 Old 09-17-2012, 02:42 PM   #1
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Default Rock Auto - What doesn't fit??
Let this be the beginning.
I have 2 so far that I need to add. Potentially a third.
07 MS3
The original Genpoo Hater
TiGraySpeed6 (09-17-2012)
 Old 09-17-2012, 02:57 PM   #2
cnyms6's Avatar
Posts: 138   (View Stats)
cnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the world
AC compressor didn't fit
cnyms6 is offline   Reply With Quote
 Old 09-17-2012, 03:03 PM   #3
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I have found a few times where parts listed for my Speed6 is wrong on Rock Auto because for some dumb reason, a lot of parts were listed to work with 2.3L motor and Mazdaspeed MZR even though this isn't right. I mean, the parts sort of fit, but they are different enough to be a PITA; In other words, the part will fit and not leave you stranded, but its just different enough to cause the OCD in you to flare up. A lot of part manufacturers must have assumed the 2.3L and MZR are basically one in the same and didn't do a lot of research.
Specifically for me, the thermostat and radiator. The thermostat on the 2.3L has a longer neck, by about 1.5" then my MS6. The MS6 neck is shorter to clear the power steering hose. The longer neck does fit and will work, but the power steering hose has to be scooted over a bit. The supposed MS6 drop in radiator from them has different lower mounts and the auto trans cooler hookups. I massaged it to work because I was in a pinch, but I will eventually get my stock radiator repaired and reinstalled.
 Old 09-17-2012, 03:24 PM   #4
LilGator's Avatar
Posts: 136   (View Stats)
LilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond repute
Groaned at 6 Times in 3 Posts
Blower motor for MS6 doesn't fit. They list it under "2.3L L4 Turbocharged", but it's definitely not a match.
2007 Speed6 GT - LPM
RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP
SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV
MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports
E85 Stratified
LilGator is offline   Reply With Quote
 Old 09-17-2012, 08:24 PM   #5
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
I'll see if I can look up some of the bad part numbers tomorrow, but last I looked, only one passenger side front cv axle, out of 6 different axles, both pass & drivers side, actually fits the speed6.
I also have the specs, dimensions & such that I'll add to feed the search engines and help folks be able to identify speed6 axles from 2.3 na axles which are much smaller
340hp / 371tq
 Old 09-17-2012, 08:33 PM   #6
jack_hammer's Avatar
Posts: 6,821   (View Stats)
Groans: 549
i bought two rear ABS sensors. they both fit. in fact, they say "fomoco" on them. however, i think one is broken. i'm still working on determining that, though...
it's fun to do bad things
 Old 09-17-2012, 08:35 PM   #7
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Lol someone in SoCal Nator was just pointing to me about this $63 axle they wanted to buy from them.. I hope they see this thread.
 Old 09-17-2012, 08:43 PM   #8
theschrum's Avatar
Posts: 1,031   (View Stats)
theschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the world
Groans: 29
Groaned at 7 Times in 6 Posts
Rock auto is an awesome site for parts, but I always reference the part number to a regular 2.3l before I purchase from them though. I wouldn't be suprised if 20% of the parts listed for our cars didn't fit.
06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block...
08 Speed 3|SOLD
theschrum is offline   Reply With Quote
 Old 09-18-2012, 12:57 PM   #9
Rock Auto- MS6 axle listing has been improved, but still not perfect. At least it's better than it was. Only a single CV appears to be incorrect.
I can guarantee that Cardone # 608190 is correct, that one was in my car for a couple of months till the rebuild failed- just lucky there. They're usually not bad. It's reasonably safe to "assume" the rear axles would be right, the application shows '06 & '07 only, and hey, they're rear axles....
The first one in the list is certainly incorrect (MZ8338A), and is used as an example of what to watch out for in the pics below.
The entire list- much shorter than it used to be:
See anything amiss with this application list?
Here's a good application list:
Mazdaspeed6 Front CV Axle specs compared to the N/A 2.3 CV axles:
Dimensions:
The Speed6 axles have a much larger nut, 35mm -vs- 32mm, on the splines/hub side. This is the one I've been using a 36mm socket on, by mistake apparently.
This nut size can also be referred to as M24-1.5 on the Speed6, and as M22-1.5 for the smaller NA axle.
Spline section diameter on the speed6 is 32.5mm, and is only 29mm on the NA axle.
