 Old 08-12-2017, 08:26 AM   #1
tom10122's Avatar
Posts: 115   (View Stats)
tom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to all
Default Oil consumption, leakdown and compression confusing
I've been using a quart every hundred miles, did the turbo and pcv valve. Nothing. Just had a compression and leakdown test done and I'm confused on the results
Cyl 1 150. 15%
Cyl 2 150. 15%
Cyl 3 130. 15%
Cyl 4 150. 5%
The mechanic that did it also said cyl 4 had oil on the plug, but that seems like the best numbers wise. Cylinder 3 possible cracked ringlands?
Sent from my XT1565 using Tapatalk
tom10122 is offline   Reply With Quote
 Old 08-12-2017, 08:38 AM   #2
Fstrnyou's Avatar
Posts: 1,477   (View Stats)
Oil in the cylinder seems like it would improve compression and leak down tests by sealing up the gaps.
So if your good results are from the oily cylinder, expect poor results if that cylinder was dry.
2006 MS6 GT - 152k Miles
Versatuner, 3-bar MAP, ITV22's
Russian Bushings in Back, Magnaflow CBE
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/Stage 2 OCC
Forged build ongoing. Manley H-Tuff & 2618, King Bearings
Other rides:
History:
 Old 08-12-2017, 05:32 PM   #3
tom10122's Avatar
Any idea what the culprit is? Rings or valves stem seals?
 Old 08-12-2017, 07:00 PM   #4
MD1032's Avatar
Posts: 2,621   (View Stats)
Groans: 139
A leakdown test will tell you where the leakage is occurring. The technician is supposed to listen for where the air is leaking from. If I had to guess, yes, I would say the problem is likely in the bottom end, likely cracked ringlands. 15% leakdown on a stock motor is a lot.
2007 Mazdaspeed3 GT
HTML code is On
Confusing electrical problem ShintaroIchi MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 08-02-2015 12:30 AM
Mostly good compression but shit leakdown results VA2010MS3 2010 MS3 - Engine, Transmission & Driveline 1 07-23-2015 08:43 PM
Bad Leakdown Mofford12 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 10-29-2014 03:26 PM
Leakdown test question torq MazdaSpeed 3/6 - Turbo Induction 0 08-09-2013 07:29 PM
Page generated in 0.24552 seconds with 22 queries
