![]() | | #1 | ![]() |
![]() Join Date: May 2009 Location: Clw/ NPR Florida
Rep Power: 1334 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,952
Groans: 85
(Thread Starter) | Not Ranked : 0 score Is it a direct fit without any problems. Just install and adjust valve clearance ?
__________________ 2006 speed6~Cobb AP~COBB custom E-tune~CobbTIP-CobbSRI~CPeHPFP~ATPdp~Magnaflow exhaust~Denzo plugs~Forge bov~Matt Damon's Occ Kit~Treadstone FMIC~PG V1 Ex.Manifold~CPE safe seals~SU EGR block off plate~SURE TIG intake mani gasket~SU lower motor mount~AWR trans. mount/passenger mount~SU shifter bushings~CPE diff mount~H&R springs~Tenzo type M ~235/40/18 Firestone Indy 500 Wide Oval~ipod adapter~HD lip~Prosport boost gauge~ TWM Desert Eagle Shift Knob~JBR shift plate~spin on oil filter~Block8head Vent Pod~ported intake manifold w/ VTCS delete~EBC red pads w/ slotted rotors~4500k HID fogs 2 gal. E85 mix !!! " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " |
Groans: 85
![]() Join Date: Feb 2009 Location: Atlanta Ga
Rep Power: 663 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 957
i would like to know this as well i have a spare head and i have been thinking about building it up
![]() | | #4 | ![]() |
![]() Join Date: Apr 2011 Location: Winston-Salem, NC
Rep Power: 1632 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,329
Groans: 185
same here head waiting for build...
__________________ Beating Black women one 5.0 at a time... ![]() 2008 mazdaspeed 3 true red Hypnotic tuned, BNR stage 3, pnp manifold, Cobb three port, Forge BPV, ETS 3.25 TMIC, cobb AP, EBC redstuff full, DBA 4000 rotors 6x6 slotted, MSCAI, JBR 88d rmm, JBR 80d pmm, JBR 80d tmm, Cobb TIP, CNT catted DP, Magnaflow CBE, KMD internals, Koni Yellows, Moog endlinks, OZ ultraleggera 18x8, Mich Pilot Super Sports 235/40/18, Hotchkis RSB, NGK step colder plugs.![]() |
![]() | | #5 | ![]() |
| Hair by Voltron ![]() Join Date: Feb 2009 Location: Hillsborough, NJ
Rep Power: 146635 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 51,478
Groans: 1,406
Groaned at 311 Times in 293 Posts
Are you talking about the larger diameter Supertech valves?
__________________ ![]() 11.91 @ 122.48 1.85 60' - 12/4/11 - Atco Raceway 11.85 @ 119.69 1.75 60' - 4/15/12 - Mason Dixon Dragway For Sale Section Rules UPDATED 5-17-2013! Please read before posting! |
![]() | | #6 | ![]() |
| Will fuck up ur day ![]() Join Date: Feb 2010 Location: Parrish, FL
Rep Power: 3506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,865
Groans: 418
Groaned at 206 Times in 122 Posts
I think it's a direct fit, if you get stock size. Frankly, if you're not going bigger valves, no sense in going with supertechs. IMO some really big gains can be seen from having the head, ESPECIALLY the exhaust side, hogged out bigtime. I'm sure you can see on that spare block you have.
__________________ 07 MS3 bone stock? The original Genpoo Hater GTX3076r FenderRollerRental Rent a fender roller, or MZR DISI Timing tools! Turismo Vids - Store your car vids and pics here! Blog your builds too!
![]() | | #7 | ![]() |
Groans: 85
Stock size valves .. (exhaust ) Supertech is way cheaper than OEM valves ..
![]() | | #8 | ![]() |
![]() Join Date: Feb 2011 Location: Vaughan, Ontario, Canada
Rep Power: 841 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 793
If you check out my build thread it has all the info. I used Supertech Inconel +1mm exhuast valves, and stock Mazda 2.3 NA valve guides. everything else was the DISI stock valvetrain. Oh I also used Supertech valve seals. You can use the Supertech bronze guides if you want. I chose not to in order to extend the service life of the built motor. bronze will take more heat away but will wear out faster. |
| The Following User Says Thank You to Celestspeed3 For This Useful Post: | jracer (09-24-2012) |
![]() | | #9 | ![]() |
What about springs and retainers? What do you feel safe reving out to?
![]() | | #10 | ![]() |
Engine builder said around 7500rpm, but there is no point with these cams. Just stick to 7000rpm.
