 Old 09-01-2018, 09:15 AM   #1
TDubTheSubBub's Avatar
Posts: 82   (View Stats)
TDubTheSubBub is a glorious beacon of lightTDubTheSubBub is a glorious beacon of lightTDubTheSubBub is a glorious beacon of lightTDubTheSubBub is a glorious beacon of lightTDubTheSubBub is a glorious beacon of light
Default PSA: A reminder on injector seals
Thought I'd throw this out there for anyone who is on the fence about doing injector seals. In the process of doing my BNR S4 swap I decided to change the injector seals. I've thought of doing this for awhile now but this was a good excuse to just do it. My car has always seemed a little off. The compression was 180 across the board, it always drove fine. When I turned the boost up to 18psi on the k04 I noticed a ticking noise at full boost, so I turned it back to factory. I've always seemed to get worse gas mileage than other speed's, absolute best I've ever got was 20 mpg on the highway with no boost at all. Now in the heat of the summer I've noticed that I was unable to even hit 15psi anymore, but nothing sounded off. I assumed it was the K04 going out since it has 114k miles and started smoking. I also want to note that I've only owned this car for 10k miles, so I'm not 100% sure of the history of it.
The seals are all beyond shot. One of them had so much carbon around it I had to use the slide hammer with all my might. I'm glad I decided to do this, just wish I had done it before so I could tell the difference these CS seals will make. I think they would have shot out of the engine if I had ran the BNR at all. So if you suspect that you should do the seals, my advice is yes, do it. Now I have to find those top washers for the injectors somewhere so I can get this shit done. Here are some pictures of what I found, those squeamish might want to look away.
Cylinder 1's injector is the one in the pic and I truly had to beat it out.
TDubTheSubBub is offline   Reply With Quote
 Old 09-01-2018, 08:29 PM   #2
Solarsurge's Avatar
Posts: 571   (View Stats)
They get cruddy AF just in normal operation. I would highly suggest sending them off to get cleaned. There's a good chance the filters are clogged in the injectors. When I pulled mine, I was surprised to find that the seals were perfect. The insides of the cups were shiny and bone dry, like they just came off the production floor, but the injector tips were covered in soft brown turd looking formations. It literally looked like poop. I sent them off to Race City Injector in Mooresville, NC. They came back clean and he included the old filters in the package so you can see how cruddy they were. They were pretty shot.
 Old 09-02-2018, 07:19 AM   #3
most of the posts i'm reading about injector cleaning are from a few years ago. Now that GDI is more common is there anywhere that can test and clean them, or would I be better off just having them cleaned? Also where would you order these washers and o'rings from?
Can't contact the dealer until tuesday.
 Old 09-02-2018, 05:04 PM   #4
Fstrnyou's Avatar
Posts: 2,480   (View Stats)
I got all my o-rings/washers from dealer.
I'm using Toyota Seals at the moment, but I have CS seals on standby.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 09-03-2018, 01:40 PM   #5
Should I replace all the seals/washers or just the blue orings and the top washers? I cant imagine the bottom two actually do much other than space it out
 Old 09-03-2018, 02:06 PM   #6
Fstrnyou's Avatar
Hindsight, I should have only replaced the o-rings. I spent a bunch of money replacing the other washers for no reason other than to have new parts. There wasn't anything wrong with mine. Even the o-rings still looked good.
Other rides:
History:
 Old 09-04-2018, 11:39 AM   #7
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Send your injectors here:
http://www.precisionlinefuelinjectors.com/index.html
 Old 09-04-2018, 03:26 PM   #8
Fstrnyou's Avatar
I had mine cleaned at InjectorRX I think.
Other rides:
History:
 Old 09-05-2018, 07:28 AM   #9
This is where I plan on on sending them. Hopefully they get out today. Got the orings and the top washers ordered from the dealer. $107
 Old 09-05-2018, 07:44 AM   #10
Fstrnyou's Avatar
My 6 is my daily, so I bought a spare set, had them cleaned, and then did a quick swap at my convenience.
Other rides:
History:
 Old 09-05-2018, 07:58 AM   #11
Mine is my daily also, but I bought a 1990 Camry (dubbed the "Scamry") to drive around during this project. It's a nice car and I smile quite a bit at all the people looking at me confused. Honestly I think I would sell my mazda for a cressida if I found a VERY nice one. Just love the look on peoples face when they see me in this grandma car. 1JZ Turbo Cressida would be even funnier, also working on a 1990 car then working on a 2006 car will make you very much hate the newer one.
 Old 09-11-2018, 08:56 PM   #12
So an update on the cleaning. Sent them to injectorRX in Houston, Texas. One of my injectors was pretty bad. Had a 10% increase in flow after being cleaned. Glad I did this! Would've sucked to have one cylinder lean out and ZZB. This thing should run like a beast when this is all said and done!!!
HTML code is On
Injector seals - need to replace injector/fuel line O-rings? TheRealDefman 2010 MS3 - Engine, Transmission & Driveline 3 03-02-2014 08:35 PM
Page generated in 0.31895 seconds with 24 queries
