 Old 09-13-2011, 12:03 AM   #1
here.n.there's Avatar
Posts: 89   (View Stats)
here.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud of
Default what is it and what's it's function?
noticed this piece underneath the oem intercooler intake, on the driver's side...
three things:
1. what is it?
2. what's it's function?
3. does anyone know if taking it off would be detrimental to an oem air intake setup?
...just because you're paranoid doesn't mean they're not after you...
...what do I call my car?!!
I call it...RAGE...
...I'll lead with a straight, follow with a hook, then I'll step to my right...if you don't know these steps, you shouldn't dance with me...for those who do recognize these steps, you'd know that I can dance with the best of them...in my prime, anyway...
here.n.there is offline   Reply With Quote
 Old 09-13-2011, 12:11 AM   #2
Oliverms3's Avatar
Posts: 1,632   (View Stats)
Oliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the world
its for the stock intake... that's where the air goes in.... I think for the n/a 3's
2010 BM MS3 - Cobb AP||3gal corn||Autotech Internals||ETS TMIC||Forge BPV||Denso Iridium ITV22||TurboXS DP||ARK exhaust||CP-E Nano SRI||PG TIP||JBR RMM||JBR PMM||TRZ TMM||NRG ETD||DDM 55w 5000k HIDs and DDM 35w 3000k HID fogs||JB Heavy Knob||JB SSP||ST Coilovers w/ Eibach rear Camber Kit(made by SPC)||17x9 +28 Drag DR31 (track) RPF1 18x8 +35 (DD)||HKS TT Type 0||Clarion EQ||MB Quarts speakers||Pioneer amps and 10" Competition Sub.
346hp 392lbs of sexyness
Oliverms3 is offline   Reply With Quote
The Following User Says Thank You to Oliverms3 For This Useful Post:
here.n.there (09-13-2011)
 Old 09-13-2011, 12:16 AM   #3
how does that apply to the MS3's? would it change the rate of airflow to the oem intake if removed? or is it's function supposed to regulate cooler air to the oem intake?
thanks for the reply, by the way...
I call it...RAGE...
 Old 09-13-2011, 12:16 AM   #4
SWAY's Avatar
Posts: 2,517   (View Stats)
SWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the world
Groans: 190
Groaned at 60 Times in 43 Posts
better change that avatar before you get an infraction
~2011 Liquid Silver MS3~ ---->> ZZB
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
SWAY is offline   Reply With Quote
The Following User Says Thank You to SWAY For This Useful Post:
 Old 09-13-2011, 12:18 AM   #5
i didn't know about that...thanks for the 411...
I call it...RAGE...
The Following User Says Thank You to here.n.there For This Useful Post:
SWAY (09-13-2011)
 Old 09-13-2011, 12:32 AM   #6
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
themytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the world
Groans: 38
does nothing when your little plastic air diverter things to the tmic (that is the technical term, srsly) are still there. if you go fmic, and remove the little plastic things, removing that cover/plug will send a little cool air to the intake. doesnt affect much either way.
BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB
25%E85FREEKPERMED
themytb is offline   Reply With Quote
The Following User Says Thank You to themytb For This Useful Post:
 Old 09-13-2011, 09:26 PM   #7
so, as i understand it, the only time that removing it would prove useful is if i were to go fmic and remove the plastic air diverters that usually channel cool air to the tmic, thus letting cool air through the unblocked whatever it's called to the oem air intake...
i was just curious, that's all...
thanks!!!
I call it...RAGE...
HTML code is On
Q on ECU injector function. Al J MSP - ECU Computer Tuning 5 01-11-2013 09:32 PM
BPV bling or function huffentuff09 MazdaSpeed 3 - Engine, Transmission & Driveline 25 01-11-2011 01:39 PM
Abs vs Req Load in ATR + ECU Function Notes FORZDA 1
Cobb ATR Support
44 02-15-2010 10:02 AM
Using the MAF X-FER function bykeryder4life MazdaSpeed 3/6 - ECU Computer Tuning 4 06-11-2009 05:26 PM
Page generated in 0.27846 seconds with 24 queries
