![]() | | #41 | ![]() |
| Harvestor of PU ![]() Join Date: Jun 2011 Location: in the snowy mountains of narnia
Rep Power: 920 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,911
Groans: 170
Groaned at 25 Times in 20 Posts
| Not Ranked : 0 score
__________________ 2012 BM MS3 w/ tech. No bolt ons. self tuned. |
| The Following User Says Thank You to Harvey PU For This Useful Post: | Downmented (10-31-2012) |
![]() | | #42 | ![]() |
| Engineered Tuning ![]() ![]() ![]() Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 8419 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,258
No way an SST maxes out a 3" MAF housing. Good luck with the 11s. Time for some weight reduction
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #43 | ![]() |
![]() Join Date: Nov 2011 Location: Caldwell, ID
Rep Power: 563 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 664
(Thread Starter) | Not Ranked : 0 score IIRC, running 4.55+ volts is maxxing a maf out, correct? Last time I had it gutted, I was 3140. I can probably get her down to about 3100 for the track.
__________________ - Stock OEM k04 - Cobb AP - 3" ATP MAF w/9" Amsoil Filter - Grimmspeed EBCS - cryo'd Act 6 Puck w/Streetlite FW - HTP 3" Inlet - Bosch 3 Bar w/PNP Harness - Forge BPV V1 - CP-E 3" Single SS Exhaust - M2 Dp - Custom FMIC - PTP BSD - EGR Delete - Sonic Tuning S3 CO's - Enkei PF01 - 235/45/17 Toyo T1 Sport - Sure Dreadnaught - Sure Torq - AWR Pass. MM - PTP RV - KMD Internals - 50/50 e85 - Sure Countershift - Blox 490 LE - PNP'd IM/Head - VG Sharkfin Antenna - Car_Led Tails - Speedline CF Grill - 12.301 @ 113.20, stock turbo, stock ex. manifold, stock clutch ![]() Awaiting: The first 11 sec STOCK k04 powered Mazdaspeed!!!! ![]() ![]() Last edited by h.h.sk1nny; 10-30-2012 at 10:06 PM. |
| The Following User Says Thank You to h.h.sk1nny For This Useful Post: | Jh8909 (10-30-2012) |
![]() | | #44 | ![]() |
| Not Ranked : 0 score No running 4.90volts is maxing it out and you need about 450 g/s to do this on a 3 inch.
| The Following 4 Users Say Thank You to Lex For This Useful Post: | atvfreek (10-31-2012), h.h.sk1nny (10-30-2012), ms3blackmica (10-31-2012), RichieRichness (10-31-2012) |
![]() | | #45 | ![]() |
(Thread Starter) | Not Ranked : 0 score I can do that with the sst, I just need to get downmented to start blowin like he does as well
__________________ - Stock OEM k04 - Cobb AP - 3" ATP MAF w/9" Amsoil Filter - Grimmspeed EBCS - cryo'd Act 6 Puck w/Streetlite FW - HTP 3" Inlet - Bosch 3 Bar w/PNP Harness - Forge BPV V1 - CP-E 3" Single SS Exhaust - M2 Dp - Custom FMIC - PTP BSD - EGR Delete - Sonic Tuning S3 CO's - Enkei PF01 - 235/45/17 Toyo T1 Sport - Sure Dreadnaught - Sure Torq - AWR Pass. MM - PTP RV - KMD Internals - 50/50 e85 - Sure Countershift - Blox 490 LE - PNP'd IM/Head - VG Sharkfin Antenna - Car_Led Tails - Speedline CF Grill - 12.301 @ 113.20, stock turbo, stock ex. manifold, stock clutch ![]() Awaiting: The first 11 sec STOCK k04 powered Mazdaspeed!!!! ![]() ![]() |
| The Following User Says Thank You to h.h.sk1nny For This Useful Post: | Harvey PU (10-30-2012) |
![]() | | #46 | ![]() |
| SPEED PERF6RMANC3 ![]() ![]() Join Date: Jun 2011 Location: Laurel, Maryland
Rep Power: 2089 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,207
Groans: 273
Groaned at 55 Times in 37 Posts
| Not Ranked : 0 score Bitch, i max out 7'' maf housing blowin over 9000gs. Shouldnt be a problem.
__________________ //KILLAH BUILT, SPEED PERF6RMANC3// Steedspeed T4 Twin Scroll // Precision 6265 Single 44mm Wastegate. KILLAH BUILT //FREEKPERM // Nuffsaid
| The Following 4 Users Say Thank You to Downmented For This Useful Post: | h.h.sk1nny (10-31-2012), Juyoung (02-20-2013), ms3blackmica (10-31-2012), RichieRichness (10-31-2012) |
![]() | | #47 | ![]() |
| can't take out voltron ![]() Join Date: Apr 2012 Location: Wood-Ridge, NJ
Rep Power: 4920 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,179
lmao this is great !