![]() | | #11 | ![]() |
Did you not get the web cams?
![]() | | #12 | ![]() |
| Eth Fiend ![]() Join Date: May 2010 Location: Murhpysboro, IL
Rep Power: 6987 ![]() Thanks: 10,849
. Just a hunch that I'm investigating.
__________________ -06 MS6 - Tuning the high compression forged mill -Corn fed 07 MS3 - Sold | |
| The Following User Says Thank You to phate For This Useful Post: | silvapain (09-25-2012) |
![]() | | #13 | ![]() |
![]() Join Date: Jul 2011 Location: Clarksville, TN
Rep Power: 1552 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,278
Doing the supertech +1mm intakes and +1mm exhaust(maybe +2mm haven't decided), but my head work is gonna be fairly expensive.
__________________ "Intelligence isn't the ability to store information, but to find it" - Albert Einstein "When I read about the evils of drinking, I quit reading" - Henry Youngman | |
![]() | | #14 | ![]() |
| Not Ranked : 0 score Look to be similar price if you have access to Mazda Motorsports.
![]() | | #15 | ![]() |
| Not Ranked : 0 score What's the MSM price? A valve and a guide were about $28 +/- $1 when I bought them. that's the brass valve guides, the NA Mazda ones might have been a little more.
![]() | | #16 | ![]() |
Rep Power: 6866 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,524
Groans: 39
The oem valves dont honestly hold a candle to the supertech valves. The retainers I replaced with supertech cromoly, but its totally optional. The springs are good to 12,000+rpm for a n/a car, the problem with boost is that it pushes against the backside of the valve which makes the spring act weaker than it really is so it floats sooner. Someone only running 15psi needs the oem spring while someone running 30-40psi needs a much stronger spring to perform the same as the 15psi car. Hope that makes sence.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant |
| The Following User Says Thank You to 06Speed6 For This Useful Post: | GLORIFIEDBOZO (09-25-2012) |
![]() | | #17 | ![]() |
What do you mean by "don't hold a candle"?
__________________ -06 MS6 - Tuning the high compression forged mill -Corn fed 07 MS3 - Sold Last edited by phate; 09-24-2012 at 10:54 PM. | |
![]() | | #18 | ![]() |
| Eatin' Your Tuna ![]() Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,323
Groans: 218
Usually, aftermarket valves are choice IF you want to go oversized. Either way these fuckers are expensive. If you are just rebuilding the head with new hardware, OEM is the best route unless you pony up for shit like Ferrea or Crower. But again, if you are headed that route, might as well punch those valves out to as large as can be fitted, esp on the exhaust side of things. We do need a consolidated thread strictly on engine build parts, with part numbers, measurements/requirements, etc. Its been a long time coming now.
Welcome To http://www.mazdaspeedforums.org The HARDCORE Of Mazda High Performance Tech! COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | |
| The Following 5 Users Say Thank You to Haltech For This Useful Post: | anavrinIV (09-25-2012), GLORIFIEDBOZO (09-25-2012), jracer (09-25-2012), JTMS3 (09-25-2012), MS3-a(sore)ASS-rex (09-25-2012) |
![]() | | #19 | ![]() |
Groans: 85
Even not for a huge crazy build .. Just replacing bent valves, supertech is like half the price of OEM .. So for my case this may be a better choice ..
![]() | | #20 | ![]() |
| Works for beer ![]() Join Date: Apr 2011 Location: Jacksonville, FL
Rep Power: 101 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
This thread has been an on going question for me. Thanks for all the info folks. Subbed for future knowledge.
