The 'What Should I do to my MS6 (and MS3)" thread! I posted this on the other forum, but I think it would be useful here as well. Not everything below applies to the MS3, just ask and I'll clarify. This thread is designed with the sole purpose of stopping n00bs from asking that infamous question: "HaI i'm new...I gotz a MS6 -N- I waHnt to m4ke iT teh fa$t3r! H0w do aye?" Fear not! This thread is designed to be a simple one stop solution to answer this question. My goal is to break it down for those on a budget with recommended setups from members who have been here for a while, including myself. The goal is to provide a cost effective solution and give you noticeable gains, and update this as parts become available in the future. I encourage any member to PM me experiences/suggestions, but please keep unnecessary chatter to a minimum. I will ask the 6/MS6 moderators to please clean up this thread as they see fit. When installing these parts, it's important to save your stock parts. Should you need work at the dealer, you can swap most(or all) of them out and take it in to avoid having warranty issues. NOTE: This is merely an opinion. These are not absolutes set in stone, so please do not jump me for telling you something that you may not agree with 100%. I assume no responsibility if you void your warranty based on suggestions from this list. BASIC BOLT-ONS Goal: Simple install, quick gains, cost-effective ==========Engine:========== Cold Air Intake/Short Ram Intake Brands: AEM, Mazdaspeed, Cobb, ProtegeGarage, Corksport, CP-e Gains: 10-20hp/10-30tq (est.)(depending on model) Price: $175-400 Install Difficulty: 2/5 (grab a few beers and go to town) Bypass Valve (BPV) Brands: Forge, TurboXS, Turbosmart, Greddy, HKS Gains: Holds boost pressure better than stock Price: $150-350 Install Difficulty: 1/5 (5 minutes, literally!) Turbo Inlet Pipe (TIP) Brands: CP-e, Cobb, RPMC Gains: 6-7hp, improved turbo response, spool at lower RPMs than stock Price: $150-200 Install Difficulty: 3/5 (1+ hour, several hard to reach spots) Top Mount Intercooler (TMIC) Brands: ETS, TRZ (?), Street Unit, AutoExe Gains: up to 20hp/tq Price: $500-800 Install Difficulty: 1/5 (swap the old for the new under the hood, right on top) Plug 'n' Play tuning solution: Brands: Cobb Gains: Depends on setup Price: $695 Install Difficulty: 1/5 (plug into OBDII port) ==========Exhaust:========= Test Pipe (TP) Brands: Street Unit, Turbo XS, SLS Gains: 10 hp (est.) smoother turbo response Price: $100-150 Install Difficulty: 1/5 (4 bolts under car, swap cat out) Cat Back Exhaust System Brands: Magnaflow, Corksport, ETS, CP-e Gains: ?????? Price: $600-1000 Install Difficulty: 2/5 (get under your car and swap some pipes!) ==========Drivetrain:=========== Rear Motor Mount: Brands: AWR, Street Unit, CP-e Price: $80-130 Gains: More fluid shifts, better overall driveability Install Difficulty: 2/5 (2 bolts, need a jack to hold motor up) Short Shifter: Brands: TWM Price:$130-200 (depending on options, with or without bushings, Stage 1 or 2) Gains: Shorter shifts between gears, less slop in shifter Install Difficulty:2/5 (1+ hour, removing some interior trim temporarily) ==========Suspension:========== Lowering Springs: Brands: Eibach, Tein, Tanabe, H&R, RPM, AutoExe Price: $200-350 Gains: Improved spring rates, lower stance Install Difficulty: 4/5 (need time, tools, and an alignment when finished) Front Strut Tower Brace (STB) Brands:Corksport, AutoExe Gains: Stiffened front suspension Price: $125-250 Install Difficulty: 2/5 (just a few bolts under the hood) Rear Sway Bar (RSB): Brands: AutoExe, Whiteline Price: $180-350 Gains: Stiffened rear suspension Install Difficulty: 3/5 (under the car, removal/reinstallation of newer sway bar) Q - What should I buy for XXXX amount? A - Depends on what you're looking for. This is the tricky part. Some people go for all power, where others want a good balance of things. Below are some standard suggestions for people based on several price points; $500, $1000, and $1500. 1 - The $500 'Package'
2 - The $1000 'Package' All of the above plus:
Happy Modding! |
Dont forget "hole in block stopper" ............... comes in a 12 oz can ... shake and spray the block ... rods wont fly out of it ... :grumpy: |
I'll be sure to add that to my list... |
As I said on the other forum (but need to get my post count up on this one) great post. Worthy of a sticky. |
no offense, but no downpipes on the list? thats like the first power mod besides a cai. and... you left out the premier plugnplay engine management on the market when you only mentioned the AP:hmmm: |
From peoples complaining for the RSB install on a MS6, I would think it's a 4/5 to 5/5 lol. |
i don't think very many owners would say a RSB is or should be one of the first parts on the car.... and even fewer owners would say a $245 strut tower bar is part of the first $1500 to spend.... |
You're gonna get flamed. There's a ton of shit missing from that. And some of the suggestions don't make sense. |
| All times are GMT -7. The time now is 10:33 AM. |
