 Old 10-10-2015, 01:14 PM   #1
JP90's Avatar
Posts: 84   (View Stats)
JP90 is a jewel in the roughJP90 is a jewel in the roughJP90 is a jewel in the roughJP90 is a jewel in the rough
Groaned at 8 Times in 4 Posts
Default Shifter plate/ Short shifter
So one of my next mods is going to be a short shifter or shifter plate. Im not exactly clear on a few things. So a shifter plates goes in the engine bay on the trans and I know what a short shifter is.
So if a shifter plate goes on the trans and the short shifter is in the vehicle can you install both and get a ridiculous amount of shft reduction? or is that just a completely insane idea?
JP90 is offline   Reply With Quote
 Old 10-10-2015, 01:39 PM   #2
superman's Avatar
Posts: 288   (View Stats)
superman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond repute
You could but most people don't. Short shifter can also reduce the knob height. This to me looks cool, but isn't practical due to the position of the shifter in relation to the armrest etc. Shift plates are inexpensive and easier to install. It's all about personal preference.
sent from my ONEPLUS 2
Power: Powered by Purple Drank, BNRS3, JBR 3.5, Grimspeed EBCS, 3-bar map, CP-e FMIC, Autotech HPFP, Forge V2 BPV, VTCS delete, DM OCC, Empire water pump pulley, BSD, JBR pan baffle, ebay downpipe, CP-e CBE, NGK step colder plugs, TIGs, CP-E Safe seals, DM EGR delete, etc. Handling: Eibach prokit, SPC camber arms, RX8 wheels, 235/40/18, Goodridge Stainless brake lines, EBC redstuff, mazda 5 rear brakes, Custom mid chasis brace, WR front strut brace, TB traction bar, TB trunk brace, JBR rear sway bar, Moog links, DM RMM, OEM poly filled PMM, CS TMM insert, JBR solid shifter bushings, AP shift hammer, Other: Android Stereo running torque pro, MZ style lip, Corksport LED lights, HIDs, lots of other random stuff
superman is offline   Reply With Quote
 Old 10-10-2015, 02:27 PM   #3
nekret's Avatar
Posts: 421   (View Stats)
nekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the world
The shifter replacements out there replace the lever that your shift knob threads on to. I guess some folks have issues with the stock shifter shearing off so it helps eliminate a possible weak point there.
I've never had a short shift plate but I have JBR's short shifter and it works as advertised to reduce the semi looking shifter setup our cars came with and does make the shifts significantly shorter. It does however have some rotational slop that i'm not a big fan of, but corksport has one with a different design that people are pretty happy with.
2011 Mazdaspeed3 non-tech package
Drivetrain
CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune
Chassis
JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace
Rice
LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers
nekret is offline   Reply With Quote
 Old 10-10-2015, 02:27 PM   #4
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
I have an old E4P (defunct) short shifter. It's nice. I did use a SSP too for years, recently removed to try it without again. I kinda miss it, throw is longer than I like, hits the cups in the holder a bit more than I like. Probably my 8 ball knob though.
 Old 10-10-2015, 03:02 PM   #5
JP90's Avatar
Alright I was just seeing if using the 2 together would give an even shorter throw than just one or the other. If it wont give a shorter throw than id rather just have a real short shifter cause that shifter height is super odd. Thanks guys
 Old 10-10-2015, 03:10 PM   #6
nekret's Avatar
FWIW I think a few people have run both but I don't think our transmissions like shifting that quick.
Sent from my SM-G900V using Tapatalk
Drivetrain
Chassis
Rice
 Old 10-10-2015, 05:42 PM   #7
Raider's Avatar
Groans: 856
Correct synchros don't like them.
 Old 10-12-2015, 01:38 PM   #8
JP90's Avatar
Alright thanks guys. I think ill just go with an actual short shifter then
HTML code is On
DM Short shifter plate daniely Gen2 MS3 General Discussion 3 09-09-2012 07:33 PM
JBarone Short Shifter Plate Chief_Wiggum MazdaSpeed 3 - Engine, Transmission & Driveline 123 11-12-2010 05:45 AM
Page generated in 0.28227 seconds with 23 queries
