  • 1 Post By superskaterxes
 Old 03-08-2011, 10:41 AM   #1
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Default VTCS removal how to ??
looking to remove the vtcs and i get the part of welding or using epoxy to fill in the hols.. but what about the solenoid ? will atr shut the cell off ?
i have read some post about it but a nice how to would be great !
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 03-11-2011, 07:59 AM   #2
jracer's Avatar
Groans: 89
Well i am looking to do this but not to keen on how to do the vac. lines and how to not get a cell.
I have this extra mani i am messing with and i did this and wanted to know from anyone if it will work or not ??
I took the rod and flappers out.. cut the rod at the end so it was flush with the inside port.
then reinstalled .. seems like it would think the rod/flappers are still there.. correct ??
Then i am going to JB weld the holes in the ports where the rod once was, then sand it all the ports smooth ect...all while keeping the vac. lines sensors ect hooked up..
what ya guys think ?? Is there any gain bye doing this mod ??
some pics below........
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
Calvin1962 (09-26-2015)
 Old 03-11-2011, 08:29 AM   #3
bova's Avatar
Posts: 3,815   (View Stats)
Groans: 45
thats probably not a bad idea if you don't want to do the resistor mod to eliminate the CEL.
jracer (03-11-2011)
 Old 03-11-2011, 08:40 AM   #4
jracer's Avatar
Groans: 89
ATR wont shut the cell off ?
I am wanting to do stuff when i have my mani off when i do my CPE injector seals...
EGR block off with plug in mani.
maybe a SURE gasket ,and the VTCS delet..
i was out looking just now and i see only one vacuum line going to the top of the mani ( the black box thingie with some sort of sensor )
i see one little hole would need to be sealed ( vacuum hole that vents into the bottom of the black box ) other than that.. just unplug both plugs ?? remove the whole mess on top of the mani and the bulbus plunger thing on the end ?
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 03-11-2011, 09:24 AM   #5
remove every single component from the VTCS. ATR will shut off any cels associated with it.
you dont need to fill in the holes between the runners but u DO need to plug the hole on the top of the mani and on the right side where the rod basically exits the mani.
Fobio (03-21-2011), jracer (03-11-2011), nlgiebel (01-08-2016)
 Old 03-11-2011, 09:26 AM   #6
bova's Avatar
Groans: 45
well that sounds easy enough
jracer (03-11-2011)
 Old 03-11-2011, 09:30 AM   #7
jracer's Avatar
Groans: 89
yes !!!!!!!!!!! thats what i am gunna do !
now what ya think of the SURE intake gasket ?? worth it ?any gains from vtcs delete??
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 03-11-2011, 10:14 AM   #8
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Can you pass an obd2 plug in if you shut off the cel with ATR?
I'll be upgrading to an pnp'd IM soon without VTCS as well.
I've heard good things about the IM spacer gasket and the TB coolant bypass with lowered BAT's. I'm going to do this all at the same time while the mani is off.
NATOR PA
The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post:
jracer (03-11-2011)
 Old 03-11-2011, 10:27 AM   #9
jracer's Avatar
Groans: 89
what two codes would have to shut off in ATR ??
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 03-11-2011, 10:34 AM   #10
i have a spacer and i LOVE it. seriously a huge difference in heat soaking and BAT's
i dunno if anyone has tried for sure but i will let u know in a month or so when i get tested haha
P2006/2009
The Following 5 Users Say Thank You to superskaterxes For This Useful Post:
doubleflusher (03-21-2011), Fobio (03-21-2011), jracer (03-11-2011), mike8748 (03-21-2011), rfinkle2 (10-19-2012)
 Old 03-11-2011, 10:39 AM   #11
jracer's Avatar
Groans: 89
one last question.. when you shut off the code.. do you do it in your map in atr ?
or is it a global setting in ATR ..
so every map you have.. you have to shut the desired code off...??
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 03-11-2011, 10:45 AM   #12
bova's Avatar
Groans: 45
well you do it in global ATR, but then you save it to the map...i'm not sure if it reverts back after you close or not.
jracer (03-11-2011)
 Old 03-11-2011, 10:56 AM   #13
qtrmile beast's Avatar
Posts: 2,401   (View Stats)
for those that don't want to deal with relay and other things to get rid of the codes you just want to get rid of the butterflies. Well you can just cut the rod and install the diaphram back into the intake and your golden. How ever it will LOOK better if you were to get rid of it all together. here are a couple of pics i took quickly this morning in response of jracers PM to me... I am porting this intake so i put the diaphram back in there for this picture so you can see what it looks like when the rod is cut.
Once you cut it and you install it back in the intake the diaphram will do just as it is supposed to and the ECU will not know the at the butterflies are gone. As for the box on top you can get rid of that and i just either jbweld the hole shut or you can tap it and put a plug in there... What ever floats your boat...
track weight 3220
street weight 3370
The Following 5 Users Say Thank You to qtrmile beast For This Useful Post:
doubleflusher (03-21-2011), Fobio (03-21-2011), hnda etr (05-20-2011), jracer (03-11-2011), MS3-a(sore)ASS-rex (03-11-2011)
 Old 03-11-2011, 11:44 AM   #14
jracer's Avatar
Groans: 89
Thanks !!
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 03-11-2011, 12:35 PM   #15
Groans: 224
Hey! That's my intake mani! LOL!!
So charles, you're saying I won't have a CEL when I swap the mani? Score!!
NATOR PA
jracer (03-11-2011)
 Old 03-11-2011, 12:47 PM   #16
That be yours and no you will not have one!!!!!
track weight 3220
street weight 3370
The Following 2 Users Say Thank You to qtrmile beast For This Useful Post:
 Old 03-11-2011, 01:44 PM   #17
jracer's Avatar
Groans: 89
How much for a port job ?
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 03-21-2011, 12:08 AM   #18
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
are u planning to port it bigger? .. it looks like u still got a some room till the gasket
08 MS3
() Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX
() Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms
() Centric Slotted Rotors/ Posi-Quiet pad
() Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90
easy is offline   Reply With Quote
 Old 04-25-2012, 07:05 PM   #19
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
thatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the world
Anyone know those codes yet? Ill keep looking but this thread was almost at the top of my search. Ill update if I find them first.
edit
VCTS troubleshooting
and
http://www.mazdaspeedforums.org/foru...s-system-9150/
| CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
thatsmrgimp2u is offline   Reply With Quote
 Old 04-25-2012, 07:45 PM   #20
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Another question that is pertinent.
How much porting can you do to match "enter phenolic spacer here"?
Plug n play of course, don't want any suprises is all.
Good revive of a thread.
HTML code is On
HOW TO: Remove MIL's caused by deleting the VTCS system SSinstaller MazdaSpeed 6 - How-To's 56 12-12-2017 05:36 PM
MS6 ECU removal kore2000 MazdaSpeed 3/6 - ECU Computer Tuning 14 01-27-2010 03:19 PM
VTCS guestion SharkDiver MazdaSpeed 3/6 - ECU Computer Tuning 12 10-29-2009 10:57 AM
P2004 and P2010 with vtcs delete Jarods7920 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 09-16-2009 12:49 PM
Who has removed there VTCS? SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 0 08-01-2009 09:29 AM
Page generated in 0.43330 seconds with 28 queries
