Notices
Like Tree2Likes
  • 1 Post By ms3blackmica
  • 1 Post By dale_gribble
 Old 10-19-2012, 08:23 PM   #1
dale_gribble's Avatar
Posts: 1,048   (View Stats)
Groaned at 7 Times in 4 Posts
Default SU Turbosmart - 10-20psi or 20-25psi spring for stock k04??
My stock BPV was slowly losing its ability to hold boost with the Stratified Tune I am running until last week where it abruptly started leaking anytime I was on the boost.
Lex's tune has my k04 running at ~21psi @ ~4000 or so and tapering down to 19psi at redline.
I just received my SU BPV today with the optional spring.
My boost curve kind of runs on the edge of both springs which is why I am looking for feedback. Should I run the 10-20 or the 20-25? Is the spring rating based on max boost or where the turbo spends most of its time?
Help is appreciated. Thanks.
dale_gribble is online now   Reply With Quote
 Old 10-19-2012, 09:01 PM   #2
Whiteboy's Avatar
Posts: 1,916   (View Stats)
Whiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the world
Groans: 128
Groaned at 34 Times in 22 Posts
I was wondering this myself...
~My Mod List: ETS TMIC; CP-E SRI; COBB TIP; CP-E DP; CP-E RMM; CP-E Safe Seals; ITV-22's; GHL SS CBE; TWM STS w/bushings; Autotech HPFP Internals; AP (Stratified by Lex); Matt Damond OCC; CP-E Triple Gauge Pod w/ Prosport Premium Boost, AFR, and Oil Pressure Gauges; JBR Eliminator Shift Knob~
Whiteboy is online now   Reply With Quote
 Old 10-20-2012, 12:29 AM   #3
XerocX's Avatar
Posts: 455   (View Stats)
XerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond repute
What color is the 10-20 spring?
2009 CWP MS3
COBB Accessport, COBB SRI, HTP TIP, PG FMIC, Autotech internals, Guardian Angel, TurboSmart Dualport BOV (VTA), CNT Catless DP + CBE, JBR Dogbone rmm, JBR RSB, Sure Shortcut, H&R Springs, CPE tow plate, MRR GT-1 18x8.5+ 35
XerocX is offline   Reply With Quote
 Old 10-20-2012, 01:12 AM   #4
can't take out voltron
ms3blackmica's Avatar
Posts: 3,852   (View Stats)
The springs are all the same color, they just come with some paint on the side to mark them. 10-20 psi spring has green paint. 20-25 psi spring has pink paint.
I always had the SU TS BPV for 3 years now and always had the 10-20 psi spring. It caused issues for me when i started to run 21 psi. Boost would taper off earlier in the RPM range. I ordered the 20-25 psi spring and now boost is holding strong.
My opinion, its worth it.
dale_gribble likes this.
2009 MS3 GT: Stock HID's and an NJSPEED3 Mani
"NJ Nator the home of makeshitfit technology" - voltron
"I didn't build it hoping for your approval...I built it because it meets mine."
ms3blackmica is online now   Reply With Quote
dale_gribble (10-20-2012)
 Old 10-20-2012, 01:19 AM   #5
XerocX's Avatar
I am running my dual port vta using the Guardian Angel and it flutters in low boost and also in higher boost (surge?). I loosened the tension a little past where the red mark is and still get it. I heard by using a softer spring it eliminates the flutter. my boost is 19.5 psi. Any tips?
2009 CWP MS3
 Old 10-20-2012, 01:29 AM   #6
I am not framiliar with the dual port.
I only have the TS BPV (only recirculates).
Lex could answer that for you.
 Old 10-20-2012, 01:37 AM   #7
XerocX's Avatar
Thanks
2009 CWP MS3
 Old 10-20-2012, 10:09 AM   #8
I ran the 20-25 psi spring. It was fine. It held boost with no partial boost flutter.
Thing is quieter than stock. I like it.
2006 MS6 WWP Sport
Autotech guts | Sure Aeros Full 3" CAI mod | CS race pipe | 18x8 TR C2 | 235/40
Turbosmart BPV | AP | Stratified | 3" dual catback | SU tmic | Autoexe springs
Do Stage 2 WMI D07 50/50 | Derale 190F fan controller
Next: NATOR down pipe
 Old 10-20-2012, 12:10 PM   #9
fivefingerdeathpunch's Avatar
Posts: 160   (View Stats)
fivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond repute
does yours hit boost targets? i tried using the 20-25psi spring when i was running 21psi and for some reason i was only able to hit 18psi or so with the stiffer spring
2006 White Water Pearl Mazdaspeed6 Grand Touring #5430
BNR S3 currently being tuned
SURE RMM - VG Sharkfin - HTP 3" TIP - SSP BigMAF SRI - GS EBCS - M2 Catless DP - Autotech HPFP Internals - Fiberglass Badgeless front grill - 20% tint - CAR LED tails - Smoked side markers - Pdipped emblems - Cobb AP - CS LED Interiors/DRL - Sub Preamp - HD lip - NGK Iridium 1step colder - Custom 2.5" FMIC w/ TR8 - Prosport Mechanical Boost Gauge w/ Block8head's Single 52mm VentPod - GHL Resonated Dual Catback Exhaust - TS/SU DP BOV -
fivefingerdeathpunch is online now   Reply With Quote
 Old 10-21-2012, 03:38 PM   #10
Ya, mine was hitting boost targets no problem.
