 Old 01-15-2009, 03:12 PM   #1
Baseballpler's Avatar
Posts: 129   (View Stats)
Baseballpler has a reputation beyond reputeBaseballpler has a reputation beyond reputeBaseballpler has a reputation beyond reputeBaseballpler has a reputation beyond reputeBaseballpler has a reputation beyond reputeBaseballpler has a reputation beyond reputeBaseballpler has a reputation beyond reputeBaseballpler has a reputation beyond reputeBaseballpler has a reputation beyond reputeBaseballpler has a reputation beyond reputeBaseballpler has a reputation beyond repute
Groaned at 5 Times in 2 Posts
Question Symptoms of an exhaust leak?
So I have no means of getting completely under my car at the moment, but I suspect my testpipe might be leaking or another part of my catback just because of the burbling sound it sometimes makes. Is there like any easy way to know if I have a leak? and would this cause power loss cause my car feels like a fucking slug right now. I have reset the ecu a few times, cleaned the maf and it just seems to be running like shit. So i was wondering if an exhaust leak had anything to do with it, and the best way to tell other than actually being able to get under my car myself. I know it ridiculous but I dont want to drive an hour to corksport if nothing is wrong and Im imagining things.
Baseballpler is offline   Reply With Quote
 Old 01-15-2009, 06:42 PM   #2
booya620's Avatar
Posts: 697   (View Stats)
booya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the world
With the engine running, shove a rag in the end of the tail pipe. You should feel the compression of the engine trying to push the rag out of tail pipe.
If you feel no resistance, there's an exhaust leak. Pressure will take the easiest way out, and by plugging off the end of the pipe, it will force the exhaust to come out where there is a problem.
2008 Sunlight Silver MAZDASPEED 3
[SIGPIC][/SIGPIC] MODS: COBB SF SRI, Mazdaspeed CBE 3", Street Unit 62a Rear Motor Mount, Street Unit Shifter Bushings, COBB Shift Weight, Forge Bypass Valve (Blue Shim).
booya620 is offline   Reply With Quote
 Old 01-15-2009, 06:54 PM   #3
phailerider's Avatar
Posts: 4,639   (View Stats)
phailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the world
Groans: 49
Groaned at 179 Times in 125 Posts
with the car warmed up, barehanded....shake the exhaust and see if it feels loose. or you can do wht ^^^he said.
my method will definitely take your mind of an exhaust leak, if in fact you have one. and that is as good as a fix!!!
phailerider is offline   Reply With Quote
 Old 01-15-2009, 07:31 PM   #4
mo08ms3's Avatar
Posts: 92   (View Stats)
mo08ms3 is a jewel in the roughmo08ms3 is a jewel in the roughmo08ms3 is a jewel in the rough
Its hard to tell without getting under the car. An exhaust leak can definitely cause it to run like shit but it would take a decent size leak to be that noticeable. In my experience, you will surely hear the leak if it is big enough to cause a huge performance. You can probably reach your hand to check the TP to CB connection withhout even jacking up your car to feel for a leak there.
08.5 Black Mica MS3
SU boost tubes for sale:
http://www.mazdaspeedforums.org/foru...ost-tubes.html
mo08ms3 is offline   Reply With Quote
 Old 01-15-2009, 07:35 PM   #5
mlassek's Avatar
Posts: 200   (View Stats)
mlassek is a name known to allmlassek is a name known to allmlassek is a name known to allmlassek is a name known to allmlassek is a name known to allmlassek is a name known to all
look at the joints at all connections and look for black carbon deposits. and if its cold enough steam/smoke might give some clues with the car running using the rag plug
your ears will help you out a lot too
bent rod
mlassek is offline   Reply With Quote
 Old 01-15-2009, 07:42 PM   #6
mlassek's Avatar
did your loss of power and exhaust "burble" start after you installed the forge bpv?
as for just the noise issue, removing the 2nd cat in place for the RP can explain the pops and burbles in the exhaust.
its normal usually happens when slowing or coming to a stop
bent rod
 Old 01-15-2009, 08:47 PM   #7
Naa i had the forge before the test pipe and catback, but I don't know if my boost is on point actually, and Im not putting in a boost gauge because that really fucked things up in my gti and audis i.e. boost leaks. anyhow Im using just a blue spring but everyone has there own combo and rhyme and reason what works for them that the fucking thing is just impossible to tune properly. one minute I hold boost like all hell, the next it feels like Im driving a god damn school bus ya know. but that is whole other topic
 Old 01-16-2009, 06:34 AM   #8
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
Does the cabin drone with a bass-type of noise that's annoying? That often indicates a leak.
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
LBV is offline   Reply With Quote
 Old 01-16-2009, 03:26 PM   #9
mlassek's Avatar
where do you live? ms3's are really finicky about the weather(especially with mods!). its been in the 20s here in MD this week and my car runs like ass when its this cold. lots of backfires, spikes higher than usual and a little sluggish at times. just the way it is...
lol runs great between 45 and 80 degrees
bent rod
 Old 01-16-2009, 08:59 PM   #10
lol thats what I hear, Im in portland, oregon, temps right around freezing and below... that may have a lot to do with it eh?
 Old 01-19-2009, 08:55 PM   #11
PCspeed3's Avatar
Posts: 55   (View Stats)
PCspeed3 will become famous soon enoughPCspeed3 will become famous soon enough
your car will sound like a muffalo...
2009 CWP Speed3
~Disco Potato~
PCspeed3 is offline   Reply With Quote
HTML code is On
Coolant Leak for me Derek88 MazdaSpeed 3 - Engine, Transmission & Driveline 11 08-23-2008 05:33 PM
installed race pipe - exhaust leak phillyb MazdaSpeed 3/6 - Turbo Induction 5 08-12-2008 01:59 PM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 07-10-2008 11:10 AM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 06-10-2008 02:12 AM
Exhaus Leak speed3 MazdaSpeed 3/6 - Turbo Induction 2 03-29-2008 09:14 AM
Page generated in 0.32628 seconds with 26 queries
