![]() | | #81 | ![]() |
![]() Join Date: Feb 2009 Location: gilbert, az
Rep Power: 1870 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,861
Groans: 237
Groaned at 70 Times in 36 Posts
| Not Ranked : 0 score
__________________ 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, hallman pro rx bc, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Turbosmart Hybrid bpv, SURE TIG's + coolant bypass, ITV24's, CP-E 75d RMM, Medefail Tranny mount, DDM 35W 6000K HID's, SURE Counterweight, 18x8 245/40 NT-05's up front, R: 225/45 Sport Maxx TT's 390whp/400wtq |
![]() | | #82 | ![]() |
| Eth Fiend ![]() Join Date: May 2010 Location: Murhpysboro, Illinois
Rep Power: 6796 ![]() Thanks: 10,662
From what I have seen, 1.09CF represents non-load bearing dynojets. 1.01 seems representative of the eddy current load control dynojets. LC's are effin sweet.
__________________ -06 MS6 - Tuning the high compression forged mill -Corn fed 07 MS3 - Sold | |
![]() | | #83 | ![]() |
![]() Join Date: Feb 2012 Location: Los Angeles, CA
Rep Power: 789 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 965
Groans: 34
| Not Ranked : 0 score I did the same, but I was also wondering if I fucked something up when I did the Injector seal replacement, TIG Installation, coolant bypass, oil catch can installation, intake valve cleaning, EGR delete, CS SRI/TIP Install, 3 BAR MAP Install, and a 1 Step Colder Plug Install in the same weekend. According to the VD Charts I lost 30 to 40 HP.
__________________ "Stockish" Black Mica 2010 MS3 Genpu
![]() | | #84 | ![]() |
Rep Power: 7677 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,969
Groans: 34
ahhhhhhhh haaaaaaaaa....now...right from the horses mouth....we know where 1.01 came from....buuuuuuut still NO MATTER WHAT CF YOU USE VD 1.1.8 READS HIGHER THAN ALL OTHER VERSIONS I say since the vast majority of Dynojets are non load bearing, we use a CF of 1.09 AND verify that still matches a real dyno and holds true in VD 1.1.9 forward. If you want to be uber anal retentive like phate and probably silvapain those guys need to come up with a new CF for loaded dynojets since I think phate came up with that CF on v 1.1.8. I bet it is NOT 1.01 anymore. phate should be able to plug in some older logs into vd 1.1.9 and verify the CF required. [That is if he has screen shots from the older version.] I can post up v 1.1.8 if need be. edit: phate here is a copy of 1.1.8 you can load up if you want. disable your internet connection first ![]() oh and it will over write any other version on your machine...unfortunate but true...you can't pick another destination folder. you can switch back and forth between the two by running the setup again. takes seconds.
__________________ ![]() ![]() PERM ![]() 07 Red MS3 GT - E40 - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - SS Exmani - Cobb DP - CNT CBE - AP w PERMTune - Grim EBC - Dano OCC - CPE CDFP - Labonte S2 WMI/w failsafe - ACT Street Kit - SUv2 RMM -"Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-05 | |
![]() | | #85 | ![]() |
![]() Join Date: May 2009 Location: Kankakee, IL
Rep Power: 7904 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,596
Groans: 121
I'll be more than happy to do some VD versus loaded DynoJet comparisons once my car is running again. I will need to Dyno tune the new engine anyways. Tapadatass
__________________ ATP GTX3071 IWG . 10.5:1 pistons . K1 Rods . Balance Shaft Delete . COBB AP . eBay Special Catless DP . Mazdaspeed Accessory CBE . OCC . Autolite XP5364 Spark Plugs . TRZ TMM . TRZ RMM . MDM SSP . JBR Shifter Bushings . JBR EGR Delete . KW V1 Coilovers . SPC Rear Camber Arms . EBC Yellowstuff Pads . Autotech HPFP internals . 3-Bar MAP Sensor . N2MB WOT Box . ACT 6-Puck Sprung Clutch w/ Streetlite Flywheel . Konig Milligrams 18x8.5 et45 with 245/40's . GrimmSpeed EBCS . Self-PnP IM with VTCS removed . TWM full replacement shifter with 3" extension . TS BPV SU Edition . CX Racing FMIC . HTP 3.5" Intake . Lots of ricer mods . Beans Above the Frank Build http://www.mazdaspeedforums.org/forum/f541/beans-above-frank-build-115919/ |
| The Following 5 Users Say Thank You to silvapain For This Useful Post: | Dano (09-19-2012), Nliiitend1 (09-21-2012), rfinkle2 (09-19-2012), SLOWHATCH (09-23-2012), TiGraySpeed6 (09-19-2012) |
![]() | | #86 | ![]() |
Rep Power: 11908 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42,864
Groans: 235
There is a 25 person dyno day in PA in October which ATVfreek and I are going to. He is going to dyno his car, and I am as well, and both of us agreed it would be cool to take a few logs (as close to dyno as possible) and compare them to the dyno afterwards. We are dynoing on a non-load bearing dynojet.
