on those cars as was there to give an idea that blowby causes pressure in the crankcase, and thus pressure on the PCV.
The operating parameters.... of the MS3, are no different then any other car out there, direct injection or not. The tuning may be load based but as far as AFR's and reaons for knock, it must respond to the same laws of thermodynamics as every other engine out there. It burns the same fuel and therefore its parameters must operate around the same stochiometric mixture of 14.68:1, especially when cruising. Meaning if the compression is too high or the AFR too lean, or the fuel too poor... with reference to that value, it will knock.
I am trying to point out reasons or theories that you may want to investigate. I am surely not qualified to diagnose with any accurracy the flaws pertaining to this fault in specifc, without any solid facts, numbers or data at my disposal and even then my schooling is systems engineering not mechanical. I am simply tossing out a few theories.
If this gentlemen wants to disagree with them, its his opinion. But stating the obvious like this car isn't a DSM, doesn't add anything to the discussion.
I don't have a MS3, so I am going out a limb to try and lend a hand to you (or the community since you chose to share it) as to reasons why the part throttle knock experienced my some, could be induced.
"I really get pissed" when some business owners bully their customers with an over bearing attitude into sharing the same opinion. Telling someone their points are moot and they have no idea what they are talking about is not only a unwarranted personal attack, its just plain disrepsectful. Especially when someone takes the time to extend their thoughts on a problem, they don't share, on their own time.
Steve
 Old 08-19-2009, 06:57 PM   #103
Thanks, typical engineer. With that being said, his input is appreciated but until he has worked on one, tuned one, or even modded one he has "ZERO" first hand knowledge of the car.
I could come in here and state that my Caliber (600 WHP proven) runs best at 13.0 AFR's on race gas and we get knock if we run any lower than 11.2 AFR's. Would I run a Mazdaspeed at those AFR's? Would I run a DSM at those AFR's? Hell NO! Every car is different, every car has different PCM logic, knock sensor sensitivity, ect ect. This is why I addressed the "DSM" comment.
To be honest with you the discussion would do nothing for the members, he has no first hand knowledge about the DI 2.3 motor and it would all just be opinion and book based. You have to work on the car in order to understand how it responds to different inputs, all cars are different and stating if one car does this, than the next one should as well is just foolish. Get your hands dirty and then get back to me.
Thanks,
John (your bully shop owner that attacks customers)
 Old 08-19-2009, 07:09 PM   #104
Why are you getting so angry / upset ... it's kinda ridiculous ... you are both arguing the same fcuking point... just different reasoning.
John ... he is AGREEING with you that a better pcv system is needed and WILL HELP curb knock! You're looking a little silly here to me at least because he is NOT arguing with you.
running a 600hp car at 13's and 11.2 afr's is irrelevant here you are right ESPECIALLY since we are talking pt knock which occurs in a closed loop scenario at a stoich afr.
Yes this car is different he knows that, how it responds to mods, tweaks etc, (how it gets from performance point A to performance point B is different then other cars out there but the logic remains similar.
 Old 08-19-2009, 09:57 PM   #105
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
can some people update the knockage curbage as they install these? if it does i will definately scrounge my pennies for one
"Go find your own enterprise, and get the fuck off my bridge!"
2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard"
1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action"
skeeter149 is offline   Reply With Quote
 Old 08-20-2009, 03:15 PM   #106
Trader's Avatar
Posts: 90   (View Stats)
Trader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to behold
Groaned at 5 Times in 1 Post
Can somebody expain what the fix is? Or is it still a secret. Will definately buy if it fixes the problems ($25 is nothing), but I also like to know what I am getting.
Trader is offline   Reply With Quote
 Old 08-20-2009, 06:58 PM   #107
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
1) its a restrictor pill that goes in the PCV system at the valve cover
2) It is not $25 anymore, the GB is over it went up in price, check PTP website for more info.
Suspension:
Trader (08-21-2009)
 Old 08-21-2009, 01:22 AM   #108
I am not upset or angry, just being clear that you either understand they system or you don't. The Mazda operating parameters are way different than that of any car I have ever worked on. Again, no two cars are the same! Yes they run on gas, yes the logic is still there, but that is where it stops. That is the only point in which I could have gotten a little upset, he has not spent the 400 hours working on the car in order to fix this problem, I have.
