Like Tree10Likes
  • 7 Post By rfinkle2
  • 1 Post By MS3-a(sore)ASS-rex
  • 1 Post By mituc
 Old 12-12-2011, 06:36 AM   #1
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Default Oil discussion compilation thread
For whatever reason, it is difficult to search our forums for 3 letter words such as oil, and UOA (used oil analysis), so it was asked that someone create a thread compiling decent oil information for our cars.
Below is a collection of links found on msf (and now other reputable sites) that are oil related.
There is also a link to what is thought as the most informative oil website that I know of, "Bob is the Oil Guy .com".
Dealer Oil Changes dealership oil change discussion
2010 Oil Analysis oil discussion and uoa results
ZDDP lacking in modern oil oil ingredient / component discussion
What kind of oil? oil discussion
http://www.mazdaspeedforums.org/foru...d-3-iyo-18303/ oil discussion
Response from Pennzoil on Ultra - Bob Is The Oil Guy - pennzoil's explanation of ultra vs. platinum (Bob is the oil guy link)
FerrariChat.com - FAQ: Motor Oil Articles by Dr. Ali E. Haas (AEHaas) - thanks to username nindoja, mathematical oil analysis
Motor Oil - All Chapters, Inclusive -Copy and Save This - FerrariChat.com - Dr. Haas's credentials (provided by username mzr165)
AZSPEED3, eppopipe, MZR165 and 4 others like this.
The Following 28 Users Say Thank You to rfinkle2 For This Useful Post:
2008speed3 (12-12-2011), atvfreek (12-12-2011), Awesomesauce (04-19-2012), AZSPEED3 (12-13-2011), BrianB6 (12-12-2011), Easter Bunny (12-13-2011), eppopipe (12-12-2011), EwMPS (07-21-2015), Hectik1 (12-12-2011), j2c2003 (02-11-2015), Jake5713 (12-12-2011), jdub0802 (04-30-2012), jtt (12-30-2011), Juyoung (07-09-2013), kairojya (03-02-2012), Menace1 (02-06-2013), MS3-a(sore)ASS-rex (12-13-2011), MZR165 (12-12-2011), nindoja (12-12-2011), P4L (11-22-2012), phate (01-17-2012), Raider (12-12-2011), SLOWHATCH (02-04-2012), speed6253 (06-19-2013), SweetJP (12-12-2011), TiGraySpeed6 (12-12-2011), Tokay444 (12-12-2011), Vader (12-12-2011)
 Old 12-12-2011, 09:10 AM   #2
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Thank fucking fuck Rob!
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following 4 Users Say Thank You to Tokay444 For This Useful Post:
atvfreek (12-12-2011), rfinkle2 (12-12-2011), SLOWHATCH (02-04-2012), Vader (12-12-2011)
 Old 12-12-2011, 03:21 PM   #3
nindoja's Avatar
Posts: 2,391   (View Stats)
I know it's not on MSF, but this link has some really great analysis of motor oil.
The guy has basically tested everything out there, and even uses math to prove his points! *gasp*
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
The Following 3 Users Say Thank You to nindoja For This Useful Post:
Easter Bunny (12-13-2011), Raider (12-13-2011), rfinkle2 (12-12-2011)
 Old 12-12-2011, 03:23 PM   #4
rfinkle2's Avatar
Groans: 298
Thanks very much nindoja.
I'm adding the link you provided to the OP.
Great stuff!
 Old 12-12-2011, 05:04 PM   #5
MZR165's Avatar
Posts: 273   (View Stats)
MZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the world
The site below has the same info as nindoja, but has some of Dr. Haas's credentials included in the beginning.
2007 Mazdaspeed 6 - Hypertech - J Barrone RMM - CS SRI & CS Turbo Inlet Pipe - Kumho Ecsta ASX
TOWER PERFORMANCE ENGINES
"You never get out of the throttle unless you see the timing tower."
“There is no limit to the good a person can do, if he does not care who gets the credit”
MZR165 is offline   Reply With Quote
The Following 2 Users Say Thank You to MZR165 For This Useful Post:
 Old 12-12-2011, 05:11 PM   #6
rfinkle2's Avatar
Groans: 298
Adding to OP. Thanks very much for the contribution!
The Dr's credentials definitely add credibility to the thread.
MZR165 (12-12-2011)
 Old 12-12-2011, 05:17 PM   #7
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
I plan on switching to this my next oil change. Penn Grade 1 High Performance Oil
I'm still debating on 10w-40 or 10w-30.
Brad Penn "Green Oil" is supposed to be some of the best stuff around. I'll give a further review vs. Pennzoil Platinum in a separate thread you can link here after the switch.
nclugnut likes this.
