Notices
 Old 10-20-2012, 01:28 PM   #1
lambo6's Avatar
Posts: 78   (View Stats)
lambo6 is a name known to alllambo6 is a name known to alllambo6 is a name known to alllambo6 is a name known to alllambo6 is a name known to alllambo6 is a name known to all
Default Projectors pop out of line
I have a 6, and I wanted to know has anyone had there stock low beam projector pop out of line where its not fully in the housing and does it affect the raise and lowering of the beams that Mazda built for it? Just happened today ftl...
06 speed6 fully loaded // cobb sri // HKS ssqv Bov // Katina GTM 18" wheels // more to come... eventually
lambo6 is offline   Reply With Quote
 Old 10-20-2012, 05:31 PM   #2
Coaststarlight's Avatar
Posts: 264   (View Stats)
Coaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the world
happen to me... I dropped it when it was off the car, epic fail, BUT its not the end of the world, it poped right back into place when I pushed on it
The bad news is, you have to open the housing and take it apart to do that, its not as hard as it sounds its just time consuming, I used a blow dryer and a flat head screw driver to open the headlight, dont forget to remove the turn signal bulb and bulb holder before you start, or you'll break it off inside the housing if you try to seporate them while its still in place
Long Block Built by GPwerks and Loose Screw Motor Sports
https://www.gp-werks.com/
http://www.crossoverauto.com
^Any Parts, Great Prices^
Coaststarlight is offline   Reply With Quote
The Following User Says Thank You to Coaststarlight For This Useful Post:
rob ms6gt (10-22-2012)
 Old 10-25-2012, 12:44 PM   #3
Evan's Avatar
Posts: 13   (View Stats)
Evan will become famous soon enough
how did you reseal your headlight? i need to do this
Evan is offline   Reply With Quote
 Old 10-25-2012, 05:47 PM   #4
Same way you open them, Heat from a blow dryer or heat gun
Heat gun may be faster but easy to mess up and warp the housing, its a time taking proccess ether way so I'd choose blow dryer, heat, press together, repeat till you have gone all the way around the headlight and done
when prying it open use a flat head screw driver to help, dont pry to hard or you'll break it, just remember, be very genorous with the heating, the more time you spend heating, the less you have to pry and risk cracking it, take you time, you'll be at it a while anyway
gl
 Old 10-25-2012, 06:37 PM   #5
m4tic's Avatar
Posts: 4,508   (View Stats)
Groaned at 22 Times in 20 Posts
I adjusted one of my projectors too far and it popped cross eyed. I need to take the light apart... Perfect time for a retro!
2007 w/ Cheez
// COBB AP // COBB SRI // COBB TIP // CXRacing FMIC // HKS SSQV v1 // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // BC Racing BR Coilovers // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Prosport Elec Boost Gauge // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob
 Old 10-25-2012, 07:55 PM   #6
Evan's Avatar
cool thanks. so the old sealing silicon will be fine
 Old 10-26-2012, 05:53 AM   #7
Scammer Hunter
Raider's Avatar
Posts: 14,984   (View Stats)
Groans: 449
Groaned at 105 Times in 88 Posts
Told ya Mike, you had to opened it up, pop in, reseal. 200 degrees preheated oven for 10 minutes, pull apart, fix, reinstall!
MSF Moore OK Tornado Recovery Donation Thread
1) Looking to Buy a used Mazdaspeed? Read this!
2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here.
3) Wanna buy and sell here? DONATE for VIP
4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting!
5) Help MSF grow with FAQ threads!?
Raider is online now   Reply With Quote
HTML code is On
15% off on clear lenses for projectors LOLredranger Mazdaspeed3/6 General Discussion 9 05-30-2012 08:20 PM
Retrofit projectors or aftermarket projector headlights? mark02smith Mazdaspeed3/6 General Discussion 4 05-16-2012 05:56 AM
Page generated in 0.31517 seconds with 24 queries
