Like Tree2Likes
  • 2 Post By Pu Manchu
 Old 09-19-2017, 07:16 PM   #1
mazdafanboy3's Avatar
Posts: 4   (View Stats)
mazdafanboy3 is an unknown quantity at this point
Default Passenger or Transmission mount first?
So ive been looking at different Motors mounts and ive come to except that the vibrations are going to be rough and what not but i dont have the funds to buy both transmission and passenger mount.
If you had to decide which one to get first or see the most improvement from just 1 mount which would you choose?
PS. i already have the rear motor mount.
mazdafanboy3 is offline   Reply With Quote
 Old 09-19-2017, 07:21 PM   #2
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,812   (View Stats)
Groans: 537
Groaned at 178 Times in 115 Posts
since you want your grundle massaged, passenger.
Db09ms3 and danb like this.
06 MS6
The Following User Says Thank You to Pu Manchu For This Useful Post:
mazdafanboy3 (09-19-2017)
 Old 09-19-2017, 07:29 PM   #3
Sooooooo most improvement from the passenger mount? plus a good massage?
 Old 09-24-2017, 11:14 AM   #4
Smallville's Avatar
Posts: 32   (View Stats)
Smallville has a spectacular aura aboutSmallville has a spectacular aura about
I can't comment on which is better performance wise but my thinking is to replace the passenger mount first since those fail a lot more often than the transmission mount. My pmm blew and puked brown hydralic fluid all over my engine bay.
As for increased vibrations, search the forums for reviews. After reading I decided to go with Damond's pmm. It costs more than others but people says it has the least increase in vibrations. I haven't installed it yet so I can't comment on my experience.
Smallville is offline   Reply With Quote
The Following User Says Thank You to Smallville For This Useful Post:
mazdafanboy3 (09-25-2017)
 Old 09-24-2017, 01:09 PM   #5
5doorsoffury's Avatar
Posts: 965   (View Stats)
Groans: 72
Groaned at 7 Times in 6 Posts
The TMM is directly next to the shifter cables so doing that first makes shifting nicer. Also it makes the tranny more auditable. The PMM is a lot easier to install and the vibes make my mangina all wet and sticky.
MECP
2012 BM
Rfinkle tune in progress
The Following User Says Thank You to 5doorsoffury For This Useful Post:
 Old 09-29-2017, 02:48 PM   #6
KamloopsDan's Avatar
Posts: 57   (View Stats)
KamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to all
I have been running a JBR rear mount for the last 2 years or so, the vibe increase was very noticeable.
Recently I installed a Damon PMM and the vibes increased even more. I now have pieces of foam hidden around the centre console to stop the annoying rattles.
God knows what it is like running all three mounts.
KamloopsDan is offline   Reply With Quote
 Old 09-29-2017, 03:05 PM   #7
AveryPlaysBass's Avatar
Posts: 276   (View Stats)
AveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond repute
Groaned at 6 Times in 4 Posts
By a used low mile PMM off of somebody/or salvage yard if you really feel the need to replace the PMM. You should only replace it with aftermarket (something not made out of rubber) if you seriously track the car or drive it really hard often. Basically, replace TMM first. After that you probably will be on the threshold of vibes and noise, especially since you already have a RMM.
It's OK to cry" - Lil B
2012 MS3 w/Tech Package
Engine: CS SRI/Tip, AutoTech internals, Damond Banjo Bolt, CFM Mount, CS Racepipe, Resonator delete, Tuned by FREEKTUNE
Trans: CS insert, CS bushings, Damond Shifter Plate
Suspension: Koni Orange with CS springs, Konig Controls 17x7.5 with 225/45 Conti DW's
Appearance: Plasti Dipped Emblems, Bumper Guard, CS Steering wheel/Shift knob/E-brake handle,dumb stickers
AveryPlaysBass is offline   Reply With Quote
 Old 10-11-2017, 11:45 AM   #8
E.Murray's Avatar
Posts: 22   (View Stats)
E.Murray is an unknown quantity at this point
I have no plans to track the car. I'm putting in a motor (with 135k on the car). Am I better off to keep my original mounts?
E.Murray is offline   Reply With Quote
 Old 10-11-2017, 02:38 PM   #9
Db09ms3's Avatar
Posts: 209   (View Stats)
Db09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant future
Depends on what you plan to do with the car I guess. I too heard good things about the Damond PMM. I worry about vibes a wee bit. So, I chose the OEM used route myself. Just for now anyways.
 Old 10-11-2017, 03:01 PM   #10
Go with a Damond Trans mount first and keep or purchase an OEM passenger mount to see how you like the vibes. The passenger mount will make the most difference when it comes to NVH. Thats what i plan on doing, although if i can't sell this CPE passenger mount I'm just going to put it on my car, seeing as though apparently its really not that much different than a stock mount and less harsh than the JBR and even the Damond.
 Old 10-12-2017, 07:48 AM   #11
E.Murray's Avatar
Good stuff. Thanks. It looks like the passenger mount isn't a nightmare to change, so I think I'll go with your plan. If I want to upgrade it at some point, I can.
 Old 10-12-2017, 02:57 PM   #12
Jonb82's Avatar
Posts: 409   (View Stats)
Jonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the world
Groaned at 24 Times in 9 Posts
My set up is CS RMM and MD TMM and PMM. NVH is minimal. At a stop there’s minimal rattle, and the only time the mirrors shake (minimally) is on first acceleration from a stop. Is it harsher then stock? Yes. But it’s not the horror show that everyone makes it out to be. You have a sports car. Enjoy the feed back that the Damond mounts provide
Sent while probably pooping
CS TIP/SRI CS RMM CS Sexy Steering Wheel CS Springs & Struts CS Shirt Throw Shifter CS Shifter Bushings CS TBE CS Boost Tubes CP-e TMIC HKS BOV in resirc DM Vented OCC DM TMM DM PMM DM SSP Autotech Internals Custom E33 Freaktune
Jonb82 is offline   Reply With Quote
HTML code is On
Dual Product Release!! CorkSport Mazdaspeed 3 Passenger Side Motor Mount and Transmission Insert CorkSport CorkSport 143 04-12-2016 11:00 PM
Page generated in 0.32906 seconds with 28 queries
