| Caldazar | 02-20-2011 06:26 PM | for the rear, stick the jack under the rear diff if your jack is long and low enough, then you can jack up the whole rear at once. Block the front wheels so it can't roll forward as you go up. Then when its up high, put a jackstand under both sides of the rear of the car, on the jacking points forward of each rear wheel.
I don't specifically know where on the front to do this, but most cars have some sort of cross member that you can jack up on. If you can find a strong spot to jack the front up on(not the engine, not the rad support), you can get it up high then put a jackstand on both sides quickly and easily.
I have never done this on a Speed6, as I have been able to use the hoist at work, but I have done this tons of times on my Talons, my Galant, and other cars like this at home. Just for changing tires, this goes really fast at home. I did an awd trans swap at home in my Galant like this as I didn't want to leave the car at work while the tranny was being rebuilt. Car was on there for a few weeks as the weather was shitty once I got the tranny back. it was nice and solid and quite high up as the tranny comes out and goes in from the bottom.
If your jack won't make it under far enough to hit the diff, you can find a spot on one side in the front(more weight there) and then just keep jacking it up till the rear tire is off the ground as well. The front will come off first, but the rear will lift in a bit too. Then you can stick a jack stand under the front and rear on one side. Then, do the same on the other side. I used to work at a pretty low budget shop and we had to do it like this all the time. Even Volvo wagons would lift just fine like this.
Keep it safe tho, pay attention to where you put the jackstand. Lower it with the jack SLOWLY and keep weight on the jack until you are sure its a good solid spot for support. If it looks like the area is going to start to collapse, jack it back up and move the stand.
I find that the doubled up areas on the pinch weld(under the rocker panels), or suspension pickup points are very good. On Talons, I often use the front lower rear control arm bushing pickup areas. The cupped part of the jackstand fits nicely under the rounded lower half of the bushing and holds it securely.
Good luck |