NATOR PA
The Following 3 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
Menace1 (02-06-2013), Raider (12-13-2011), rfinkle2 (12-12-2011)
 Old 12-12-2011, 05:22 PM   #8
rfinkle2's Avatar
Groans: 298
I know you are familiar with the Evo world, and Forced Performance highly recommends Brad Penn.
Check out that Zddp in modern oil thread (started by Lex) above.
There is a link to a test of oils performed by Forced Performance (white paper Ziggo reminded me of).
MS3-a(sore)ASS-rex (12-12-2011)
 Old 12-12-2011, 05:24 PM   #9
Groans: 224
Will do, thanks. The 2.1 stroker running an FP Black I'm building now will be running Brad Penn 20w-50 (off topic yes but cool none the less LOL)
NATOR PA
The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post:
 Old 12-13-2011, 10:59 AM   #10
MZR165's Avatar
I don't know who is copying who, but Dr. Haas and Bob the Oil Guy have exactly the same write up's about oil! It's all very good information, but someone is guilty of plagiarism.
Bob the Oil Guy University
Motor Oil 101 - Bob is the Oil Guy
Dr. Haas, the PHd Surgeon
The Following User Says Thank You to MZR165 For This Useful Post:
rfinkle2 (12-13-2011)
 Old 12-13-2011, 11:02 AM   #11
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Um, read the bob link. "by AE Haas"
The Following 2 Users Say Thank You to Raider For This Useful Post:
atvfreek (12-13-2011), rfinkle2 (12-13-2011)
 Old 12-13-2011, 02:37 PM   #12
MZR165's Avatar
Ok....I didn't read the fine print! Gotta give me a little break, I'm looking through tri-focals! lol
 Old 12-13-2011, 02:44 PM   #13
AZSPEED3's Avatar
Posts: 3,148   (View Stats)
AZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the world
Groans: 65
Great thread Rob, ton of good info.
AZSPEED3 is offline   Reply With Quote
The Following User Says Thank You to AZSPEED3 For This Useful Post:
 Old 02-04-2012, 06:42 PM   #14
Ferg's Avatar
Posts: 1,498   (View Stats)
Ferg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the world
@codyb154
2008 Silver Mazda 6s (AEM cai and jdm cbe) sold feb 2011
2008 Black Ms3 SOLD
Vibrant CBE/custom straight test pipe/SURE AEROS SRI/short shifter/jbr chrome molly 88 duro dogbone rmm/rally armor mudflaps/MOTORCRAFT trans fluid/EBC Redstuff front pads/JBR short shift weight/JBR adjustable short shift plate @30%/autotech internals/MD OCC/ Prosport Evo Boost gauge with Vent Pod/NGK one step colder plugs
AP Dizzy Tuned by BUCKER
CorkSport Interior LED Kit
2015 STi Limited in Lightning Red
Stock bottom end died at 18K hard canyon miles.
Current Mods after build
Forged High Performance CP Pistons, CP Rings, King Race Bearings, Manley H Beam Rods, 20g Turbo with 8cm Hotside, Cobb Performance Fuel Regulator, DW300c Intake pump, 1000cc Injectors, Cobb intake, Nameless 3" divorced catless DP, 3" MagnaFlow catback, Grimmspeed EBCS, SPT lower shift bushings, SPT short shifter, Diode Dynamics Boomerang kit, AP v3 Tuned by Justin@FreekTune
[11:46 AM] wdawson4: now here is where i get expensive it takes atleast 250,000 to pound my butthole i cant sell that for cheap
Ferg is offline   Reply With Quote
 Old 08-13-2013, 09:03 PM   #15
2con's Avatar
Posts: 16   (View Stats)
2con is an unknown quantity at this point
I just installed a oil temp and pressure gauges.
What temp does my oil need to be at before i can shut off my car safely to prevent turbo damage?
I tried searching but was unable to find a result.
thanks
2con
2con is offline   Reply With Quote
 Old 08-13-2013, 09:48 PM   #16
mituc's Avatar
Posts: 3,519   (View Stats)
Groans: 111
It's not the hot oil that damages the turbo, it's the hot turbo itself. That's why you need to drive normally for at least 2-3 minutes after a long/agitated drive before you shut your car off.
The turbo heats up quite a lot from the exhaust gasses (mostly) and some components can reach easily 1200-1400F (even 1500-1600). On the other hand the oil should always be at the operating temperature. Keeping the engine running for a few minutes before shutting the car off will simply bring the turbo temperature down to the oil/coolant temperature (or close).
