![]() | ![]() | #1 | ![]() |
Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
(Thread Starter) | ![]() ![]() ![]() 27% greater flow with a clipped exhaust wheel. The testing has been done for compressor to turbine pressure ratios and the clip has been done in results to that testing (don't ask how much clip was done because will not tell you). Testing to get this done is very expensive and I don't want the others trying to copy us. This is the smaller unit that flowed enough for 350 WHP based on CFM, but we have no idea how this is going to respond to the DI motor. If the eff from DI vs standard injected motors is consistant and crosses over to the turbo's out put, 370 should be possible to the wheels with this first of 3 upgrades we have planned. I hope you guys enjoy the pictures. I have several updates planned with this so stay tuned to the big wheel thread. Thanks. MORE DETAILS IN WHAT WE HAVE FOR YOU THE MS3/6 MARKET STOCK WHEEL: INDUCER 45 MM / MAJOR 56MM VERSION 1 : INDUCER 48.0 MM / MAJOR 60 MM 35 LB. PER MIN. VERSION 2 : INDUCER 48.3 MM / MAJOR 70MM 37 LB. PER MIN. VERSION 3 : INDUCER 48.3 MM / MAJOR 76MM 40 LB. PER MIN. VERSION 1 & 2 AVALIBLE NOW! VERSION 3 NEEDS TO BE TESTED IN LATE MAY. Testing is getting done right now for the version 3, we hope to have more info on this before the end of June but the first 2 options are running the stock and upgraded pumps out of fuel near 24 psi. The stocker appears to be 28 to 30lbs per hour, so each lb you gain should be 10 to 15 WHP added to the car. 35lb wheel should make 350 WHP, 37lb 370WHP, 40lb 400WHP... you see what I am getting at. I will have more info and test data when we are all done testing the 3 versions. Last edited by ptperformance; 05-08-2008 at 06:04 PM. |
![]() | ![]() | #2 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Forgot to add that the inlet is ported out to max so the volume is there for the larger compressor wheel. |
![]() | ![]() | #3 | ![]() |
![]() Join Date: Mar 2008 Location: Monterey Park, ca.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 120
Groaned at 51 Times in 34 Posts
| ![]() ![]() ![]() couple questions. 1. What is the cost, estimated if you aren't sure yet. 2. Will we have to run an upgraded fuel pump to use this turbo? I am not really to excited about the current fuel pumps that are available, I want to get a look at yours before I go that route. 3. Where do I sign up? lol. Great work John.
__________________ 2008 speed3- FOR SALE!!!!!!!!!!!!!!!!!! SEE HERE! http://www.mazdaspeedforums.org/forum/f665/2008-speed-3-sale-177096/ 2000 Honda S2000(track car) |
![]() | ![]() | #4 | ![]() |
Rep Power: 0 ![]() ![]() ![]() Thanks: 11
![]() | ![]() | #5 | ![]() |
Banned ![]() Join Date: Mar 2008 Location: LaLa Land
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,321
Groans: 57
| ![]() ![]() ![]() is this mine? lol i still have no clue whats going on! Anthony alive? |
![]() | ![]() | #6 | ![]() |
Eth/Meth Junkie ![]() Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2926 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,840
| ![]() ![]() ![]() What pre-turbine pressure/intake pressure ratio are you trying to stay below? I run about 2.2 on my Mustang, but I have no idea what is typical for stock or modded MS3s. Any idea on lag with the clippage? I wouldn't mind a little slower spool due to fuel limitations down low... |
![]() | ![]() | #7 | ![]() |
Rep Power: 0 ![]() Thanks: 1
| ![]() ![]() ![]() Purdy, I didn't realize that you were actually increasing the compressor inducer size, nice. What's the exducer look like on these beauts? |
![]() | ![]() | #8 | ![]() |
The clip seems to add about 200 RPM of lag but the boost curve looks great and seems to add 2 to 4 psi on the top end for boost hold. Its a + + if you ask me. | |
![]() | ![]() | #9 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Inducer and exducer on this one. It moves way more air then the stocker. I will try to get some pictures up of the wheel when we have a few more running on the streets. |
![]() | ![]() | #10 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Did you send me your core yet? Thats about the only way you will be getting one.... LOL. I have another one on the way back to me and there are 4 more getting done as I type this. I should have everyone taken care of on these in the next 2 weeks. |
![]() | ![]() | #11 | ![]() |
Groans: 57
| ![]() ![]() ![]() no, mine is sitting in my garage. Last i heard anthony was suppose to send me his as he is having problems. not to sound like a dick but we were also suppose to take car of other matters that we didnt, so untill we do im not sending anything when im unsure of whats even going to happen to it. |
![]() | ![]() | #12 | ![]() |
I recommend a pump upgrade for every MS3 or 6 due to the problems that many are having with the performance falling off up top on the stock turbo. You can use this turbo on the stock pump (we have done this) but you need to keep the boost levels at stock, do not raise them more then 2 psi because the car leans out really bad. Send me a core and thats your ticket in. Keep an eye out for cores for me and that will get you an "IN" with me. Thanks. | |
![]() | ![]() | #13 | ![]() |