2006 MS6 WWP Sport
 Old 10-21-2012, 04:00 PM   #11
nybe0010's Avatar
Posts: 133   (View Stats)
nybe0010 has a reputation beyond reputenybe0010 has a reputation beyond reputenybe0010 has a reputation beyond reputenybe0010 has a reputation beyond reputenybe0010 has a reputation beyond reputenybe0010 has a reputation beyond reputenybe0010 has a reputation beyond reputenybe0010 has a reputation beyond reputenybe0010 has a reputation beyond reputenybe0010 has a reputation beyond reputenybe0010 has a reputation beyond repute
Groaned at 4 Times in 2 Posts
I have the dual port as well and i experienced flutter in low boost when i was running recirc now i have no issues while im 50/50. Im curious as to whether or not i may need a different spring when i get a tune and run more boost, but maybe you could go 50/50 see if that solves it?
11' Black Mica MS3 Cobb AP/EBCS/FMIC piping Treadstone TR6 AT Internals unSURESRI/TIP Forge V1 BPV JBR 88 Fully Mounted/SSP/Bushings/Weight/TIGs CNT catted DP/CBE c-pe SafeSeals Pioneer 4300dvd NGK DDM Lamin-X AWAITING INSTALL:Block8head Dual Vent Pod Blowshift Boost/OP MD OCC VTA PERM Butt Plug
nybe0010 is offline   Reply With Quote
 Old 10-21-2012, 04:27 PM   #12
XerocX's Avatar
I have my recirc hose plugged due to being VTA. I think I remember someone said they went with a softer spring and they had no flutter. I'm at 19.5psi and am wondering if the softer spring will hold that.
2009 CWP MS3
 Old 10-21-2012, 06:31 PM   #13
nybe0010's Avatar
Alright well give that a shot and then let me know! Im going to be getting tuned pretty quick here and i may run into similar issues. Any particular reason you run VTA ive read around and ppl mostly only have negative things to say?
 Old 10-21-2012, 06:38 PM   #14
XerocX's Avatar
Yeah man, I installed a Guardian Angel for overboost protection (hit up Lex for more info) and it has an option to run your bov VTA with no ill effects on the car. It already saved my ass once too!
2009 CWP MS3
 Old 10-21-2012, 06:56 PM   #15
nybe0010's Avatar
damn thats sick plus you get all the noise even 50/50 is soo much louder than recirc. My AP showed me hit 23 psi and threw the overboost code when i was running a stage 1 map and i didnt have my internals in yet cut out like a mofo and scared the shit out of me. I saw the guardian angel on their site im looking into getting stratified i will probably end up getting it!
 Old 10-21-2012, 07:03 PM   #16
XerocX's Avatar
Right on man! Check them out, Lex will answere all your questions, he helped me out a lot. I'm VERY happy with my purchase
2009 CWP MS3
 Old 10-21-2012, 07:12 PM   #17
nybe0010's Avatar
Sounds good will do !
The Following User Says Thank You to nybe0010 For This Useful Post:
XerocX (10-21-2012)
 Old 04-17-2013, 02:26 PM   #18
The softer spring is leaking on me around 20 psi. Piece of shit. The hard spring is too hard and I get some compressor surge and the soft spring is too soft now.
2006 MS6 WWP Sport
 Old 04-17-2013, 02:37 PM   #19
Boost_creep's Avatar
Posts: 587   (View Stats)
Boost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the world
FWIW, I've been running the softer spring at 20-21 psi for 2 years, and I love it.
No flutter, and holds boost like a champ!
