 Old 09-14-2018, 04:18 AM   #1
Tiner's Avatar
Posts: 116   (View Stats)
Tiner will become famous soon enoughTiner will become famous soon enough
Default Some codes after going back to stock engine
Hi!!!
I recently removed all the aftermarket parts I had installed in my MS3.
BNR S4, internals, downpipe, intake, IC.
Now I'm getting some codes, some of them pop up the light of engine failure in the dash.
Here they are.
1. PCM
2. P0037
3. IC
4. U2064
Which one is causing this? I suspect it is the one O2 related.
Could it be possible to have that code because of not having installed the hose that cames out from here?
Enviado desde mi SM-G950F mediante Tapatalk
Tiner is offline   Reply With Quote
 Old 09-14-2018, 05:55 AM   #2
shamie's Avatar
Posts: 924   (View Stats)
Did you go back to the stock tune?
2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, 51R Battery Box & Raider's AD / StopTech Brakes
 Old 09-14-2018, 06:15 AM   #3
Tiner's Avatar
Yeah!
Running now stock stage 0 Cobb tune, as Im still logging with the accesport.
HTML code is On
Trouble codes new engine ThatJuanMS3 MazdaSpeed 3/6 - ECU Computer Tuning 13 12-15-2017 03:04 PM
Engine died - no codes kvg823 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 12-15-2014 03:26 PM
few check engine light codes berni6163 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 01-17-2012 07:11 PM
Why No MIL/CEL/codes on BLOWN ENGINE? ASIC_BSEE MazdaSpeed 3/6 - ECU Computer Tuning 27 01-16-2010 08:48 AM
Page generated in 0.25049 seconds with 21 queries