![]() | | #48 | ![]() |
| Approved MSF Vendor ![]() Join Date: Mar 2010 Location: Germantown MD
Rep Power: 1778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,900
Groans: 33
Groaned at 16 Times in 11 Posts
update...I'm going to MIR next weekend so I can shit all over h.h.sk1nny's face ![]() or break another axle
__________________ Cobb AP w/RichTune | IWG gt3071r | JMF IM | DNP Exh Mani | NATOR D.C. FMIC | JBR Wide Path | Autotech Internals | HKS SSQV2 | Ebay DP | PG TIP | Denso ITV22 | PTP Intake Gasket | Prosport OCC | Prosport Gauges | TWM Bushings | NATOR D.C. SS | SU RMM | CP-e RDM | AutoExe Strut Tower Bar | Whiteline RSB | Megan Springs w/Drag Bags | DSS Driver Side Axle | PERM CC Plate | JMF OCCs 331 awhp 397 awtq @ Moore Automotive 11/10/2012 on ~e48 Stock Turbo 12.263 @ 111.75 mph 1.669 60' 11/17/2012 - Stock Turbo World Record! ![]() Visit RichTune.org or message me for a tune $699 for Cobb AccessPORT + RichTune |
![]() | | #49 | ![]() |
@RichieRichness What is your track weight? How are you going to pick up 4mph? Good luck tomorrow buddy!!!!
| The Following 2 Users Say Thank You to h.h.sk1nny For This Useful Post: | Downmented (11-09-2012), RichieRichness (11-10-2012) |
![]() | | #50 | ![]() |
Groans: 33
I don't need to trap 114. I'll be good with 112 or 113 since my 60' kicks ass. Sent from my iPhone using Tapatalk
__________________ Cobb AP w/RichTune | IWG gt3071r | JMF IM | DNP Exh Mani | NATOR D.C. FMIC | JBR Wide Path | Autotech Internals | HKS SSQV2 | Ebay DP | PG TIP | Denso ITV22 | PTP Intake Gasket | Prosport OCC | Prosport Gauges | TWM Bushings | NATOR D.C. SS | SU RMM | CP-e RDM | AutoExe Strut Tower Bar | Whiteline RSB | Megan Springs w/Drag Bags | DSS Driver Side Axle | PERM CC Plate | JMF OCCs 331 awhp 397 awtq @ Moore Automotive 11/10/2012 on ~e48 Stock Turbo 12.263 @ 111.75 mph 1.669 60' 11/17/2012 - Stock Turbo World Record! ![]() Visit RichTune.org or message me for a tune $699 for Cobb AccessPORT + RichTune | |
![]() | | #51 | ![]() |
(Thread Starter) | Not Ranked : 0 score You have to have one BADASS 60' to run 11s with a 112 trap.
![]() | | #52 | ![]() |
Groans: 33
12.39 so far skinny nuts. Sent from my iPhone using Tapatalk
![]() | | #53 | ![]() |
Groans: 273
| The Following 5 Users Say Thank You to Downmented For This Useful Post: | atvfreek (11-17-2012), Black Metal (11-17-2012), RichieRichness (11-17-2012), superskaterxes (11-17-2012), The Panda (11-17-2012) |
![]() | | #54 | ![]() |
im lovin this competition lol
| The Following 2 Users Say Thank You to ms3blackmica For This Useful Post: | Juyoung (02-20-2013), RichieRichness (11-17-2012) |
![]() | | #55 | ![]() |
| Utah Mazdas ![]() Join Date: Feb 2011 Location: Utah
Rep Power: 674 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,078
Groans: 76
Groaned at 6 Times in 6 Posts
__________________ - 06 Black Mica MS6 - - GT3071R 24PSI - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP - - Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught - - E20 - GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete - 12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30 12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20 Dynojet 301 AWHP 359 AWTQ SAE Corrected on K04 and Corn Dynojet 391 AWHP 387 AWTQ SAE Corrected on 3071 and Corn | |
| The Following User Says Thank You to Black Metal For This Useful Post: | Downmented (11-17-2012) |
![]() | | #56 | ![]() |
Groans: 273
| Not Ranked : 0 score I will let rich come in and share his victory here
| The Following 3 Users Say Thank You to Downmented For This Useful Post: |
![]() | | #57 | ![]() |
Groans: 33
| The Following 13 Users Say Thank You to RichieRichness For This Useful Post: | atvfreek (11-17-2012), Black Metal (11-18-2012), Boost_creep (11-17-2012), h.h.sk1nny (11-17-2012), Juyoung (02-20-2013), lilred (11-17-2012), ms3blackmica (11-17-2012), nindoja (11-17-2012), Rainmens (11-17-2012), SarcasticOne (11-17-2012), Schmitty5 (11-17-2012), superskaterxes (11-17-2012), The Panda (11-17-2012) |
