 Old 12-22-2011, 06:31 PM   #1
2006MS6's Avatar
Posts: 271   (View Stats)
2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of
Groaned at 8 Times in 5 Posts
Default prosport oil pressure gauge install
had a few questions regarding the install. In the harness there is one black wire which is designated for "ground" then it also says the black wire goes to the "G" connector on the sender. They have one wire to go to 2 different spots? Also connecting the wires to the sender, Do I just add and eyelet connector on the wire and slide it over the post and then screw the back rubberized nut back on over top of it?
2006MS6 is offline   Reply With Quote
 Old 12-22-2011, 06:54 PM   #2
crazyp's Avatar
Posts: 1,093   (View Stats)
crazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the world
Groans: 68
Groaned at 22 Times in 9 Posts
meh I just wrapped it and screwed rubber nut on it. the G just goes to ground. confused me at first too.
2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC
crazyp is offline   Reply With Quote
 Old 12-22-2011, 06:58 PM   #3
2006MS6's Avatar
so the black wire in the harness just goes to the "G"? doesnt have to be grounded to anything in the car?
 Old 12-22-2011, 07:20 PM   #4
crazyp's Avatar
Groans: 68
. The black wire just gets grounded, to anything thats a ground really. from the sensor I grounded to a bolt where my intake use to be. The guage was grounded around the radio
 Old 12-22-2011, 07:50 PM   #5
2006MS6's Avatar
gotcha, so a separate wire gets added to the sensor as a ground for it.
The Following User Says Thank You to 2006MS6 For This Useful Post:
crazyp (12-22-2011)
 Old 12-22-2011, 07:58 PM   #6
crazyp's Avatar
Groans: 68
yes exactly. I wasnt sure at first either because like you I read the instructions.
 Old 12-22-2011, 08:53 PM   #7
2006MS6's Avatar
ok cool man, thanks alot!
 Old 12-23-2011, 08:03 AM   #8
Crazyspeed3's Avatar
Posts: 167   (View Stats)
Crazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond reputeCrazyspeed3 has a reputation beyond repute
Groaned at 20 Times in 7 Posts
does anyone know where the oil pressure sensor is located on the motor??
Silver Genpu // Cobb SF // GFB Bov // Eibach Springs // 3" Custom DP back // Cp-e Tmic // Sure Torq R3 Street // JBR Short Shifter Kit // Autotech internals // Enkei Ekm3 // 93 Pump Gas FREEK TUNED
06 Subaru wrx SOLD
08 mazdaspeed3 SOLD.:sofa:
NOTE: Stock Internals + DP = Death Penalty
Crazyspeed3 is offline   Reply With Quote
 Old 12-23-2011, 08:15 AM   #9
pwned101's Avatar
Posts: 229   (View Stats)
pwned101 has a reputation beyond reputepwned101 has a reputation beyond reputepwned101 has a reputation beyond reputepwned101 has a reputation beyond reputepwned101 has a reputation beyond reputepwned101 has a reputation beyond reputepwned101 has a reputation beyond reputepwned101 has a reputation beyond reputepwned101 has a reputation beyond reputepwned101 has a reputation beyond reputepwned101 has a reputation beyond repute
Groaned at 9 Times in 7 Posts
I just ordered an oil pressure gauge and had to get the oil filter spin on conversion and sandwich plate adapter so I think you have to get those in order to install an oil temp and press gauge lol.
pwned101 is offline   Reply With Quote
 Old 12-23-2011, 02:06 PM   #10
2006MS6's Avatar
yes you do, we have a cartridge filter and need the spin on conversion
 Old 12-23-2011, 09:11 PM   #11
bertrand_CX_7's Avatar
Posts: 1,455   (View Stats)
bertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the world
Groans: 52
Groaned at 145 Times in 38 Posts
2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII.
Pending install: JB EGR block plate
Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness.
2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system.
bertrand_CX_7 is offline   Reply With Quote
HTML code is On
How-to install prosport gauge and block8head pod Block8head MazdaSpeed 3 - How-To's 66 09-12-2015 04:48 PM
prosport electrical boost gauge install?? bombdotcom MazdaSpeed 3/6 - Turbo Induction 17 12-22-2013 01:33 PM
air/fuel and oil pressure gauge install? cgburton12 MazdaSpeed 6 - How-To's 32 12-15-2012 05:43 PM
Prosport Gauge Install SJP0tato MazdaSpeed 3/6 - Turbo Induction 16 01-17-2010 09:40 PM
Page generated in 0.31192 seconds with 24 queries