Passenger side is also longer for the Normal 6 2.3, since there is no PTO to deal with
- top is the Speed6, bottom is normal 6 passenger side
340hp / 371tq
manu (11-14-2016)
 Old 09-18-2012, 01:10 PM   #10
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
SleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the world
Groans: 52
Groaned at 54 Times in 39 Posts
Yes I see this thread lol. I ended up just buying a OEM axel
2009 CWP Speed3
SleeperHatch is offline   Reply With Quote
 Old 12-27-2012, 11:31 PM   #11
DashingDomin8r's Avatar
Posts: 21   (View Stats)
DashingDomin8r is just really niceDashingDomin8r is just really niceDashingDomin8r is just really niceDashingDomin8r is just really niceDashingDomin8r is just really nice
Exedy Clutch kit doesnt fit.
DashingDomin8r is offline   Reply With Quote
 Old 03-29-2013, 01:17 PM   #12
lopezsr20's Avatar
Posts: 71   (View Stats)
lopezsr20 has much to be proud oflopezsr20 has much to be proud oflopezsr20 has much to be proud oflopezsr20 has much to be proud oflopezsr20 has much to be proud oflopezsr20 has much to be proud oflopezsr20 has much to be proud oflopezsr20 has much to be proud oflopezsr20 has much to be proud of
Groaned at 22 Times in 9 Posts
Does anyone know if the ball joint moog MDBJ4869 they offer for the speed fits?
Or the DEEZA Part # MDH201—
2007 Mazdaspeed GT
Autotech Internals :Mazdaspeed cold air intake v2 : Corksport TIP : Cobb Accessport : Turbo XS Hybrid BOV cuz pssshhhhhhhhhhhh : Corksport RMM :Corksport Testpipe: JBR Shifter Bushings: Homedepot special OCC : Koni Yellows : Cobb rear sway bar : Resonator delete : Rallyarmor Mudflaps cuz rally car
lopezsr20 is offline   Reply With Quote
 Old 04-06-2013, 06:53 PM   #13
MazdaSpeedster's Avatar
Posts: 128   (View Stats)
MazdaSpeedster is just really niceMazdaSpeedster is just really niceMazdaSpeedster is just really niceMazdaSpeedster is just really nice
I ordered a cabin air filter last week for my speed 6. I received it today and it did not fit.
MazdaSpeedster is offline   Reply With Quote
 Old 04-06-2013, 07:47 PM   #14
What's the part number for the filter which doesn't fit?
340hp / 371tq
 Old 05-22-2013, 12:18 PM   #15
rabble rabble
802MS3's Avatar
Posts: 5,315   (View Stats)
Groans: 221
Strut mount kit for the 3 -
Mevotech MS76201 does not come with the strut boot and bump stop, even though it shows both of those in the pictures.
More Information for MEVOTECH MS76201
Details
'08 CWP MS3 w/ T3 3071r
 Old 07-31-2013, 07:15 AM   #16
spd6demon's Avatar
Posts: 164   (View Stats)
spd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the world
The shaft pivot seal doesn't fit, too big in diameter. I just re-used the old seal but took the spring ring (or whatever its called) out of the new seal and put it in the old one. Been about two weeks and no leaks
06 MS6 GT // PTE 6266 GEN2 // Kozmic 6th Port Inj. 1200cc // Weisco Pistons (0.020 over) // Manley H+ Rods // JDM Sport EM // Tial 38mm EWG // SP63 Keyed & Polished Crank & Sprockets // 4" WPI // P&P IM // Cobb AP // Custom DP
CP-E Safe Seals // CP-E Rear Diff Mount // Bosch 3.5 BAR // Sure ShortCut // TWM Shift Knob // AutoTech HPFP internals // H&R Springs // DRAG DR-34 +35mm // CS2 Front Lip // CX Racing Air to Water IC // Custom Matt Damond Dual OCC
HTP Small Batt Tray // SP63 EBCS // HKS BOV // Kozmic Oil Feed Line // JBR EGR block off // JBR BSD // JBR Counter-weight // NGK // DW 65c ITFP // JBR PMM // JBR SSB // SU RMM // Corksport TMM Insert // FREEK Tune in progress
305/364 (K04) // 367/387 (2871r)
454/417 (PTE6262 R.I.P)
spd6demon is offline   Reply With Quote
 Old 07-31-2013, 07:29 AM   #17
Can you post the part number you ordered from RA, or any other details?