![]() | | #58 | ![]() |
Rep Power: 8513 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,112
Groans: 31
Groaned at 19 Times in 16 Posts
| Not Ranked : 0 score Freekn tappin
__________________ 2010 Speed3---GTX2867 // SURE 3" Intake // HTP 3" inlet pipe // Ultimate Racing DP/TP // Corksport CBE // KMD v2.1 hpfp internals // Devils Own WMI // COBB FMIC // 3bar map sensor // GFB dual port BPV // JBR 70 duro RMM // MD Dual OCC // Drag DR-34 18x8 // Nitto Neo-gen 235/40 r18 // NJSPEED3 Ported Intake Manifold // JBR TIGS Perm Tune by the Freek ![]() 417hp/395tq 12.903@117.33 Street tires and shitty 2.25 60ft | |
| The Following 4 Users Say Thank You to atvfreek For This Useful Post: | Juyoung (02-20-2013), ms3blackmica (11-17-2012), RichieRichness (11-17-2012), superskaterxes (11-17-2012) |
![]() | | #59 | ![]() |
Congrats dude, nice 60 too....Don't worry buddy, I will get some 11s before you!!! Awwwww, sea level must be nice.
| The Following 3 Users Say Thank You to h.h.sk1nny For This Useful Post: |
![]() | | #60 | ![]() |
oh snapppppppppppppp rich ! hhsk1nny said he will still 1 up you ! |
| The Following 2 Users Say Thank You to ms3blackmica For This Useful Post: | Downmented (11-17-2012), h.h.sk1nny (11-17-2012) |
![]() | | #61 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Rockville, md
Rep Power: 10008 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,737
Groans: 98
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust 510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs WWW.SONICTUNING.COM Certified RichTune e-Tuner KILLAH BUILT by SPEED PERF6RMANC3 | |
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | ms3blackmica (11-18-2012), Rainmens (11-17-2012) |
![]() | | #62 | ![]() |
__________________ - Stock OEM k04 - Cobb AP - 3" ATP MAF w/9" Amsoil Filter - Grimmspeed EBCS - cryo'd Act 6 Puck w/Streetlite FW - HTP 3" Inlet - Bosch 3 Bar w/PNP Harness - Forge BPV V1 - CP-E 3" Single SS Exhaust - M2 Dp - Custom FMIC - PTP BSD - EGR Delete - Sonic Tuning S3 CO's - Enkei PF01 - 235/45/17 Toyo T1 Sport - Sure Dreadnaught - Sure Torq - AWR Pass. MM - PTP RV - KMD Internals - 50/50 e85 - Sure Countershift - Blox 490 LE - PNP'd IM/Head - VG Sharkfin Antenna - Car_Led Tails - Speedline CF Grill - 12.301 @ 113.20, stock turbo, stock ex. manifold, stock clutch ![]() Awaiting: The first 11 sec STOCK k04 powered Mazdaspeed!!!! ![]() ![]() | |
| The Following User Says Thank You to h.h.sk1nny For This Useful Post: | ms3blackmica (11-18-2012) |
![]() | | #63 | ![]() |
| 720-989-4238 ![]() Join Date: Apr 2011 Location: San Marcos, Texas
Rep Power: 1560 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,545
Groans: 302
Groaned at 124 Times in 75 Posts
| Not Ranked : 0 score -1500' DA?
__________________ ![]() ![]() |
| The Following User Says Thank You to PU Manchu For This Useful Post: | h.h.sk1nny (11-18-2012) |
![]() | | #64 | ![]() |
Groans: 33
Niggah I beat you with 300+ extra lbs, stock clutch that has over 89,000 miles on it, stock exhaust mani, and more than 1/4 tank of gas in the car. I can't guarantee 11's but I will be faster come spring. Sent from my iPhone using Tapatalk
| The Following 3 Users Say Thank You to RichieRichness For This Useful Post: |
![]() | | #65 | ![]() |
Groans: 31
Do you have a log of the tune you ran. I would love to take a peak. Freekn tappin
![]() | | #66 | ![]() |
Groans: 33
| Sk1nny's Billet5857 Build | h.h.sk1nny | MazdaSpeed 3/6 - Big Turbo Builds | 10 | 08-21-2012 04:02 PM |
| Big Install Plans | spedo3 | Gen2 MS3 General Discussion | 8 | 07-12-2012 07:43 AM |
| Chevy plans new Colorado pickup, mum on U.S. plans | Haltech | Automotive News | 0 | 03-08-2011 09:10 PM |
