 Old 06-22-2012, 09:19 AM   #1
BlueStreak's Avatar
Posts: 1,467   (View Stats)
Default Verify Coil Pack Resistance
I need some numbers to compare to. I'm measuring my coilpack resistance to make sure they're in check, however, I have a feeling the secondary resistance is quite low on all 4.
The check is as follows.
- Disconnect harness from one of the coil packs. Coil pack does not need to be removed from engine, it just needs to be accessible.
- Connect a multi-meter to the first two pins and measure the resistance.
- Report back.
I've searched high and low over the internet for acceptable values and generally, I'm seeing somewhere between 8K-18K ohms being considered normal (varies from OEM to OEM), however, I'm not sure if this applies to 2 wire coils vs. our 3 wire coils.
Mine are reading somewhere around 2K ohms which seems incredibly low.
If one of you guys can check yours when you have a chance or have checked in the past, please let me know.
If my coil pack resistances turn out to be much lower than what is presented, I'll explain how they possibly got hurt. I just need confirmation first.
'07 CWP MS3
Forged.
The Following 2 Users Say Thank You to BlueStreak For This Useful Post:
ms3blackmica (02-22-2013), SilverDemon (06-22-2012)
 Old 06-22-2012, 09:30 AM   #2
SilverDemon's Avatar
Posts: 3,034   (View Stats)
If I can remember, I will check when I get home from work.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following User Says Thank You to SilverDemon For This Useful Post:
BlueStreak (06-22-2012)
 Old 06-22-2012, 11:02 AM   #3
BlueStreak's Avatar
Appreciated, Scott.
'07 CWP MS3
Forged.
The Following User Says Thank You to BlueStreak For This Useful Post:
 Old 06-22-2012, 02:15 PM   #4
I am measuring 1.8K @ about 86° F ambient temps
1st two pins starting from the left..correct?
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 06-22-2012, 03:04 PM   #5
BlueStreak's Avatar
Yessir.
Thanks Scott. Looks like all is well with my coils.
'07 CWP MS3
Forged.
 Old 06-22-2012, 03:21 PM   #6
fooqr's Avatar
Posts: 559   (View Stats)
fooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the world
It's in the factory manual.
Sent from my DROID2 using Tapatalk 2
08 MS3 GT (SSM). JBR WP intake, CS boost tubes, Forge v2 BPV, JBR TB/IM TIG, JBR TB coolant bypass, JBR EGR block-off, 3-bar MAP, PTP pill, bnoon bolt, SM OCC (MD kit) w/ Kat's heater, UR DP (ceramic cat), UR resonated TP/CBE, JBR SSP, SU shift bushings, JBR trilogy mounts (CRMO 88 RMM, 70 PMM/TMM), Koni yellows, JBR RSB, 2nd Fiamm, Stoptech SS lines, Hawk HPS, spin-on CX-9 oil filter, Fumoto valve, PP 5W-30, XT-M5-QS, tints, clear bra, Continental DWS, ITV22, DashHawk, AP, AT internals
There are no stupid questions, but there are stupid people and some of them ask questions.
- A. Funicello
fooqr is offline   Reply With Quote
The Following 2 Users Say Thank You to fooqr For This Useful Post:
BlueStreak (06-22-2012), SilverDemon (06-22-2012)
 Old 06-22-2012, 05:31 PM   #7
Hahaha.. probably so, but it is much easier to just walk out to the garage and test it, then to look it up....I am lazy like that
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 06-23-2012, 08:38 AM   #8
fooqr's Avatar
"...several kilohm is normal..."
- A. Funicello
 Old 06-23-2012, 11:31 AM   #9
BlueStreak's Avatar
Yes. I got that from alldatadiy.com, however, "several kilo ohms can be 2K, 18K, 25K etc.
The majority of my searches showed normal resistance values are much higher for other OEMs than what SilverDemon confirmed.
Now the Speed community has a numerical value to attach to "several kilo ohms" as a normal value for our coil packs.
'07 CWP MS3
Forged.
fooqr (06-23-2012)
 Old 02-08-2013, 08:25 PM   #10
tzddrmz's Avatar
Posts: 8   (View Stats)
tzddrmz is an unknown quantity at this point
Im having some issues with my car also, I have checked my coils on the low and high end resistance. I got 1.7 for the low and 14.2 for the high on cylinders 3 and 4. Then 1.8 on the low and 12.4 on the high for cylinders 1 and 2. Does this mean that cylinder 1 and 2 coils are goin out? Anyone with any thoughts?
tzddrmz is offline   Reply With Quote
 Old 02-17-2017, 12:17 PM   #11
Allaboutthesnail3's Avatar
Posts: 29   (View Stats)
Allaboutthesnail3 is on a distinguished road
I just bought a new ignition coil for my 08 speed3 from edgeautosport it's a new coil and it's reading 0.00 Kilohms measuring between terminals 1 and 2.. is this okay?
Allaboutthesnail3 is offline   Reply With Quote
 Old 02-17-2017, 12:44 PM   #12
Also some part numbers would be nice because the ones that came with the car when I purchased it was 6M8G-12A366... The ones purchased from edgeautosport are LF2L-18-100A.
HTML code is On
Can someone verify? Captain KR MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 7 12-02-2011 03:35 PM
abcink Deals (4-Pack Brother Ink $21.52, 3-Pack HP Laser Toner $72.95) Haltech Hot Deals Section 0 03-28-2008 08:10 PM
abcink Deals (1-Pack Brother Laser Toner $28.08, 6-Pack Canon Ink $13.20) Haltech Hot Deals Section 0 03-26-2008 08:41 PM
Page generated in 0.31989 seconds with 25 queries