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
The Following 2 Users Say Thank You to mituc For This Useful Post:
rfinkle2 (08-14-2013), Strangel (01-18-2014)
 Old 02-13-2014, 04:39 PM   #17
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Agent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the world
Groans: 665
Groaned at 76 Times in 40 Posts
Originally Posted by seshomaru7 View Post
Picking up Pennzoil 5-30 ultra for my next change. Will verify if it is a huge step up from Mobil-1 EP 5-30
Hmmmm
Just shy of 150 posts.
Bumping lots of old threads with stupid comments.
Whatcha got to sell?
Agent_Orange is offline   Reply With Quote
 Old 02-13-2014, 04:55 PM   #18
btstarcher's Avatar
Posts: 4,851   (View Stats)
Groans: 112
Oh come on, he's been here for a few years now and obviously isn't a noob.
SnailTune in progress
 Old 02-13-2014, 05:01 PM   #19
Groans: 665
Join date means nothing.
Obviously not an active member.
 Old 10-07-2014, 12:52 PM   #20
Thepedigree13's Avatar
Posts: 608   (View Stats)
Thepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the worldThepedigree13 is the leader of the world
Groans: 64
I got this UOA done last oil change. The oil used was BG Products full synthetic line. Been a while since I've researched what all that means, but I figured I would share this for the people that can interpret the information.
The oil was changed and analyzed after 4800 miles of use.
I am sorry for the image being sideways. When I upload from my phone it always does this, hence my avatar.
~2013 BLACK MS3~
COBB: (APV3//Exhaust Hangers)
CS: (TMIC//RP//Leather Knob//Battery Box//Interior LEDs)
JBR: (3" SRI//80 Threesome//SSP//SSB//TB TIG//Coolant Bypass//Rice Flaps, EGR delete, OCC)
Magnaflow CBE//GFB BOV//FREEKY DEEKY OTS+
》》》SUPPORT YOUR MSF VENDORS《《《
Thepedigree13 is offline   Reply With Quote
 Old 10-08-2014, 12:57 AM   #21
Groans: 64
I'm hoping this oil suits our platform well. I did some research, but still don't know how to determine what some of those numbers mean.
Anyone?
Apparently BG Products will warranty any components you use their products in so long as you fall within certain guidelines. I plan on using their tranny fluid as well and will post pros/cons afterward.
I have always been a fan of their 44k, so we will see how well their other products work.
~2013 BLACK MS3~
 Old 01-24-2015, 04:37 PM   #22
Conrad144's Avatar
Posts: 26   (View Stats)
Conrad144 has a spectacular aura aboutConrad144 has a spectacular aura aboutConrad144 has a spectacular aura about
Great thread truly appreciated
Conrad144 is offline   Reply With Quote
 Old 05-17-2015, 06:38 PM   #23
avesfan101's Avatar
Posts: 442   (View Stats)
avesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the world
T6 /thread.
Fuck MSF
avesfan101 is offline   Reply With Quote
The Following 3 Users Say Thank You to avesfan101 For This Useful Post:
Raider (05-18-2015), Scare Dem (05-17-2015), Vansquish (05-17-2015)
 Old 05-17-2015, 06:58 PM   #24
FSUMazdaSpeed's Avatar
Posts: 350   (View Stats)
FSUMazdaSpeed is the leader of the worldFSUMazdaSpeed is the leader of the worldFSUMazdaSpeed is the leader of the worldFSUMazdaSpeed is the leader of the worldFSUMazdaSpeed is the leader of the worldFSUMazdaSpeed is the leader of the worldFSUMazdaSpeed is the leader of the worldFSUMazdaSpeed is the leader of the worldFSUMazdaSpeed is the leader of the worldFSUMazdaSpeed is the leader of the worldFSUMazdaSpeed is the leader of the world
T6 has been said, the thread is over, hence /thread
VIP, Little over $2 a month to watch unlimited couches getting fucked
2013 MazdaSpeed3 w/Tech: JBR RSB, 80 Duro RMM, Shift Knob, Stage II Intake, ATP Catless Downpipe, FMIC, SSP: Autotech Internals
SS Performance Group Mustang Dyno 301/320 Tuned by FLOWTUNED
FSUMazdaSpeed is offline   Reply With Quote
The Following User Says Thank You to FSUMazdaSpeed For This Useful Post:
avesfan101 (05-17-2015)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f505/oil-discussion-compilation-thread-99365/
Helpful oil info - ASEClub This thread Refback 11-23-2012 11:23 AM
HTML code is On
Video: Vintage crash compilation shows how far racing has come Haltech Automotive News 0 05-22-2011 05:20 PM
autocross compilation video!!! srt8autoxer Auto-X / Road Racing / Time Attack 2 09-10-2009 09:12 AM
VIDEO: Got 90 minutes? Good. Watch this gigantic compilation of rally crack-ups Haltech Automotive News 0 04-26-2009 03:40 PM
Page generated in 0.46835 seconds with 36 queries