![]() | | #87 | ![]() |
![]() Join Date: Mar 2010 Location: Philadelphia, PA (Manayunk)
Rep Power: 1673 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,813
__________________ 2010 MS3 VRM - Corn Fed PU CS CBE, CS RP, CS DP, JBR 80/88 Duro Fully Mounted, TS BPV, CPE HPFP, CS SRI/TIP, CPE-FMIC, AP, NGK Iridiums, GS EBCS in 3 Port Int, JMF IM, Hypnotic Tuned, TWM Full Replacement, E4 Weighted Knob, Eibach Prokit, 18x8.5 Konig Milligrams Matte Black with Machined Undercut, 245/40 18 Fuzion ZRiBest Run: 13.1 @ 109 1.9 60ft Atco Slow build in progress ![]() ![]() | |
| The Following User Says Thank You to trf5000 For This Useful Post: | rfinkle2 (09-19-2012) |
![]() | | #88 | ![]() |
Groans: 235
Oh that is actually better, but I thought dturboman stated we would be on their dynojet.
__________________ CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R) ● CPE HPFP ● CPE RMM ● CPE FMIC ● CPE TOW PLATE ● CPE TRITON CBE ● HTP 3" TIP ● HTP BATTERY RELOCATE● COBB AP ● GRIMMSPEED 3 PORT BCS ● COOLING MIST / DEVILS OWN METHANOL INJECTION ● DEFI Boost gauge ● TWM FULL REPLACMENT ● TWM M1 ABRAMS ● JBR SSP ● JBR RSB JBR TIG ● H&R COILOVERS● JUMPING JACKSON 3 BAR MAP HARNESS ● STOPTECH STAINLESS LINES ● AKEBONO EURPO 915a ● TANABE STRUT BRACE ● NEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KIT ● GRAM LIGHTS 57 DR ● TOYO PROXES PLUS | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | trf5000 (09-19-2012) |
![]() | | #89 | ![]() |
Vid of a Scoob on the dyno we will be using:
![]() | | #90 | ![]() |
Groans: 235
Ahh that was it. Sorry Tyler. For clarification we will be on a Mustang dyno calibrated to read like a dynojet. For Fucks sake, I can't keep all of this shit straight.
| The Following 4 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() | | #91 | ![]() |
Groans: 34
I think it will be best to validate your plots and dyno numbers with true DJ numbers.
| The Following User Says Thank You to Dano For This Useful Post: | Nliiitend1 (09-21-2012) |
![]() | | #92 | ![]() |
| Engineered Tuning ![]() ![]() ![]() Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 8353 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,239
Shops self calibrating dymos kills me. At least the drum Dynojets can't be tweaked and that makes them consistent from shop to shop.