I have the CAT back sitting here if thats what your talking about, DP is jigged just waiting for some final parts to show up so I can start on them. I hope thats what your talking about????s | |
![]() | ![]() | #14 | ![]() |
![]() Join Date: Mar 2008 Location: Phoenix
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,548
![]() | ![]() | #15 | ![]() |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
| ![]() ![]() ![]() sub
__________________ ![]() |
![]() | ![]() | #16 | ![]() |
I know from experience the turbo back can have a hell of an influence on that pressure ratio! Tks I dropped from ~4:1 to 2.2 by going from a restrictive cat back to a bullet off the downpipe. :-) | |
![]() | ![]() | #17 | ![]() |
Groans: 57
options so far: I send you a core u do what u do, send it back, i put it on and send you the stocker thast on my car to keep. 2: I get anthony's(which i have heard nothign about for him) and send you the core and the stocker thats on my car. 3: I don't even know what it is im getting, which option, port work? wheel? lol im completly lost, hence the reason im hesitant to send out my stuff. I need to be filled in on to whats going on and what im actually getting, how am i testing it? Track dyno both? Alot of "ifs" I have track times and i have dyno times. 302whp 336wtq and 12.90 @ 111 are the "bases". Last edited by Laloosh; 04-22-2008 at 03:18 PM. | |
![]() | ![]() | #18 | ![]() |
| ![]() ![]() ![]() lol i am wondering where all these extra turbos came from, how does the average person have one laying around? |
![]() | ![]() | #19 | ![]() |
Groans: 57
| ![]() ![]() ![]() i bought a core and the one that is on my car. Most who went BT have gotten rid of their stocker and many of us picked them up for a price. |
![]() | ![]() | #20 | ![]() |
The pressure is crazy high just like on the SRT4 turbo. 90% of it comes from the poor design of the turbine housing. Its a balance between clip, thrust pressures and pressure ratios. It takes time to get it right but when you do, damn it makes for a great driving turbo. | |
![]() | ![]() | #21 | ![]() |
| ![]() ![]() ![]() so in theory we should be able to get more out of these turbo's at lower boost? i was running 20-21psi but with this i can run like 18-19psi and make more power? |
![]() | ![]() | #22 | ![]() |
| ![]() ![]() ![]() Im so in, time to request overtime :thumbsup:
![]() | ![]() | #23 | ![]() |
![]() Join Date: Apr 2008 Location: North Hollywood
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| ![]() ![]() ![]() subing
__________________ (fqspd3) as in F**cken quick speed3 ![]() |
![]() | ![]() | #24 | ![]() |
Groans: 57
| ![]() ![]() ![]() jon, you said in a previes thread that your reworked stockers made 30 whp on stoock boost and probably 50-70 on raised. You also said you were running out of fuel on the big wheel set up that broke and were making very good power. Do you have any proof of this? Dyno numbers? |
![]() | ![]() | #25 | ![]() |
Eatin' Your Tuna ![]() Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,600
Groans: 243
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | |
![]() | ![]() | #26 | ![]() |
![]() Join Date: Mar 2008 Location: San Diego
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,190
| ![]() ![]() ![]() SWEET!!! subbing and hoping one of them them turbo's are heading my way in 2 weeks! thanks fo r the update, john!
__________________ MAZDASPEED6 Engine: Cobb SRI/AP | CPE FMIC/DP/MM/HPFP | MagnaFlow 3in CBE | HKS TwinPower Ignition | Denso plugs | Suspension/Wheels: SSR GT10 19x8 +37 | RPM Street Springs | AutoExe F/R braces | WhiteLine RSB | GT Spec Ladder Bar/Trailing Braces | Exterior: SSG AE Lip Kit | HomeDepot Front Lip Mod | JDM Tailights | Black Emblems | Interior: AutoExe ShiftKnob | TWM STG2 | ProSport BoostGauge | Dashawk | |
![]() | ![]() | #27 | ![]() |
![]() Join Date: Mar 2008 Location: Balitmore
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| ![]() ![]() ![]() I'm in talks with john right now. My car is basicly stock so i will be trying to send him a core this week. once i get it i will go be going back to the dyno for him to get some numbers which should make everyone happpy since i still have stock TMIC and DP and exhaust. just a Cobb SRi and Turbo x's Test pipe thats all.
__________________ My car: 2008 Mica black Mazdaspeed3 sport model: -Currently Serving in the United States Marine Corps. as a Machine Gunner ( 0331 ): -Afghanistan southern heldman province Oct.09'-May.10' MODS: COBB Short air intake, ONE OF THE FIRST PEOPLE TO HAVE THE ACCESS PORT BETA TESTER, Cobb access port, CP-E Catted Down pipe ( now no cat.'s ), Custom Exhaust,Turbo X's Hybrid BOV , Coil Pack spring mod, MY Very own Intercooler Cover mod, 8000K HiD Head Light upgrade, Stri electric boost gauge, EGT and turbo timer, AEM UEGO Wide band A/F Gauge, CP-e Dog bone lower mount with race bushing, Red Calibers, yellow fog lights. CP-E fuel pump upgrade. |
![]() | ![]() | #28 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 69
| ![]() ![]() ![]() I have stocker laying around that i want to rework, i just need to get some $$$. |
![]() | ![]() | #29 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
| ![]() ![]() ![]() looks gorgeous.
