  • 1 Post By E.Murray
 Old 10-12-2017, 12:04 PM   #1
E.Murray's Avatar
Posts: 22   (View Stats)
E.Murray is an unknown quantity at this point
Default What to check on used long block?
I found a long block out of 52k mile 2013 car at a dealership. They said the car was a trade-in that was smoking, so they replaced the engine. Seems a little extreme, but the tech I talked to (the guy who did the work) just kind of shrugged. He said he thought the engine was ok and got the approval to sell it. So I jumped on it.
That was a few months back and it's just been sitting in the garage since then. I finally got around to checking it out and it seems to be fine. I did a leakdown test and cylinders 1, 2, and 4 are all at 16%, with the only hiss coming through the intake valves. If I cover up the intake port, the leak goes to virtually nothing. Cylinder 3 shows 22% and, again, only past the intake valve. Obviously, this is a cold motor. I can see that the valves are dirty, so I soaked the #3 in some Seafoam, but the reading didn't really change.
So, finally, here's my question: what else can/should I check? I think the plan has changed, so I'm on the fence about using the motor. I was going to just sell it as-is on here, but found out I need 100 posts first. That's probably never going to happen since I only post when I actually have something to say and it will take years to have 100 things to say... So maybe I'll keep it. Either way, I want to know what I'm looking at without a bunch of disassembly.
E.Murray is offline   Reply With Quote
 Old 10-12-2017, 12:24 PM   #2
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
I don't think soaking it would be enough. I think you'll have to get into it and pressure blast with media. As far as that goes
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
 Old 10-12-2017, 12:28 PM   #3
E.Murray's Avatar
Which puts a bunch of stuff in the cylinder specially designed to be abrasive. Unless there's a safe way to do it?
What's the best way to get the valves clean? I let it soak, then blasted it out with a rag wrapped around the air nozzle (to catch all the black crap). Learned about the rag the hard way...
 Old 10-12-2017, 12:32 PM   #4
Bexar's Avatar
Pull off intake mani
Google "cleaning valves mazduhspeed3"
JBR:
 Old 10-12-2017, 12:35 PM   #5
E.Murray's Avatar
Ok. I'll try to do that this weekend. I didn't know there was an established way to do it. Anything else I should check while I'm in there?
 Old 10-12-2017, 12:48 PM   #6
Bexar's Avatar
Seems like it was pretty early in it's life at 52k. Maybe see what the oil looks like if you haven't already. It will be interesting to see how bad the valves are .
I mean check the pan for debris if you're messing around with the engine anyway (and it's out of the car). Could do a timing chain change.
JBR:
 Old 10-17-2017, 09:55 AM   #7
E.Murray's Avatar
I pulled the pan off last night and there is no metal in it.
Db09ms3 likes this.
 Old 10-17-2017, 02:29 PM   #8
Db09ms3's Avatar
Posts: 207   (View Stats)
Db09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant futureDb09ms3 has a brilliant future
Groans: 35
Nice. Check the chain stretch from the valve cover.
 Old 10-17-2017, 03:28 PM   #9
E.Murray's Avatar
Good tip. I’ll do a search on how to check that.
HTML code is On
Page generated in 0.30550 seconds with 23 queries