![]() | | #93 | ![]() |
| lowspeed ![]() Join Date: Jun 2009 Location: Tally, FL
Rep Power: 1753 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,690
I hear mustang dyno and I instantly think "soul crushing heartless bitch" The local 4wheel dyno is a mustang, and it's a SCHB, doubly so since they won't rig fans to push air through top mounts. I've never seen so much knock or such hellish BAT's. I don't like to talk about the resulting HP numbers cause they were only in the upper & lower 260's.... No big, had to break my dyno cherry somewhere... ![]()
__________________ Mazdaspeed6 GT #3476 TiGray slicktop Cobb AP, SRI & TIP, BNR S3, MAC 3 Port, FMIC, TS BPV, 3 BAR MAP, VTCS Delete M2 DP & Magnaflow, KMD Internals, GPWerks BSD & Baffle, SM OCC, EGR Delete, TB Coolant Bypass, SU Billet RMM TWM Stage II STS & JBR SSB, Prosport Mech Boost RX-8 wheels & 235/40 RE760, H&R Sport Springs, SPC abj's, Strapped diff Stage 1 Brakes: Slotted, Hawk’d, Lined & Blued 405/394 AWD - cf1.01 e38 BNRs3 315/372 AWD - cf1.01 e38 k04 |
![]() | | #94 | ![]() |
Someone just want to post up 1.1.8 vs 1.1.9 plots of the same logs? I have no idea which version I was using, I'll have look my old screenshots. Dynos are tools for tuning. Period. [Meaning I don't really care, and I don't think VD is good enough for anything but looking at very drastic changes in power.]
| The Following User Says Thank You to phate For This Useful Post: | rfinkle2 (09-19-2012) |
![]() | | #95 | ![]() |
If it helps, these are the logs from the MD runs, and screenshots of the dyno results hot and knocky...
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | rfinkle2 (09-19-2012) |
![]() | | #96 | ![]() |
![]() Join Date: Nov 2010 Location: Manchester, England
Rep Power: 706 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,201
Groans: 34
Lol at the fan 6 feet from the front of the car!! Recently went on one that was in a small garage with 27c ambient temps. Ran the car up to 3k to "teach" the dyno, only then did he switch a fan on that was about 6 feet from the front of the car. Due to the fact I'm load tuning and stupid high temps, it pushed the psi required over the map sensor threshold and I couldn't get a run without a cut.
__________________ Tuned with by ![]() Su tmic/corksport intake/custom 3" tbe/grimmspeed ebcs/forge bpv/jbr ssp/jbr rsb/Jbr side mount/sure tig set/sure r3 rmm/kmd internals/pg sst (tune in progress)/3 gauge pod |
| The Following 2 Users Say Thank You to skiptowncat For This Useful Post: | rfinkle2 (09-19-2012), TiGraySpeed6 (09-19-2012) |
![]() | | #97 | ![]() |
Groans: 34
![]() | | #98 | ![]() |
| (Toe-kay) ![]() Join Date: Jan 2011 Location: Oakville Ontario Canada
Rep Power: 8698 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,712
Groans: 503
__________________ ![]() ![]() Tokay Racing BeCuse Seals. BeCuse you need these. Demodded. Mwho? | |
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | rfinkle2 (09-19-2012), TiGraySpeed6 (09-19-2012) |
![]() | | #99 | ![]() |
| Not Ranked : 0 score My comparison was actually done with VD version 1.1.2: ![]() ______________ ![]() Glad I take actual screenshots ![]() PS - Can't wait for some NASTY torque like this (or lots more) again with AWD. Car was in rocket ship mode like this. PPS - And if you remember (I barely do), the correction factor FROM THE DYNO (224xLC dynojet) was 1.01 on these runs.
__________________ -06 MS6 - Tuning the high compression forged mill -Corn fed 07 MS3 - Sold Last edited by phate; 09-19-2012 at 03:58 PM. |
| The Following 5 Users Say Thank You to phate For This Useful Post: | Dano (09-19-2012), Nliiitend1 (09-21-2012), rfinkle2 (09-19-2012), silvapain (09-19-2012), TiGraySpeed6 (09-19-2012) |
![]() | | #100 | ![]() |
If 1.1.9 is similar to 1.1.2, which I think it is, then we should stick with whatever correction factor makes you guys content. 1.1.8 was happy, it seems, for whatever reason. It's an anomaly, so I don't think it's relevant. I never took notice of the actual numbers in any version because this is used to compare: and I load all the runs I want to compare at once. If Brad can supply a version of 1.1.2 to test against, we'll have our answer. But I think this was a lot of uproar for no reason, lol. I do think something close to 1.00-1.01 is most similar to LC dynojets, and ~1.09 is similar to regular dynojets.