I will make a thread on this so we can get an accurate account of any knock correction if any. Thanks.
See below post.
Thank you.
 Old 08-21-2009, 03:10 AM   #109
Driverman5777's Avatar
Posts: 685   (View Stats)
Driverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the world
Groans: 76
So for some reason im finding it hard to believe that restricting a line poses no negatives. How is this true?
Driverman5777 is offline   Reply With Quote
 Old 08-21-2009, 05:26 AM   #110
KRNAGE's Avatar
Posts: 120   (View Stats)
KRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond repute
so is this fix working? not smoking but want to get one just in case (still need to get a downpipe) which ill order soon
is this hard to install?
KRNAGE is offline   Reply With Quote
 Old 08-21-2009, 10:24 AM   #111
708
Erich's Avatar
You would have less problem believing this if you could look at some of the other design issues with the PCV system on this motor. It is like the engineers got to the end of their design cycle, were tired and still had the PCV system to go and just started slapping random necessary components in semi-random location to get it done.
The Following User Says Thank You to Erich For This Useful Post:
ptperformance (08-21-2009)
 Old 08-21-2009, 01:30 PM   #112
Yes its working very well. We are also including one for free with every downpipe ordered off the site. The DP prices are very affordable and allow for a no smoke install with the PTP restrictor.
Install is very easy.
 Old 08-21-2009, 01:42 PM   #113
Groans: 76
quite a shame then that you don't have speed6 downpipes
 Old 08-21-2009, 03:55 PM   #114
I am sure that we could get one for you. We are going to be working with another company to get these on the market for you guys, thanks.
 Old 08-26-2009, 10:15 AM   #115
DaleNixon's Avatar
Posts: 2,079   (View Stats)
Groans: 91
Mine came in the mail yesterday. Thanks for the fast shipping, PTP. I'll try to get it installed this weekend. Is everyone loving this so far?
The Following User Says Thank You to DaleNixon For This Useful Post:
ptperformance (08-26-2009)
 Old 08-26-2009, 02:47 PM   #116
90% of the people love it and 10% seem to have some issues with it fitting tight and not working. We are addressing those that don't have a tight fit with the part with V2. This should clear up that last 10% of customers that say that mod is not working.
Thanks.
 Old 08-26-2009, 03:13 PM   #117
DaleNixon's Avatar
Groans: 91
Thanks. I gathered that same number reading the forums. I'll see if it fits in my system. I'm not smoking, and my knock is mysteriously gone with Cobb's 105 maps, but I still think this fix is important as Mazda themselves are redesigning the PCV system.
 Old 08-27-2009, 03:22 AM   #118
ilight's Avatar
Posts: 20   (View Stats)
ilight is just really niceilight is just really niceilight is just really niceilight is just really niceilight is just really nice
How loose is too loose, fit wise? Mine spins, in place, once I managed to get it installed. I have only tested the car once, since I added the part, and I still have some smoke. I had a decent length drive (after I installed the part, but before I "tested" the car) and would have thought I'd have burned off any remaining oil... Please let me know if I can make any improvements.
ilight is offline   Reply With Quote
 Old 08-27-2009, 11:38 AM   #119
The remaing oil takes some time to get rid of so that might be what is taking so long to rid your car of the smoking issues.
Give it some time to see if it gets any better, if not, then I would say that we might have to get you into another mod that fits tighter. Keep me posted on your test results, thanks.
 Old 08-27-2009, 03:36 PM   #120
ilight's Avatar
Thanks! I will give it some more time and let you know the results.
HTML code is On
brand new ms3, 1k miles, burning oil already!! johnsonroda27 MazdaSpeed 3 - Engine, Transmission & Driveline 123 05-14-2009 07:42 AM
Burning oil STi Slayer MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 04-19-2009 10:13 PM
Help!!! Car losing/burning oil aaronc7 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 34 10-19-2008 08:35 AM
HUMMER crashes Burning Man in a big way Haltech Automotive News 0 09-02-2008 11:10 AM
Page generated in 0.66793 seconds with 38 queries