__________________ Black Mica '07 Mazdaspeed3 Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing Reppin' ProtegeGarage for life! |
![]() | ![]() | #30 | ![]() |
| ![]() ![]() ![]() Your just excited that this will help you move more fuel pump.... ![]() ![]()
![]() | ![]() | #31 | ![]() |
| ![]() ![]() ![]() hmm whats the core fee for the people who dont have stock turbos lying around =P |
![]() | ![]() | #32 | ![]() |
| ![]() ![]() ![]() wait.... so how much is it to do all the good stuff if i send you my stocker?
__________________ ![]() || CP-E CAI || CP-E Inlet || CP-E FMIC || CP-E Catback || SU TurboSmart BOV || PG Turbo Manifold || CDI/PG Fuel Pump internals+spring || Denso 1step colder plugs || ATP DP || ATP FCD || ATP CEL trick || TWM stage2 SS+bushings || AWR Engine mount || SU rear diff mount || TT rear diff Rear mount || Whiteline anti-sway bar || AWR Endlinks || BC racing CO's || matt black OZ Ultraleggeras + Kumho ASX || Cobb AP || VEI boost || VEI oil Pressure/Water Temp. || AEM wideband || ApexI Turbo Timer || N2MB WOTbox || SM catchcan || BS delete+baffle kit || Spin on Oil filter conversion + Prosport sandwich || Other: Other mods are BS! Sponsored by: STREETUNIT.COM check them out :thumbsup: |
![]() | ![]() | #33 | ![]() |
| ![]() ![]() ![]() lol not at all. PTP has their own fueling stuff coming to market soon enough in addition to what I offer now. The turbo really does look wonderful. If I cared about a warranty I definitely would go the reworked route. lots more power and it all looks the same to the dealer.
![]() | ![]() | #34 | ![]() |
| ![]() ![]() ![]() Yes it looks the same only down side is if they try to replace it under warranty if they don't notice right off the bat by looking at the turbos side by side then you are out a upgraded unit. I work for a dealer so i'm a little special because i'm able to do all my own work warranty and regular stuff since i work as a mazda tech for a mazda dealer. but still i mean this whole hearted if i had my way everyone would be allowed to mod their cars and not have to worry about warrantied voids or being voided and not have to worry about putting their car back to stock to have it worked on. Anyone in Maryland baltimore area hit me up if you need stuff done and i'll help you out as best as possible i think this warranty void police are now getting to trigger happy and it's not fair to the average customer or consumer. It's so stupid cause when i goto training and talk to the higher ups at mazda when i'm at MNAO head quarters or their sister stations they mostly say if the aftermarket part didn't cause the problem or problems then who cares and they're getting sick and tired of getting calls from service people and managers bitching that the car has after market parts. Bottom line this is out of their mouths if the part isn't causing the problem then it shouldn't void the warranty no matter what and the car should be fixed and repaired under warranty just like everyone else. I laughed and told them thats not the case and i have many horror stories of friends and other people getting warranty voided because of stupid stuff. Anyway sorry i rambelled on. PT is nice but LIL'Guy is the O.G> of CDFP's so i'm still stickin with him for any of mine or friends cars i work on that get upgraded pumps. Keep doing your thing play'a
![]() | ![]() | #35 | ![]() |
![]() Join Date: Apr 2008 Location: Utah
Rep Power: 551 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 120
| ![]() ![]() ![]() Probably shouldnt be pitching competitors fuel pump in PT Performances own subforum that they paid for. |
![]() | ![]() | #36 | ![]() |
![]() | ![]() | #37 | ![]() |
(Thread Starter) | ![]() ![]() ![]() |
![]() | ![]() | #38 | ![]() |
![]() | ![]() | #39 | ![]() |
| ![]() ![]() ![]() any new updates? i can't wait to get this ![]() |
![]() | ![]() | #40 | ![]() |
![]() Join Date: Mar 2008 Location: Planet Earth, v3.7
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
| ![]() ![]() ![]() So without a core, total price will be $1499? Also, for those of us with blown seals, will that issue be taken care of? My MAIN concern is not smoking, so that will pretty much make or break the deal for me ![]()
__________________ The fastest MS3 in the whole garage... |
Display Modes | |
Post your autox pictures | Laloosh | Auto-X / Road Racing / Time Attack | 319 | 07-28-2017 08:12 PM |
Installed my carbon fiber dash kit, pictures inside | Death-From-A-Mile | MazdaSpeed 3/6 - Appearance | 26 | 04-26-2009 08:25 AM |
Stock turbo upgrade | mdogg | MazdaSpeed 3/6 - Turbo Induction | 20 | 03-31-2008 01:14 PM |