Knowing RA, they have some that do fit & some that don't so any details you can provide on what didn't work would be great!
340hp / 371tq
 Old 07-31-2013, 07:50 AM   #18
spd6demon's Avatar
Part # 221620
There was only one shift shaft seal that came up for the 06' ms6. The seal didnt fit no matter how hard I tried. Seal is slightly too big for housing. Also the new seal wasnt as thick as OEM
The Following User Says Thank You to spd6demon For This Useful Post:
TiGraySpeed6 (07-31-2013)
 Old 08-01-2013, 12:18 PM   #19
Mandinca's Avatar
Posts: 1,700   (View Stats)
Mandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the world
Groaned at 7 Times in 5 Posts
Originally Posted by spd6demon View Post
Part # 221620
For what the OEM costs why didn't you go to Mazda ?
The radiator doesn't fit. The brackets for the fans are all wrong and one of the hose fittings on top is different. It would be nice if it did fit since RA's is $119 and the only other place I could find one was OEM at $350
I also bought a PCV valve from them and the jury is still out on its functionality.
Last edited by Mandinca; 08-01-2013 at 12:18 PM. Reason: MSF Database - Automerged Doublepost
Mandinca is offline   Reply With Quote
 Old 08-01-2013, 12:23 PM   #20
soul.survivor's Avatar
Posts: 335   (View Stats)
soul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the world
Fel-pro donut exhaust gasket fits but isn't thick enough to make a seal.
2008 CBM MS3
CP-E RMM | JBR 3.5" WP | GTX3071R | JBR OCC + IM TIG | SU TMIC | Turbosmart Compact BPV | Autotech Internals | Cobb AP + TBE + EBCS | NGK 1 Step Colder | TWM Shifter | Hotchkis Sways | Bilstein Sports | Swift SPEC-Rs | SPC Camber Arms | Freektune
soul.survivor is offline   Reply With Quote
 Old 08-01-2013, 05:30 PM   #21
spd6demon's Avatar
My friend actually ordered it for me. Didn't think rock auto's would be different. Guessed wrong lol.
 Old 01-23-2014, 05:53 AM   #22
Rcimp's Avatar
Posts: 129   (View Stats)
Rcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond repute
I ordered the LUK clutch kit and it fit fine, I also ordered two axles that fit fine to. I ordered two front bearings with hubs and they did not fit.
Bearing with Hub: PRECISION AUTOMOTIVE 513211 - Did not fit.
Clutch Kit: LUK 10064 - Fit
Axle: EMPI 803952 - Fit
Axle: EMPI 803957 - Fit
Clutch Slave Cyl: WAGNER SC143568 - Fit
07 Cosmic Blue Speed 3,
BNR S2 Turbo
Cobb AP
BEGI SRI
CNT Catted Downpipe
Forge BOV
CorkSport Turbo Inlet Pipe / Silicone BPH / Boost Tubes / Dry Flow Air Filter
Fidanza Aluminum Flywheel
CPE Xflex Stage 2 Driver Side MM
CPE Xflex Stafge 2 Rear MM
AWR Passenger Mount 88 Duro
Power Slot Rotors
Last edited by Rcimp; 01-23-2014 at 05:53 AM. Reason: MSF Database - Automerged Doublepost
Rcimp is offline   Reply With Quote
The Following 2 Users Say Thank You to Rcimp For This Useful Post:
madspd6 (03-02-2014), stockms3 (08-13-2014)
 Old 03-02-2014, 12:47 AM   #23
season_of_ages's Avatar
Posts: 290   (View Stats)
season_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond repute
Radiator was mentioned. Of course, this will include the drain plug. Thread is too small to fit oem radiator
Sent from my SM-N900T using Tapatalk
season_of_ages is offline   Reply With Quote
 Old 03-02-2014, 01:41 AM   #24
madspd6's Avatar
Posts: 1,009   (View Stats)
madspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the world
Groans: 31
The one EMPI Drivers side front axle #803967 for the speed 6 fits fine too as i have it.
I also called EMPI and about 5 months ago they were working on tooling for the passanger side, guy said new tooling takes between 5-6 months to perfect.
Velocity Red Mica 06 Speed6 (ricer) #834
Some shitty; s300sx fmw turbo, home made fmic setup, home made 4" Intake, 3.5 blowthrough maf, home made downpipe, poorly self tuned. More motor mounts then necessary.