2009 True Red Mazdaspeed 3 GT - 326whp/360wtq
E30, Cobb AccessPort, Cobb SRI/TIH, Sure ID300 Maf
UR v2 Catted Downpipe/Resonated Testpipe, Racing Beat CBE
Corksport TMIC/Tubes, Grimmspeed Ported Throttle Body
KMD v2.1 FP Internals, PTP Seals/Studs, JBR TIG/EGR Delete
Turbosmart BPV, Denso ITV22, Bosch 3 Bar, Optima RedTop
Snow Performance Stage 2 WMI Kit, Sure Torq R3 RMM
SPEC Stage 2+ Clutch, Goodyear Eagle GT, EBC Red Stuff
H&R Coilovers, Corksport RSB
Boost_creep is offline   Reply With Quote
 Old 04-17-2013, 02:42 PM   #20
mituc's Avatar
Posts: 903   (View Stats)
I used the soft spring with a 24PSI tune and it was fine. I think the ability of the BPV to hold boost is not necessarily dependent on the opening pressure. When into boost you have the same boost pushing the piston into the closed position both in the cold pipe and the other hose connecting to the IM. So as long as the pressure difference does not exceed a certain value that would make the spring compress (14PSI for the softer spring and 20 psi for the stiffer one) the piston should stay closed.
If you guys have problems with the Turbosmart BPV holding boost check that rubber o-ring/gasket at the top of the valve. Over time mine got longer for some reason (probably because of the Turbosmart Oil I was using, or heat stress?) and I had a very hard time threading that cap back after I was lubing the piston. Last time I lubed the piston it took me 20 full minutes to put it back in place, and this used to take less than a minute. When I got back in the house I ordered a Cobb XLE which requires less maintenance thanks to the low friction material used for the piston coating.
2008 Cosmic Blue Mazda 3MPS
Bilstein B14 PSS, SSR Type-F, Michelin PSS 225/40/R18 US Spec, CS RMM Inserts, AutoExe Street Pads
Cobb SRI, SU TMIC, Cobb XLE, NGK LTR7IX, Corksport CAI Box, UR catted DP and res TP, GS EBCS, Autotech internals, GTX3071, Bosch 3BAR MAP Sensor
StratiVersaTuned
mituc is online now   Reply With Quote
 Old 04-17-2013, 03:21 PM   #21
I have had the Turbosmart BPV with the soft spring for a while. Every oil change, I pulled it apart and oiled it. I just recently inspected it and it was fine. It seemed to do fine, but lately, I started hearing (and seeing in logs) the BPV dumping some boost over 20psi at peak boost. I am not sure what changed since I first installed it. I don't think this is a leak at the o-ring; I think the spring is starting to compress and leak under 20+ psi boost pressure. Maybe the spring is getting a little tired? I don't know.
Anyways, I put the higher rate spring on and we'll see how it does. It isn't fluttering at partial boost and is holding boost fine.
2006 MS6 WWP Sport
 Old 04-17-2013, 09:13 PM   #22
mituc's Avatar
The spring gets indeed a bit softer over time but not too much and I still don't think it's a real issue.
I lubed mine every ait filter change which in my area has to occur at 3-5k km (2-3k miles), so a lot more often, and still the piston had some obvious wear marks on it.
I don't think mine was leaking (at 24PSI is becomes a lot more obvious), but eventually it would have. So pull the piston and take a look at it.
These are good valves, very easy to maintain and worth every penny. But sometimes they are just full of surprises.
So, OP, put the softer spring in, in my opinion you really don't need the stiffer one.
StratiVersaTuned
 Old 04-18-2013, 10:43 AM   #23
I am OP. I did need it. Ok, I did some more research here. Street Unit must be retarded or using ricer math to come up with their spring ratings (10-20psi, 20-25psi). Everything you will read is that springs aren't rated for boost. Repeat: Spring ratings are not rated for boost. I'ts a pull type valve; the vacuum sucks open the valve. Therefore, the springs are rated based on the amount of vacuum the car produces at idle to ensure the vacuum can sufficiently open the valve. Springs are rated relative to engine vacuum reading at idle on a warm engine. They are not rated on how much boost they can hold.
Turbosmart offers 2 springs with their BPV made for our car; these are the two springs that SU sells with this BPV:
TS-0203-3002 BOV Kompact DP Spring-Pink (rated at 15-21 in/hg)
TS-0203-3003 BOV Kompact PB Spring-Green (rated at 10-16 in/hg)
Our cars typically idle at -10.5psi (~21 in/hg). Therefore, the Pink spring (15-21 in/hg) (the supposed 20-25psi spring) IS the correct spring for our cars. I confirmed yesterday that the spring has a little pink paint on it when I swapped it out. I am running this spring and it is working perfectly.
I find it very unlikely that SU ran spring rate tests and found some way to definitely rate the 'boost rate' of the springs.
ms6forthewin likes this.
2006 MS6 WWP Sport
ms6forthewin (04-24-2013)
HTML code is On
K04 @ 20psi vs 3071R @ 20psi Questions Alpha MazdaSpeed 3/6 - Turbo Induction 109 04-11-2011 01:37 PM
Overboosting 25psi on Stock Tune!? SoyBean MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 11-23-2009 01:50 PM
Page generated in 0.44394 seconds with 27 queries