| The Following 3 Users Say Thank You to phate For This Useful Post: |
![]() | | #101 | ![]() |
Groans: 34
Here is my buddy's VD plot that we took a few hours ago. I was riding shotgun since he didn't know how to take a log. He has a 2012 White Pu that is fully bolted with all COBB parts (except fuel pump internals which are Autotechs) and was tuned by SoCal COBB. On their mustang Dyno he got 289hp and 312 torque targeting 18 lbs on 91 octane. The knock rarely went past 1.0. DynoJet ![]() Mustang ![]() It seems to me in this example the CF should be more like 1.03 for a Live Mustang Dyno
![]() | | #102 | ![]() |
Groans: 503
You should edit your log in virtual dyno in the throttle position % plane to read 77 all the way down.
![]() | | #103 | ![]() |
![]() Join Date: Jun 2011 Location: Kansas City, KS
Rep Power: 256 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
__________________ Brad Barnhill VIRTUAL DYNO The ONLY way to graph your runs. www.bradbarnhill.com/projects/VirtualDyno |
| The Following User Says Thank You to bbarnhill For This Useful Post: | phate (09-20-2012) |
![]() | | #104 | ![]() |
And, just to say it, Damn glad you're here Brad (love fest...) If we didn't like and use the hell out of your software we wouldn't care enough to bicker like this. Glad to have it.
![]() | | #105 | ![]() |
Groans: 34
(Thread Starter) | Not Ranked : 0 score not sure I would classify this thread an uproar, a significant plotting difference in the versions was brought to light. It was causing me a lot of heart burn, apparently others as well, and I wanted to figure out what was going on.
| The Following User Says Thank You to Dano For This Useful Post: | SLOWHATCH (09-23-2012) |
![]() | | #106 | ![]() |
| Not Ranked : 0 score I understand what you're saying. It becomes a liability with stock bottom end BT cars, where some are trying to avoid excess torque or excess power. When we say "400hp/400tq" is the limit, and the measuring stick changes, it has some potentially devastating results. In this case, of course, the measuring stick shifted in a direction that wasn't harmful...
![]() | | #107 | ![]() |
Groans: 503
Well everyone's numbers shifted down, so for those striving for the edge of 400 and 400, they would have likely gone over than in real numbers had we not discussed this a brought up the thought of a new standard correction factor. A shift upwards in VD numbers would have been safer.
__________________ ![]() ![]() Tokay Racing BeCuse Seals. BeCuse you need these. Demodded. Mwho? Last edited by Tokay444; 09-20-2012 at 09:04 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to Tokay444 For This Useful Post: | SLOWHATCH (09-23-2012) |
![]() | | #108 | ![]() |
The anomaly was 1.1.8. Why did no one bitch when 1.1.8 was suddenly reading higher than 1.1.7 or any other prior versions? This thread is killing me guys, we're talking about chasing numbers. The only time it should have messed up ANYONE was if they started using VD on version 1.1.8, then saw a sudden decrease in 1.1.9. For the astute, they would have realized it. Those that didn't realize it probably aren't tuning themselves. I think the question is really, "was 1.1.8 the only version to have skewed numbers". If 1.1.9 is the only version to read low, then I side with the "potentially harmful" argument. The comparison should probably be between 1.1.9 and 1.1.7. Quite honestly, though, if you are tuning THAT close to the edge, and thinking it will be safe, or NEEDING it to be safe, you shouldn't be that close to the edge. We have had so many blown engines at stock/250hp/300hp/350hp/400hp that having a definite "400/400 figure" is impossible. We've seen solidly tuned cars let go well before that, it's a risk we all take.