Gay and coated white enkei rpf1s with stupid 245/45 tires. Pointless drilled and slotted rotors. Clunky coilovers. Ricer lips and lights.
madspd6 is offline   Reply With Quote
The Following User Says Thank You to madspd6 For This Useful Post:
Guano5150 (07-25-2016)
 Old 09-24-2014, 05:25 PM   #25
arias valentia's Avatar
Posts: 17   (View Stats)
arias valentia is an unknown quantity at this point
I got the engine gasket set, 4 exhaust valves and a pcv valve from them and I havnt had any issues except a minor seaping around the valve cover that I attribute more to the some rusty (+1 missing/snapped) cover bolts.
So far I guess i was lucky
Anyone know about the rack and pinion boots?
arias valentia is offline   Reply With Quote
 Old 09-29-2014, 07:32 AM   #26
maddocx240's Avatar
Posts: 820   (View Stats)
maddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the world
Groaned at 45 Times in 21 Posts
Has anyone ever tried the oxygen sensors for the speed 6? I might need one and wanted to know if they are the right part.
maddocx240 is offline   Reply With Quote
 Old 10-29-2014, 06:22 PM   #27
twiztdspeed's Avatar
Posts: 28   (View Stats)
twiztdspeed will become famous soon enough
Ngk 02 sensors should be ok but the dorman intake manifold runner control or ebcs has the wrong male pluge
twiztdspeed is offline   Reply With Quote
 Old 10-29-2014, 06:34 PM   #28
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Turbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the world
The ngk/ntk o2 sensor part number 24357 worked perfectly for my 08 speed 3.
They list part number 24354 for the speed 6. I am not sure if the connectors are different between the 2 cars but this is probably why it has a different part number. If it is pictured with the heat shield it should be the one you want.
The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS
Soon to come.
WHO KNOWS? A.D.D. FTW!
Turbo_Steve is offline   Reply With Quote
The Following User Says Thank You to Turbo_Steve For This Useful Post:
cshunter (10-29-2014)
 Old 11-13-2014, 10:25 AM   #29
Slick6's Avatar
Posts: 7   (View Stats)
Slick6 has a spectacular aura aboutSlick6 has a spectacular aura about
I overhauled most of the suspension on my MS6 last summer with rockauto parts. Only a few parts gave me problems.
The Beck/Arnley rear lateral links don't fit a MS6. The part number is 1016605. I'm not sure about the Mevotech or Moog lateral links, but with the Beck/Arnley ones I could not adjust rear toe at all.
The Beck/Arnley control arms fit. I've had them on my car for over a year and haven't had a problem with them. These are the part numbers:
Rear upper CA's - 1017042
Front upper CA's - 1015535 (Left) / 1015534 (Right)
Front lower rear CA's - 1015533 (Left) / 1015532 (Right)
For the Front lower front CA's, I bought Dorman #520809 which fit perfectly and have held up well.
KYB Strut mounts #SM5540 fit but after about a month they began making noise, so I would avoid these.
2007 MS6 GT
Cobb AP / JBR SRI + TIP / Fleabay TP / JBR TIGS / Sure RMM + Diff Mounts / Koni Yellows (Front) / Bilstein HD (Rear)
/ Cut OEM Springs / SPC Balljoints / JBR SSP / Denso ITV-22's
Slick6 is offline   Reply With Quote
The Following 2 Users Say Thank You to Slick6 For This Useful Post:
season_of_ages (11-21-2014), TiGraySpeed6 (11-13-2014)
 Old 11-20-2014, 06:20 PM   #30
ibcrusn's Avatar
Posts: 494   (View Stats)
ibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the world
I forgot to post this some time ago but the Beck/Arnley 037-6112 intake gasket fits perfectly. Their TB gasket fits 100% as well I just don't have the P/N handy.
'10 VRM MS3
3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert
Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
ibcrusn is offline   Reply With Quote
 Old 11-21-2014, 09:40 AM   #31
I read there was a TSB regarding the passenger control arm where the MS6 would pull to the right. Are these the updated control arms? After installation, do you experience any kind of pull while driving?
 Old 11-21-2014, 10:47 AM   #32
Slick6's Avatar
The updated control arms are supposed to correct differences in caster between the left and right wheels. I don't think these will fix caster differences, but I went from 4 degrees of caster to about 5 degrees after installing them, FWIW. Then again, I had the front subframe lowered and installed SPC balljoints when I replaced the UCAs, so I can't say for sure if the increased caster was a result of the control arms.