__________________ 09 Mazdaspeed 3 - Mazdaspeed CAI V2, COBB TIP, COBB DP, Corksport TMIC, CP-E HPFP, COBB AP, Currently being tuned by LEX. Numbers will be here when he is done with his mastery. Semper Fi |
![]() | | #21 | ![]() |
![]() Join Date: May 2009 Location: Kankakee, IL
Rep Power: 8105 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,037
Groans: 121
OE Valves: Intake - L3K9-12-111 $10.01 ea from MSM Exhaust - L3K9-12-121D $31.34 ea from MSM
__________________ ATP GTX3071 IWG . 10.5:1 pistons . K1 Rods . Balance Shaft Delete . COBB AP . eBay Special Catless DP . Mazdaspeed Accessory CBE . OCC . Autolite XP5364 Spark Plugs . TRZ TMM . TRZ RMM . MDM SSP . JBR Shifter Bushings . JBR EGR Delete . KW V1 Coilovers . SPC Rear Camber Arms . EBC Yellowstuff Pads . Autotech HPFP internals . 3-Bar MAP Sensor . N2MB WOT Box . ACT 6-Puck Sprung Clutch w/ Streetlite Flywheel . Konig Milligrams 18x8.5 et45 with 245/40's . GrimmSpeed EBCS . Self-PnP IM with VTCS removed . TWM full replacement shifter with 3" extension . TS BPV SU Edition . CX Racing FMIC . HTP 3.5" Intake . Lots of ricer mods . Beans Above the Frank Build http://www.mazdaspeedforums.org/forum/f541/beans-above-frank-build-115919/ | |
| The Following 5 Users Say Thank You to silvapain For This Useful Post: | GLORIFIEDBOZO (09-25-2012), Haltech (09-25-2012), jracer (09-25-2012), mzr0818 (09-25-2012), phate (09-25-2012) |
![]() | | #22 | ![]() |
Also if you are going oversized, unless you replace the valve seats which becomes expensive, you can only really go +1mm on exhaust, and about +.5mm on the intake which requires machining of the valve since they only come in +1mm.
| The Following User Says Thank You to GLORIFIEDBOZO For This Useful Post: | jracer (09-25-2012) |
![]() | | #23 | ![]() |
Groans: 85
would non inconel ex. valves work ?? WOW the MSM prices are really good ! to bad i dont have a account
![]() | | #24 | ![]() |
Groans: 121
As phate alluded to, he and I (and possibly others) have a suspicion that the OE exhaust valves are Inconel, hence the price. He has some of my original bent exhaust valves that he is going to have tested. Tapadatass
| The Following 3 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #25 | ![]() |
Groans: 39
Take it this way, say the intake valve has 1sq" of surface area on the back side, if your seat pressure is 30psi and you run 35psi of boost, that valve would never close. I believe the oem exhaust valve is stainless and the intake valve is coated steel, I dont know of any car in our cars price range that has inconel exhaust valves.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant | |
| The Following User Says Thank You to 06Speed6 For This Useful Post: | jracer (09-25-2012) |
![]() | | #26 | ![]() |
Groans: 85
__________________ 2006 speed6~Cobb AP~COBB custom E-tune~CobbTIP-CobbSRI~CPeHPFP~ATPdp~Magnaflow exhaust~Denzo plugs~Forge bov~Matt Damon's Occ Kit~Treadstone FMIC~PG V1 Ex.Manifold~CPE safe seals~SU EGR block off plate~SURE TIG intake mani gasket~SU lower motor mount~AWR trans. mount/passenger mount~SU shifter bushings~CPE diff mount~H&R springs~Tenzo type M ~235/40/18 Firestone Indy 500 Wide Oval~ipod adapter~HD lip~Prosport boost gauge~ TWM Desert Eagle Shift Knob~JBR shift plate~spin on oil filter~Block8head Vent Pod~ported intake manifold w/ VTCS delete~EBC red pads w/ slotted rotors~4500k HID fogs 2 gal. E85 mix !!! " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " | |
![]() | | #27 | ![]() |
The top of the stem and tip are magnetic, while the valve head and lower part of the stem are non magnetic. And, for being smaller, they're really heavy. I talked to a lab a while back about testing them, but it kinda went to the wayside since I got the other 6. I'll pick that back up. It would be worth knowing, just in case mazda did something else spectacular. I also talked to Mazda Motorsports about the exhaust valve material and they said they can't even find out what it is. Proprietary information that doesn't leave Mazda HQ, lol.
| The Following User Says Thank You to phate For This Useful Post: | GLORIFIEDBOZO (09-25-2012) |
![]() | | #28 | ![]() |
Groans: 39
![]() | | #29 | ![]() |
I have a spare head I wa looking to just get port to the max and call it a day. I'm not sure if I want to mess with the valves and such. I just lack knowledge of all this.
| Blow off valve vs recirculation valve | Vlad | 2010 MS3 - Engine, Transmission & Driveline | 19 | 06-22-2012 07:59 AM |
| Supertech Valvetrain Info | holeinmypocket | MazdaSpeed 3 - Engine, Transmission & Driveline | 26 | 01-13-2012 11:54 AM |
| Supertech wants our head | zx2man | MazdaSpeed 3 - Engine, Transmission & Driveline | 38 | 07-17-2011 06:03 PM |