| The Following User Says Thank You to phate For This Useful Post: | Tokay444 (09-20-2012) |
![]() | | #109 | ![]() |
Groans: 34
![]() | | #110 | ![]() |
Groans: 34
I was upgrading hardware in an attempt to gain more power.... when you make said hardware change AND went from VD8 to VD9 and saw a drop in HP you ask yourself WTF is going on here. did the HW change cause the drop in power...was it the map...so you start swapping maps and hardware back around only to find that the program you relied on to graph your deltas is the root cause. Now in hindsight it is easy to see that all logs, old and new, should be replotted in the current version. This does take quite a bit more time than going back to an already plotted screenshot. Its not realistic to use a real dyno for these type of changes nor is it necessary. I wasn't even addressing the potential safety issues you brought up b/c like you, I don't think you need to run to the edge of safety on a virtual plotting program, although it is pretty damn accurate if you control the inputs. That is all I am saying and if you don't see that point nor agree we can respectfully disagree with each other...its really no big deal now that the issue has been uncovered. I see this thread as a constructive analysis of the differences uncovered in VDs plotting algorithms. nothing more nothing less. peace brother phate
| The Following 5 Users Say Thank You to Dano For This Useful Post: | 802MS3 (09-20-2012), Nliiitend1 (09-21-2012), phate (09-20-2012), skiptowncat (09-20-2012), SLOWHATCH (10-07-2012) |
![]() | | #111 | ![]() |
I still love you <3
| The Following 2 Users Say Thank You to phate For This Useful Post: | Dano (09-20-2012), Nliiitend1 (09-21-2012) |
![]() | | #112 | ![]() |
Groans: 34
Haha We were each just expressing our opinions, nothing wrong with that. Oh and I know I'm hard to love, being old and stubborn so I do appreciate that you still do. Tappin
| The Following User Says Thank You to Dano For This Useful Post: | SLOWHATCH (10-07-2012) |
![]() | | #113 | ![]() |
Groans: 503
and it messed me up.
![]() | | #114 | ![]() |
I still stand behind that its just in the smoothing factors from 118 and 119. The calculation of power has not changed in the least since 1.0.1
| The Following User Says Thank You to bbarnhill For This Useful Post: | silvapain (09-21-2012) |
![]() | | #115 | ![]() |
Groans: 34
I don't and never did dispute that fact...lol I just pointed out that the global, behind the scenes, smoothing changed between versions which does change how the HP is plotted. so in effect it changes the HP calculation given to the end user. BTW lastnight I just happened to pull up a plot from 1.1.7 for one of the guys I tuned back in March to post up in another thread. I plotted those same logs in v 1.1.9....guess what? v 1.1.8 is not an outlier...v 1.1.7 and 1.1.8 plot the same. you can definitely see the newer version cuts down the wild datalog runs as evidenced by the blue runs in each plot. it is what it is. ![]()
![]() | | #116 | ![]() |
| Not Ranked : 0 score ONOES! I wonder how 1.1.2 stacks up...
![]() | | #117 | ![]() |
Don't care anymore.... ![]() Done with the old stuff, just looking forward to the final decision on what CF to use so we can all go back to measuring our (slightly shorter now) dicks....
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | SLOWHATCH (09-23-2012) |
![]() | | #118 | ![]() |
Rep Power: 4091 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26,497
More fuel for the fire. This datalog lines up pre close in both versions with only the smoothing changed from 4 in 1.1.8 to 3 in 1.1.9 ![]()
![]() | | #119 | ![]() |
Groans: 34
The better the log/run the closer they will be due to the global smoothing. No road bumps, dips etc. Tappin
![]() | | #120 | ![]() |
The two logs above in 118 and 119 ... those are what I would expect since smoothing was increased per level so it takes less to smooth the same amount.
| The Following User Says Thank You to bbarnhill For This Useful Post: | SLOWHATCH (09-23-2012) |
| Virtual Dyno | bbarnhill | Mazdaspeed3/6 General Discussion | 839 | 12-21-2012 07:22 AM |
| Virtual Dyno fun | Mfinlay04 | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 5 | 08-08-2012 10:38 PM |
| Virtual Dyno For Mac? | neofandango | 2010 MS3 - Dyno Sheets/Discussions | 7 | 08-06-2012 09:28 PM |
| Virtual Dyno | CJM | 2010 MS3 - Dyno Sheets/Discussions | 0 | 05-23-2012 04:53 PM |