I don't have any pull while driving after installing these and getting a good alignment.
2007 MS6 GT
The Following User Says Thank You to Slick6 For This Useful Post:
 Old 07-22-2015, 03:14 AM   #33
myspeed90's Avatar
Posts: 30   (View Stats)
myspeed90 has a spectacular aura aboutmyspeed90 has a spectacular aura aboutmyspeed90 has a spectacular aura about
Default throw out bearing
Bought a throw out bearing for my genwon and it was wrong. Claimed to be for the turbo engine but its definitely wrong. Ended up going to Mazda and buying. Part # N4115
88mm Wiseco pistons_Manley H- beam rods_CPE Injector seals_Clevite Bearings_Autotech Internals_HKS SSQV_Cobb SRI/TIP_COBB V3_JBR 88 duro pmm_JBR rmm_Turbine Tech FMM_CxRacing FMIC_TurboXs Catless DP/TP_South Bend Stage 3 DD_That Corn Shit_FREEKTUNE!
myspeed90 is offline   Reply With Quote
The Following User Says Thank You to myspeed90 For This Useful Post:
illegal shishkebab (10-22-2017)
 Old 09-01-2016, 01:20 PM   #34
dead-zone's Avatar
Posts: 442   (View Stats)
dead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the world
Groaned at 53 Times in 17 Posts
WIX Cabin Air Filter fitted perfectly gen1.
ACDelco rear coil springs were about half inch longer, though no noticeable change in car height or handling. The springs hardness feels same as the stock one, if not even slightly firmer.
MEVOTECH Rear LCA also fitted fine.
dead-zone is offline   Reply With Quote
 Old 11-27-2016, 02:15 PM   #35
cjbevington's Avatar
Posts: 27   (View Stats)
cjbevington is a splendid one to beholdcjbevington is a splendid one to beholdcjbevington is a splendid one to beholdcjbevington is a splendid one to beholdcjbevington is a splendid one to beholdcjbevington is a splendid one to beholdcjbevington is a splendid one to behold
I had to return an A/C compressor. The return was really easy, that place is awesome for parts (when they fit).
cjbevington is offline   Reply With Quote
The Following User Says Thank You to cjbevington For This Useful Post:
 Old 09-08-2017, 07:54 PM   #36
Lex2007's Avatar
Posts: 554   (View Stats)
Do not use National # 510096 front wheel bearing for Mazdaspeed 3. It fits but the wheel speed sensor won't get the correct signal and you'll get DSC and ABS dash lights.
illegal shishkebab likes this.
 Old 09-15-2018, 05:50 PM   #37
skyms6's Avatar
Posts: 29   (View Stats)
skyms6 has a spectacular aura aboutskyms6 has a spectacular aura about
has anyone purchased a clutch from rock auto ? if so which one do you recommend im looking to purchase one from them
thanks
skyms6 is offline   Reply With Quote
 Old 09-15-2018, 09:49 PM   #38
Solarsurge's Avatar
Posts: 571   (View Stats)
thanks
That LUK clutch in the picture is the OEM clutch. That's a steal for $200 considering it comes with the pilot bearing, release bearing, and alignment tool.
Edit: You MUST replace the flywheel bolts if you replace the flywheel or have it cleaned up. They are one-time use only. Don't forget about those.
 Old 09-15-2018, 10:07 PM   #39
skyms6's Avatar
do you think i need to replace the fly wherl ?
 Old 09-15-2018, 10:14 PM   #40
Solarsurge's Avatar
It is 100% necessary for the flywheel to have a clean, perfect mating surface for the clutch to grab. If the clutch wore down to the rivets or damaged the flywheel at all, it will have to be replaced or at least resurfaced. Fidanza is a cheap option and it's lighter, which is just a bonus. OEM Flywheel is hella expensive. If the flywheel is undamaged, clean it well with denatured alcohol. Be VERY careful to only use a TINY bit of lubricant on the splines and be careful when you re-grease the fork and release bearing. That shit's gonna spin at 6000 RPM, which will send any excess lubricant all over the place. If any lubricant at all gets into the clutch, you're gonna have a bad time.
skyms6 (09-15-2018)
HTML code is On
Rock vs Fog light SWAY Gen2 MS3 General Discussion 41 09-10-2011 02:11 PM
Page generated in 0.57183 seconds with 50 queries
